That’s a 3/8. I’m looking for a 5/8.
Well Google screwed you n me then. The add that immediately popped up was a 5/8. So I clicked on it n just grabbed the link..That’s a 3/8. I’m looking for a 5/8.
I'm also wondering "why". Most 1/4" drive sets stop at 14mm or 9/16" for very good reasons.That’s pretty big for 1/4”. Might need to use an adapter. Torque on that fastener could be close to the limit of 1/4” drive. Good manufacturers don’t make sockets like that for a reason.
I can’t believe you veterans missed the obvious..I'm also curious about the application here, if there is one aside to have one.
This implies a 7/16" bolt/nut. 1/4" drive tools would be very hard pressed to do these up tight.
Not to derail the thread but, I'd still like to see 1/4 drive or nano/dual drive spark plug sockets.
I profoundly seriously hope that's NOT why we're talking about this. The added pegs on Hanson rails have caused more trouble on this board. The solution are diagonals. Just cut them off and forget about it!
Heresy!I profoundly seriously hope that's NOT why we're talking about this. The added pegs on Hanson rails have caused more trouble on this board. The solution are diagonals. Just cut them off and forget about it!
What about printing new peg caps that slide over the original ones?Not to derail this thread but. . . . . . . . . . . . . . . . is there a way to 3D print a Hansen tray with whatever pegs you want?
Trust but verify.Well Google screwed you n me then. The add that immediately popped up was a 5/8. So I clicked on it n just grabbed the link..
See if I trust those guys again.![]()
You made me go look at my Hanson tray and I don't have a 20 but do have a 21 and 22 loose. Apparently I got tired of looking at the 20mm peg so I broke it offHeresy!
Everyone should own a 20mm![]()
That's why you need another tool, a 3D printer. Then you will never have to worry about that againYou made me go look at my Hanson tray and I don't have a 20 but do have a 21 and 22 loose. Apparently I got tired of looking at the 20mm peg so I broke it off
What do you do when you have sizes above the pegs?
I must really be lacking as my 1/4" set in the trays stops at 1/2" but the 3 sets I have in blow molded cases do stop at 9/16"
Otherwise I have never understood this fascination with socket sizes beyond the normal range.
I had the same issue with looking for a a deep socket to fill out my tray, got a proto impact and took a drill bit and slightly bored out the opening to fit the impact socket.I've spent too much time trying for find a 1/4" drive deep hand (not impact, as they are too fat to fit) socket to fill a lonely hole on an OLSA socket organizer - but a 5/8 is within the rule I read somewhere that the max at any drive size is 2 1/2 to 3 times the drive/anvil size, if that bit of internet lore is correct 2.5 x .25=.625 inches, or 5/8" ... but most everyone stops their sets at 9/16" ..
