1/2 impact socket set over 1 1/4?
CobraChevelle
Wisconsin
What are the chances finding a SAE impact set over 1 1/4 without going 3/4 dr?
I will be buying the axle nut socket Set from HF tools sizes 29mm, 30mm, 32mm, 34mm, 35mm, 36mm, 38mm. So maybe I wont need SAE over 1 1/4.
u118224
Northern MI
Most USA industrial and automotive tool lines go up to 1-1/2 inch in 1/2 drive. I purchased mine in regular and deep up to 1-1/2 on E-Bay over time. Mine are mostly Armstrong.
sberry
Brethren, Michigan
Sears big pro sets go to 1 1/4. Sounds like you have what you need, let the store keep it for you till you really need one and for home brew stuff I aint scared to rap a socket of any kind a little with an impact. This is for one off light use with a little care.
Buckgnarly
VT
I just found this set. I was looking at Sunex impact sockets and came across this set. looks like a good deal.
Very happy with mine, I use them on my tractor implements and IR2235. Tekton has a presence on here and are very good with warranty from what I have seen.
Spudland_Dave
Maine
Why?
In the past I got some needed larger sockets (In my case chrome) in 1/2" Drive, mostly because it was what was available locally at Sears...Now I'm going out of my way to go with 3/4" Drive...if there were some resale value on my large 1/2" drive sockets I'd sell them tomorrow and replace them with 3/4" drive in a heartbeat.
It may seem like a great idea to have a 1/2" drive, 36mm socket, but IMHO not a great idea...much better off going with 3/4" drive..
Spudland_Dave
Maine
1.) I don't have a 3/4 impact.
2.) Using 1/2 to 3/4 kills the torque on the impact.
3.) might use it 1 or 2 times a year depending on size
1) I don't either...yet... :(
2) While I cant argue any extension/adaptor/joint saps torque I don't notice a difference. when going UP size...I think the larger/heavier sockets actually work BETTER, basically duplicating some of the power sockets available. I use my 1/2" Drive MAC Edge impact sockets in my 3/8" M18 impact all the time.
3) Same here
Why I quit on 1/2" Drive was when I changed the CV shaft on my accord...1/2" Drive 36mm socket...sheared the drive off my CMan breaker bar, sheared a 3/4"->1/2" adaptor, my impact couldn't do it either...ended up needing to get a 36mm 3/4" drive socket, using my HF Breaker bar and a cheater...no issue.
I'm now even going down the line with 3/4" Drive...just got a 3/4" Drive 19mm socket to deal with the infamous Honda crank bolt i'll be tackling soon...didn't want to waste my time with 1/2" Drive.
sberry
Brethren, Michigan
I have a couple in sized to 1 7/16 in 1/2, there are times on equipment they are the right thing. The original post sonded like a question regarding if it was worth sitting on for occasional work, if you are a shop like me then you got to have a few extra things but just to have them wouldn't unless I actually had a need.
Most auto parts stock every tool needed.
Spudland_Dave
Maine
Get an IR2235 and you will see the need for 1/2 in those bigger sizes.:thumbup:
I dunno...I'm looking into 3/4" Guns now...eying the 2145 or the 2161..or possibly an offshore...going down that road for the big boy stuff and then getting one of the small compact 1/2" guns like a MG3255 or the AWP050C for day to day....stick with my M18 for 3/8"
My mode of thinking is on large sockets like that, there's no need for me to have both Chrome & Impact, Deep And Shallow like I/most people do in 3/8 and 1/2" drive...so from my understanding, the effective torque limit for 1/2" drive is ~850-950 ft/lbs of torque...that's NON-Impact torque.. so if I have to crack off a crazy nut which even a MG725 cant handle, I Then need to bust out the ol breaker bar and cheater pipes, but would be limited to less then 1,000ft/lbs by virtue of the drive not being able to handle any more. Going with 3/4" Drive, you raise the ceiling of effective torque capabilities...I have not sheared off any drives...
Running them in an impact...when I use 3/4" Drive sockets in my 1/2" gun...it hits just as hard, sometimes seems like harder...IMHO it duplicates the power sockets like the 19mm Lisle 77080 socket...increasing the socket mass directs more impact energy to the fastener...3/4" sockets (size for size) are much heavier then their 1/2" counterparts. on impact sockets, Heavy = Good thing.
upstateny918
My Matco/ADV set goes from 5/16ths to 1-1/2" in 1/2" drive. I really am happy with the set.
My 3/4" impact gun is an Aircat th1600, Awesome gun and for under 400 bucks even better!
Vigo
Im not trying to be negative here, but it sounds like what turned you off the 1/2" sockets was the tools you were turning them with, which in your case just weren't particularly strong.
Personally, i've always had terrible luck with breaker bars. At a young age i figured out that my 1/2" craftsman ratchet with a cheater pipe on it was stronger than any breaker bar i'd ever got my hands on. I have done some STUPID stuff with a cheater pipe on a 1/2" cman ratchet and gotten away with it every time. I've broken multiple breaker bars but never sheared the drive off a 1/2" ratchet! Go figure. I still keep that silly old cman ratchet around because of its long-proven cheater pipe performance, even though i have a MUUUCH nicer long-handle flex head 120xp gearwrench to use as an 'actual ratchet'.
And i've had an IR Titanium since 05. Still kicking! I havent been turned off of 1/2" drive yet! If 1000 lb ft is my 200 on a 5ft cheater pipe, i guess i just havent found anything that i couldnt get off like that so far. Mostly automotive, so im sure heavy equipment is a WHOLE other ballgame!
WJD
Rocky Mountains
I have found with the high output 1/2 impacts out today I have had to use 3/4 impacts much less.
The IR 2131 1/2 impact I use and the 'better be sitting down for this' Harbor Freight earth quake or what ever its called 1/2 impact have all but on rare occasions spun the nut or moved the bolt on one inch and larger bolt in size.
Spudland_Dave
Maine
I don't take it as negative at all... I don't think its an issue with the tool in question...in my case the breaker I broke was a Craftsman, which I never felt were "junk"...and when I look at tests such as this Hot Rod test..
http://www.hotrod.com/how-to/1406-half-inch-ratchet-shootout/
Seems to reinforce my theory on +/- 800 ft/lbs being the design limit of the 1/2" drive square.
