1.5" Crowfoot? Other ideas?
Jeff95TA
Pittsburgh, PA
I have 4" square tubing on the base of a structure that needs to be bolted down to a test bed (see attachment). There are 1" hex head bolts that are 1-7/8" in from the edge of the tubing. You can't get a socket and torque wrench in there, and there's more structure above the corner bolts, so I can't put a thru-hole above it for access like the other bolts.
These are Grade 8 bolts that need to be torqued to around 600 lb-ft, so the torque wrench is 3/4" drive.
My thought was a 12-pt box end crowfoot wrench, which is still a close fit. The torque wrench can only swing one direction due to interference with the test bed. An open end crowfoot would have to be moved 60° to the next position on the bolt head, which wouldn't work.
I found a 3/4" drive, 1-1/2" crowfoot from Imperial-Newton, but there's a 20-day lead time. Anyone know any other sources?
Other ideas? An interchangeable head torque wrench is an option, but the only ones big enough for 600 lb-ft are the single setting style that require calibration equipment to set the torque value (vs. a twist handle style).
Any thoughts?
Thanks!
Banjorear
Essex Co., NJ
May seem like a silly response, do you don't have access from the other side or are they sitting in the spot blind?
NUTTSGT
Northern Central Ohio
I forgot to mention that there's no nut. These are threading into tapped holes, so no access from other side.
I guess that rules out welding the nut.
Is there bolt threads sticking out the other side ? Does something attach to those threads ?
or.... The bolts go through the tubing and bolt the frame work down to something else ?
Sorry, I guess I'm just at a loss as to how this project goes together ?
:headscrat
dutchgray
Dorset. England.
If you can't wait 20 days make you own crows foot by cutting up a wrench and welding on a 3/4" socket or the drive end of an extension.
J
Jeff95TA
Pittsburgh, PA
I may suggest something like that. It's at a customer's facility, and I know they have some capabilities there. My only concern is the 600 lb-ft on a fabbed-up tool & injury.
Worst case we scrap the base and use 6x6 tubing.
gungatim
west mich
can you drill an access hole through the tubing above the bolt with a hole saw? re-weld the plug back in if needed?
rlitman
Long Island
600ft#?
with a crowfoot?
the jaws will spread, especially a '12' point
Jaws won't spread on a BOX end like he said.
Oh, and you should shoot the engineer who came up with that corner.
J
Jeff95TA
Pittsburgh, PA
There's structure above the bolt. We're trying to avoid lifting it off because the test equipment will already be mounted.
I was on the fringe of the design, and analyzed the structure for strength, so I'm kind of to blame too since I should have seen this. I've already slapped myself accordingly!
gungatim
west mich
ok then, time to engineer a different approach. like screwing in the bolts and leaving a gap, then using a bolted double wedge that goes underneath that can be tightened to compress through the side to apply the proper force...good luck...
LXCam
Notch the side of the frame adjacent to the open end then if needed weld it back on. Then you can use a torque adapter.
APEowner
Sunny, New Mexico
I hate it when that happens. Can you just weld it to the test bench and then cut it off when you're done? If not I'd go with the custom wrench.
LXCam
Can you change it out to a socket head bolt?, then you could cut down a Allen wrench and then certainly use a torque adapter. They even make socket heads in reduced height which would give you another .100 to .200 of clearance.
This isn't a reduced head, but it only requires a 3/4" driver which would give you plenty of space.
http://www.mcmaster.com/#91251a916/=10akrfq
eddiemeddiem
Yeah, make a special box end adapter for your torque wrench.
Another method would be to use the "turn of the nut method" to rotate it a prescribed amount past hand tight to develop your preload. Once you know the degrees of rotation required, use a slugging wrench or a regular combo wrench.
rlitman
Long Island
Very well. :)
How about using a box wrench, and pulling on it with a dynamometer?
Drill through a cheap wrench at a known distance and install a clevis (drilling that'll be fun)?
