1-man brake bleeding with Mityvac
Schurkey
There are several ways to bleed brakes. Here are some methods I DON'T recommend:
1. Vacuum bleeding. If you aren't pulling air around the bleeder-screw threads, you're pulling air past a rubber seal somewhere--Usually happens with drum-brake wheel cylinders. Vacuum bleeding is best done on small jobs at the wheel cylinder--replacing caliper, replacing brake hose. Major jobs take too long. The last bit of brake bleeding you do will be via gravity, to assure that the wheel cylinder doesn't have a perpetual bubble in it.
2. Phoenix or similar "Reverse Injection" bleeding, using dedicated tooling. The wheel cylinder is designed to be bled in the normal direction. If you don't do a final-bleed OUT the bleeder screw, there will be an air bubble trapped in each wheel cylinder. In addition, the worst, most-contaminated fluid in the system is typically in the old wheel cylinder, pushing contaminated fluid through an ABS system is...expensive. The only time "reverse injection" bleeding makes sense is when the system is completely clean and empty, and you still need to bleed in the normal direction when you're done "reverse bleeding" to eliminate that air pocket in each wheel cylinder. I admit I have "reverse bled" brakes by first filling the caliper with clean fluid, bleeding the normal direction to eliminate an air pocket, then pushing the piston fully into the caliper bore. Be sure there's room in the master cylinder to accept all the fluid without overflowing.
3. 2-person pump. Unless your helper is a Victoria's Secret model, in which case I wouldn't be pumping the brake pedal. There's nothing really wrong with this, it works, and it can be a great parent-child, husband-wife bonding experience. There's reasons to do this that don't include effectiveness. I never have the Victoria's model as a helper.
4. Motive Products or other "garden sprayer" pressure bleeders. Because there's no diaphragm in the pressure vessel to separate the compressed air from the fluid...the first thing a "garden sprayer" pressure bleeder does is to contaminate the fluid with the humidity in the air.
5. Fabricating a "pressure bleeder" using the top of a master cylinder, or a flat plate across the master cylinder so only the fluid in the master cylinder is pressurized. The master cylinder doesn't hold enough volume--you'll be refilling your "pressure chamber" (the master cylinder) every few seconds of bleeding time.
6. "Speed Bleeders" or similar check-valve bleeder screws. By the time you **** with them, you might as well just gravity bleed. I'm not outright opposed to these "special" bleeder screws, like I am to "Reverse Injection" special tools, I just don't see the need for them.
There are two methods of bleeding brakes I recommend. One method for major work, flushing the system, or for work at the master cylinder, and one method for work at the wheels.
7. Real, live, professional-grade pressure bleeder that has a diaphragm to separate the brake fluid from the compressed air, along with the appropriate attachment for your master cylinder. I have a Brannick G300, although mine is old enough that it came with different master cylinder adapters that what is being shown now. I've purchased additional adapters, some of them at a "surplus store", but in general the adapters are expensive, too.
https://www.amazon.com/dp/B000RT8GUK/?tag=atomicindus08-20
Advantage: Bleeding is F-A-S-T and THOROUGH.
Disadvantage: Cost of the equipment, Set-up and Take-Down time.
Perfect for major work or complete system flushes.
It would take almost nothing to weld/braze/epoxy a bleeder screw to an air quick-coupler, which would create an adapter to connect a "real" pressure bleeder to the wheel cylinder bleeder-screw port for those of you who still can't get reverse-injection bleeding out of your thought-process. I haven't bothered. This is not a recommendation, it's an acknowledgement that a real pressure bleeder could be used to reverse-bleed with minimal effort and expense.
8. Gravity bleeding. Crack open a (clean, not plugged) bleeder screw, keep the master cylinder reasonably filled. Fluid drips out of the bleeder screw. Air bubbles are gently removed. I usually tap on the wheel cylinder and brake tubing, and wiggle the brake hose to encourage the tiny air bubbles to detach from the internal surfaces
Advantage: Very little set-up and take-down time. No expensive tooling--drain pan, bleeder-screw wrench, drill bit to clean out the screw, hammer to tap on the cylinder.
Disadvantage: Slower process than pressure bleeding. Not suitable for major work, flushing, or work at the master cylinder. Not real efficient when the master cylinder is located low on the vehicle--Antiques where the master is below the brake pedal, for example.
Perfect for work at the wheels--replacement of wheel cylinder/caliper, and brake hose.
rlitman
Long Island
...7. Real, live, professional-grade pressure bleeder that has a diaphragm to separate the brake fluid from the compressed air, ...
You make a good point. Any pressure bleeder without a diaphragm is fine for one use, but the fluid left in it should be discarded within a short period of time.
You could use a clean extrol tank with a diaphragm to make a pressure bleeder where the fluid could be kept for years at a time, but I couldn't justify the expense. For me, I'll vacuum and gravity bleed to start, and finish with the pedal.
Showkey
"MEMBER EMERITUS"
Wausau WI
One reason vacuum and pressure bleed system are preferred...... is .............stroking the master cylinder ( especially one that has not been serviced regularly) to the bottom of the stroke is a great way to trash the master seals.
Common that master (on an older vehicle) goes out several weeks after a flush when the master has been full stroked.
J
Jason280
Well, I tried the Mityvac method without much success. Never was able to really pull any amount of vacuum, but it was probably due to some user error. Ended up using my old method of a jar of brake fluid and pumping the brake myself, which left me with a pretty firm brake pedal. I was able to test it out, and worked quite well. Still need to do the 2-man method once my assistant is available...oddly enough, the Jeep still has a worn out smiley face sticker on the brake pedal the last time we switched out the rear axle. He was probably 5-6 years old, and I put it there so he would know which pedal to press! ;)
akalian
St. George Utah
You can do it very effectively with the hand held MityVac but the key to making it work is to get a spare bleeder screw and then cut off the pointed end that seals in the brake caliper, add a rubber washer and then fabricate a short piece of plastic tubing to the bleeder end of the screw.
Picture below shows what it looks like. I put together a DIY thread over at ToyotaNation that goes step by step through the entire process of making the complete kit. Maybe a little over the top, but it gets the job done for not a lot of money out of pocket.
http://www.toyotanation.com/forum/1...der-bleed-your-brakes-easy-way-many-pics.html
Evilunclegrimace
Erie Pa
I've done some thing similar. I just drill straight through the bleeder so that the tapered seat can still seal and I don't have to worry about air being pulled around the threads. I attach a hose, vacuum the system and then reinstall the factory bleeder. I can usually bleed a non ABS system in 30 minutes by myself.
kblee27
Singapore
I use mityvac 7201 with the brake bleeding accessory kit.
Never have any problem.
It may not be the "best" method, but if you're a 1-man show, it simply works.
sberry
Brethren, Michigan
I don't have any of them, been at this a while and gravity if it will go or have someone pump a pedal. It may be different in a full time brake shop but for diy sometimes it doesn't pay to have all the extra stuff.
akalian
St. George Utah
I never considered doing that, and it is a much more elegant solution to the one I came up with.
I'm off to the garage to drill a couple holes in some bleeder screws and make up a couple of new pigtails. Great tip.
LEVE
On the Willapa
I've used the MityVac system for about 3 decades without any issues. I've replaced the assembly once after about 17 years of use when the plastic frame cracked. I've not had a problem with sucking air via the bleeders, but then I'm pretty good about using the right size tubing to go over the bleeder.
I've also used speed bleeders, but they're not my favorite way of bleeding brakes.
I also use the pump and hold method, alone, using a cut length of 2X4. It's not quick if you do it alone. I'm getting too old to start jumping up and down so many times to do the bleed job. It was, when I was younger, my favorite way of doing the job. But as I aged I found popped for the MityVac. It made the job physically easier to do.
Now, all my vehicles have Anti-Lock breaks. They're a PITA to bleed properly. Without a way to exercise the system you could find yourself in serious brake bleeding trouble if you let air get into the modulator. That's where my vehicle specific handheld tool comes in... it lets me cycle/activate the modulator on/off and do the job properly without a lot of fuss of muss.
MDK22
Philadelphia, PA
People saying they get air coming in. Did you ever think you may be turning the bleeder screw too far. I normally don't have to move more then an 1/8th inch to be able to start to pull fluid.
Never had an issue unless there was an open somewhere else in the system after the master or obstructions either rusted mounts around hoses narrowing the hoses greatly, falling apart hoses, dirt in system etc.
CJM8515
I honestly prefer the 2 man method, but yea you can mess up the master easily that way. Other preferred methods: Gravity bleed. Or fill a bottle with brake fluid and use hoses. Then put onto caliper and submerge hose in fluid in bottle. Gently pump brakes yourself. No air can enter. But it can be tricky.
