1/4 drive 5/8” 6 point deep socket
Old Dude
Who makes one of these? I can find regular ones from Williams etc. Where is a six point deep?
AEAdam
SE PA
That’s pretty big for 1/4”. Might need to use an adapter. Torque on that fastener could be close to the limit of 1/4” drive. Good manufacturers don’t make sockets like that for a reason.
bwringer
Indianapolis
I'm also wondering "why". Most 1/4" drive sets stop at 14mm or 9/16" for very good reasons.
rust in the eye
Chicagoland
I'm also curious about the application here, if there is one aside to have one.
This implies a 7/16" bolt/nut. 1/4" drive tools would be very hard pressed to do these up tight.
LXCam
I can’t believe you veterans missed the obvious..
Because theres a peg..duh!!
Mr Ratchet
For chrome, I have Blue Point in shallow and deep. Both have been used numerous times and will continued to be used. My deep impact is from Proto and the shallow is from someone different, can't think of the name.
Not all 5/8" fasteners are torqued to the max spec. My brother barrowed my chromes along with my SO long breaker bar to remove a starter from a Ford pick up that had clearance issues.
Add Tekton, Williams, and Snap On to the list of "Not Good" manufactures who make 5/8" sockets in 1/4" drive in chrome and/or impacts.
66HertzClone
Long Valley, NJ
Yeah, those empty pegs are bothering me to, I have a Hansen rack for both 6 and 12 point 1/4 drive sockets, missing are the 5/8 shallow and deep on both and the 5/32 deep 12 point. All of my chrome sockets in 1/2, 3/8, and 1/4 drive are in Hansen racks, all pins are filled in each except for the 1/4 drive ones I mentioned
51dueller
Saskatchewan
I used to have a Ultrapro deep and SK USA 5/8 shallow. The broaching on the SK was awful and had manual die grinding on the 1/4 drive hole. I sold them with my old socket collection but I kept the 1/8 SK shallow and deep as they are close enough to the Tekton set.
If you were in Canada you can get Taiwan made one from Gregg's Distributors house brand Procore.
Tchicken
THE Motor City
I've spent too much time trying for find a 1/4" drive deep hand (not impact, as they are too fat to fit) socket to fill a lonely hole on an OLSA socket organizer - but a 5/8 is within the rule I read somewhere that the max at any drive size is 2 1/2 to 3 times the drive/anvil size, if that bit of internet lore is correct 2.5 x .25=.625 inches, or 5/8" ... but most everyone stops their sets at 9/16" ..
LXCam
I profoundly seriously hope that's NOT why we're talking about this. The added pegs on Hanson rails have caused more trouble on this board. The solution are diagonals. Just cut them off and forget about it!
Heresy!
Everyone should own a 20mm 😆
Wamsutta
Amarillo, Texas
Not to derail this thread but. . . . . . . . . . . . . . . . is there a way to 3D print a Hansen tray with whatever pegs you want?
Twisted Sid
CA
What about printing new peg caps that slide over the original ones?
Could make them larger diameter for less movement and put different sizes on them.
willf650
Heresy!
You made me go look at my Hanson tray and I don't have a 20 but do have a 21 and 22 loose. Apparently I got tired of looking at the 20mm peg so I broke it off
What do you do when you have sizes above the pegs?
I must really be lacking as my 1/4" set in the trays stops at 1/2" but the 3 sets I have in blow molded cases do stop at 9/16"
gilbo
That's why you need another tool, a 3D printer. Then you will never have to worry about that again
3D Printed Toolgrid
Tchicken
THE Motor City
The Snap-on (even sans shipping charges) costs more than a whole set of Olsa sockets ...
Guess I need to decide how much that unfilled hole is worth ... or switch to a different organizer
cody1325
Southwest Virginia
Not to derail the thread but, I'd still like to see 1/4 drive or nano/dual drive spark plug sockets.
EXACTLY. For 99% of what I do, the little Kobalt 1/4 drive set in the blue plastic case handles it.
My HF 3/8 General Service set has an adapter that allows me to use 3/8 sockets on a 1/4 ratchet, and it's sold on its own in a pack of adapters. In the meantime, that should allow me to use any of the spare 5/8 plug sockets I have with 1/2 stuff.
AEAdam
SE PA
I really honestly do not understand this thread and the many others like it. Please, someone just read me in.
If you have a need to turn a bolt with a 5/8” head, but you either don’t have room, or don’t need torque, but you want speed, why not use a stubby 3/8” ratchet? If the stubby 3/8” is too big, I’ll concede that maybe a 3/8” anvil in a 1/4” body makes some sense.
At this point, really what exactly is the difference between a 5/8” socket on a 3/8” ratchet, vs a 5/8” deep on a 1/4” ratchet if the ratchets are similar in size?
The only possibility that comes to mind is some sort of maintenance tool kit where you only want a single drive, have no torque issues, and 3/8” sockets would add the need for 3/8” extensions and ratchets etc.
Otherwise I have never understood this fascination with socket sizes beyond the normal range.
Doesn't have to be logical, or realistic. No need, just can't have an open hole..
Similarly, why do I have an Astro 1/4" ratchet that's about 10" long and some other that is 4"? I used a 7.5" Proto at work, and it just fit my hand better than the 17 or so standard length 1/4" ratchets l already owned. So I finally found a longer “not Proto”. Not logical, but nice to use it.
Draftpick1
I had the same issue with looking for a a deep socket to fill out my tray, got a proto impact and took a drill bit and slightly bored out the opening to fit the impact socket.
