1/2 drive.... how important
Kev442
Wi
I slowly added 3/4, starting with a breaker bar because the 1/2 flexed too much. Then added the the HF cheapy set. Last year I noticed various 3/4 sockets on Cripes. I have 3/4 sockets that go down below 1" now.:wtf:
KillNThrill24
Wadsworth, Ohio
I have a 3/8" deep well impact snap on socket set and ratchet that I have thoroughly abused, and they've held up incredibly well.
That said, I much prefer to use my 1/2" stuff. The extra torque I get from my 1/2" ratchets being longer makes it worth it alone. Not to mention the added strength of the 1/2" stuff for peace of mind. I also have not broken any 1/2" sockets, where as prior to my snap on stuff, I have snapped some 3/8" sockets.
Once every blue moon, I do have to bust out the 3/4" stuff too. It's nice to have a lot to pick from.
Sent from my Note 9 using The Garage Journal mobile app
JulianMorrow
Oklahoma
My favorite tool is an old 1/2" Craftsman RH 9-43797. I always reach for that ratchet before any other tool. As KillNThrill24 noted, I like the extra leverage the 1/2" drive provides--let the tool do the work. But I recently used my 3/8" Craftsman RH 9-43796 on my son's 02 Camry for an ATF spill & fill. The transmission pan takes a 10mm hex, and all my hex sockets were 3/8". Those two Craftsman ratchets are almost as old as me, but they still do the job.
FSrepair&fabrication
maryland
1/2 is small. I have more 1” and 3/4 than 1/2. Once you get over a 5/8 bolt (15/16 head) 3/4 really shines especially with air guns. If you work on cars or pickups in the rust belt, 1/2 is a no brainer. The work decides what tools you need...
Nero
I use 1/2" drive on everything from my motorcycles to my truck. Lug nuts, axle nuts, steering/suspension stuff like ball joints, they all require (or at least are best served by) 1/2" drive. And they're not all easily accessible by impact, so I do use 1/2" ratchets and chrome sockets/extensions regularly as well.
You don't strictly need chrome 1/2" sockets or extensions, though. Impact sockets/extensions work just fine with a ratchet and torque wrench as well.
Only exception of having strictly impact, is you may wish you had a chrome socket once in awhile if you have a clearance issue to where the impact socket is too thick.
Tallpilot
Orlando
I did the same. I needed to turn an axle nut about 1mm to get the cotter pin holes lined up. It’s disconcerting when a 24” breaker bar visibly flexes. At that point you really don’t care about elastic vs plastic deformation. You just want something that doesn’t make you envision impaling yourself.
JulianMorrow
Oklahoma
It would be smart for me to buy another 1/2" ratchet, since I only have one--my 1/2" Craftsman is 30 years old. I'd hate for that to break in the middle of a job without another 1/2" ratchet. Not sure I like the new Craftsman ratchets coming out of China with the flat handle. I'd like to pick up a Snap-On 1/2" Flexhead, but can't envision spending $200 on a ratchet.
Nero
Try this: I've had it for a few years in a professional environment, and it's held up, and it's not terribly expensive either.
https://www.napaonline.com/en/p/CHQR12FQR
JulianMorrow
Oklahoma
I was in NAPA a few weeks ago--saw the Carlyle line & think there was some GearWrench in there as well. I was on eBay last weekend and *almost bought a $60 used Mac 1/2" flexhead ratchet. I hit the site the next day for a second look and the Mac ratchet was gone.
wilb1976
Maui
This is my usage.
Work - 1/4” 5%, 3/8” 80%, 1/2” 10%, 3/4” 5%
Home - 1/4” 40%, 3/8” 50%, 1/2” 10%, 3/4” 0% (so far)
Formula
If you have to ask that question, then you yourself probably don't need them.
zendriver
Indiana
I never use 3/8 when working on brakes and other heavier fasteners. 1/2 only.
FWIW other than a Cman 12pt ratchet/socket set, all my 1/2" are HF 6pt impact sockets.
Works perfect and leaves a lot of room in the tool chest, for other stuff.
bonneyman
Desert SW
10-4
In residential HVAC I use 1/4" drive almost all the time, some 3/8" drive. Panel screws, cabinet attachment bolts, etc.
Sockets are not that important - wrenches are the thing. Long, short, stubby, angle, flare, 0 offset, ratcheting, crowsfeet. Every size in like 6 or 7 styles. Never know where the dang fittings are going to be located.
matthew
When I got my first vehicle, 3/8" drive was my go-to. But a fairly high percentage of fasteners on that were around 9/16" or 14mm in size.
Since then I've switched to 1/4" being my most used, and 1/2" is probably 2nd most. Pretty simple reason why - furniture and plumbing are too easy to overtorque, and 1/4" is just convenient. The car uses a lot of 10mm. Same with small engines. And even though my car is smaller, I seem to run into 21mm and larger fasteners more often than on my old truck - seems like the way things are designed has changed, and fewer larger fasteners are the norm.
There's still jobs I still use 3/8" for - spark plugs comes to mind in particular, but I also tend to use them on drain plugs. And my 3/8" socket collection is the most comprehensive - my 1/2" selection in particular isn't as complete. But if I was starting from scratch, I'm not sure I'd do the same.
Although, come to think of it, 1/4" hex drive screwdriver bits in a bitrachet are right up there with 1/4" square drive in how often I use them. For anyone interested enough to read this board, and just putting together a general purpose tool collection, I'd say both that and a basic 1/2" is important.
davethorik
Norka, Ohio
One of the first vintage "sets" I put together was a vintage mishmash of 3/4 drive stuff. Bonney rat, fair bit of other Bonney bits but all USA 3/4 thru 2-3/8". It didn't cost me a lot of money but I did this over maybe a 6-8 month span of time.
In 2017 I finally got me some quality 1/2 drive long ratchets. Cornwell flex heads at 17 and 27" long, and a Snappy fixed head at 2'. I now use these with an adaptor to 3/4. They are longer than my Bonney 3/4 rat at 19" by a bit. I use 1/2 drive a lot. At home and at work.
Aaron_W
I'd say all 3 have a place, but I'd drop 1/4" before 1/2".
The other thing is there are times where you need two wrenches, like holding a bolt with one and turning the nut with the other. It makes a lot more sense to me to have a set of 3/8" and a set of 1/2" instead of duplicating everything in one size.
If somebody made me choose only one, I'd have a tough time, 3/8" will do about 90% of what I need, but in practice probably only does 40-50% of the work. It is generally handier, but when I need 1/2" drive it is certainly nice to have and I have a lot more confidence in it when breaking loose a stubborn bolt.
So far I've not needed anything larger than 1/2" drive, but I just bought an old Dodge 2 ton 4x4 truck, so I could see finding myself building a small selection of 3/4" drive in the near future.
danielbuck
I do have duplicate sockets in 1/2", but often I'll grab a large (2 foot handle) crescent wrench to hold the opposite end while I crank away the other side with a socket. (or blast away with an impact), for bolts that go through a frame, where there's easy access.
MrDeerHunter
I have a 3/4 drive SK set that I use fairly regularly and I use 1/2 all the time on my tractor. It all depends on use. If you have the space in your box buy a cheaper set and see if you use it. 1/4 and 3/8 for vehicles and the bigger stuff is for bigger equipment.
Sent from my Moto Z (2) using The Garage Journal mobile app
Engineer61
Colorado
I bought the Greys Duo 1/4" socket set and use it a lot with my Milwaukee 1/4 hex driver, both around the house and on my 3/4 ton truck. The ratchets in the Duo sets have a low tooth count (1/4" is 72 tooth but 1/2" only 24) and I rarely use them but the sockets are great. They are chrome socket wall thickness, but made with a high strength alloy that gives them impact rated strength. Both SAE 3/16 - 9/16 and metric 4mm - 15mm, std and deep sockets, all in one long but thin case.
bonneyman
Desert SW
I for one would like to see your collection of 3/4" drive Bonney! :drool:
Teenager with old tools
riverside california
Am I the only odd ball that for homeowner use has 3/4 sockets and impacts and uses them? I needed to change an axle(CV) on my Accord a couple of weeks ago and need the bigger stuff.
Never needed it for anything on my s10 including all the suspension and axles but sure would have been nicer than a pipe over a half inch breaker bar. Now i’ve got a 3/4 set I use on my k10 and my Cummins and I would never go back to not using it
Aaron_W
Yeah, there are certainly other options available, often times I use a combo wrench on the back side. Also people usually have both standard and deep sockets which would provide you with two sockets in the same size.
I've just found using 3/8" on one side and 1/2" on the other is a common solution for me, so I'd never toss out one size from my general tool kit.
Now for my small in the car repair kit I just have a basic 3/8" set, but I'm not expecting to do any major repairs with that kit. I just have it to fix simple problems away from home.
leoxdeng
London
I bumped into this thread and appreciate it's been a while since the last post - but I had to comment!
What hasn't been mentioned is the usefulness of good old ring spanners - especially the deep offset versions. I got fed up with getting clearance issues with 1/2 ratchet + sockets as they're just too fat - and I don't really want to risk breaking my nice Facom 3/8 with a cheater pipe - so I have slowly and patiently buying on ebay all metric sizes of deep offset ring spanners (all used but good brands - Elora, King **** and Britool here in the UK) - from 10mm to 36mm. The whole range of sizes cost me less than 100 quid to acquire but when I needed one to break free a well hidden bolt - they're worth their weight in gold!
Speaking of drive sizes - I stopped using a cheater pipe over 1/2 breaker bar on lug nuts - I have bought a Gedore 1 inch drive sliding T which is about 3' - and I can just stand on it and break loose any seized lug nuts effortlessly!
Thank you for reading. Namo Amituofo
richfinn
Leeds, Yorkshire, England
Wheel nuts/hub nuts/CV joints
Cylinder head bolts/flywheel bolts/crank bolts
Brake caliper carrier bolts
Steering/suspension bolts
Mostly 1/2" impact sockets on a impact wrench, but I have a breaker bar/long ratchet (for barring engines over) a few extensions and a Torque wrench
Mostly I use 3/8" and 1/4" for everything else, but have some 3/4" for big vans and truck wheel nuts
It depends what the torque spec of a fastener is, or how strong the Loctite!!!
Ralf11
And the sad think is, i don’t even have 1/4 drive for some reason
the reason is that you are not doing trim work on your car(s)
re: 1/2" drive... for cars, you "need" it for lug nuts, and the suspension - I even used 3/4" drive once on a rear axle nut
to save $$ for a DIYer, you can use an adapter on a 3/8" ratchet handle once you have things broken loose - you then only need a 1/2" breaker bar and maybe a torque wrench
BlakeTheCarGuy
Roanoke Virginia
Yep it is for me. I use it on brake caliper mounting bracket bolts, suspension, lots of other stuff and lots of stuff on my dads big rig I just used 1/2 on it yesterday and today. Very important just as important as 1/4 and 3/8.
Semi-hole mechanic
I have a pretty complete set of 1/4 and 1/2 so I rarely use my 3/8 set. Growing up, Dad didn't buy a 3/8 set until the early 80s. He bought a KMart Pro metric set in 3/8 because it covered most of the common metric sizes that were starting to appear on cars and trucks.
bsaint
Manchester, CT
Do you find yourself needing longer handle 1/4 ratchets to make up for the times when you need more leverage, but 1/2 is too big?
With CNC machinery its either something small or something large and engineers design it so you can fit large tools on large fasteners. If a high torque hex nut is m8, 13mm is usually in a 1/2" dr set and a 1/2" drive ratchet will generally fit where that fastener is on our machinery.
nh_yota
Seacoast New Hampshire
I use my 1/2" sockets and ratchets all the time when I work on my Tacoma. They are a must for any suspension or brake work especially in salt/rust areas.
