May Pop
II use mine for taking out differential pin bolts. Tight space and can put a deep socket and extension on for a cheater. Comes in handy in the junkyard.
Ron
Ron
I've only come across one bolt that was so tight I felt like it was over-stressing my 1/4" ratchet.
So I just used a 3/8" ratchet, problem solved.
That's cool... except for the 95% of times when you're using 1/4" stuff because that's all that'll fit.
I absolutely LOVE the 8" Matco. The extra length means I don't have to put stupid pressure on it, I have more control when it breaks loose, so fewer busted knuckles. I have the excessively long 15" 3/8 ratchet for the same reason.![]()
If you need a breaker bar for a 1/4", then its either on way too tight, or you should be using a 3/8" instead
This is my opinion as well.
Sent from my SGH-I927 using Tapatalk 2
i suppose i'd consider carrying a mini breaker with sockets as an emergency item in bike tool bag, but I can't think of how that'd be much better than a small adjustable wrench.
If I have a small job and grab my 1/4 kit to go with me, then I have used my breaker bar a bunch. If I am in the shop I wouldn't even remember I have one.
For multiple bolts and speed by hand they are faster than a ratchet.
Not faster than a roto-ratchet, though. That's why it's taken me this long to get one. My roto's always filled that void for me:
Based on your previous posts I believe you own some laundromats, right? I think if I had to work on washing machines any more than I do, then I could see maybe using one from time to time.
Why is there a split down that handle?
They're all that way. You can adjust the tension of the rotating head with that screw on the side, and to remove/replace the head on these things.
Ohhh cool. I always thought it had something to do with spring tension or torque something something something
You are absolutely correct. I agree 100%. I use two hands on them like I am making a fire, when I want to haul ***. The 3/8 snap-on is my favorite ratchet. The 1/4 is nice too. The two hand method is very fast.
I dont get why this is even a debate. This is garage journal, I have three 1/4 breaker bars a Craftsman a Snap On and an SK.
Ratchets,you don't use when bleeding brakes.The brake fluid has some metalic stuff in it that tears up the ratcheting mechanism right up.My Matco tool dealer fixed a customer's ratchet twice.It was the brake fluid doing it,asked the customer if he was using it for bleeding brakes and the answer was yes.I have used my 1/4 breaker bar to break loose certain small driveshaft bolts,will round them off if you don't do this taking them out with an impact.
