bagged89s10
Is anyone using that 1/2" rapid air kit to plumb their garage? I'm thinking abut getting it and using a couple hose reels with it. I also already have air ride fittings which can let me expand the system.
Brand new original RapidAir Complete Master Kit. This is a complete air line piping system for your shop or garage. This air distribution kit is made to install on the wall or inside of it! This kit includes 1/2" outside diameter, 3/8" inside diameter nylon tubing that allows for 60 CFM flow at a 20ft length and 25CFM at 100 ft with a working pressure of 150 PSI. This tubing attaches to aluminum distribution blocks with easy to use push lock fittings. This system is an incredibly easy way to conveniently get an air supply throughout your shop without dragging hoses around. This complete kit is very easy and quick to install!
Specifications:
100 Ft. Of Tubing
Tubing is 1/2" Outside Diameter 3/8" Inside Diameter
Includes Solid Aluminum Professional Looking Distribution Blocks
Includes Push Lock Fittings
Includes Tubing Cutter
Easy To Install
Specifications:
100 Ft. Of Tubing
Easy To Install
