1 piece vs 2 piece bit sockets
03protege
Louisiana
Just wondering what the opinions of these two types of sockets are.
Mainly anyone notice any drawbacks to the 1 piece designs?
jjjrmx5
Cincinnati, OH
One piece tend to be the lower line.
Blue point is mainly a 1 piece bit socket. Snap-On offers 2 piece which means that should you mangle the bit, it can be driven out and repalced and pressed back in (or the holding pin can) and the bit replaced, saving the socket portion.
One of the advantages of buying better tools.
Your wallet and frequence of use will decide your purchase.
Thumper
N.E.Ga
I have found over the years that the 2 piece are stronger than the 1 piece. I have some Lisle sockets and they will take care of most things but if you encounter a tough fastener they will most likely shear off. I have twisted a few off over the years. The 2 piece are higher cost but well worth the money and will let you get the job done. I prefer the 2 piece.
pipsters
USA
Every US made torx and hex socket I own seems to be simply mediocre. I've tried the one and two piece set ups as well. My opinion, Lisle sockets are basically ****. I have a few of their other things, they don't scream quality but they still get the job done. But not their torx stuff.
For torx I have had excellent luck with the Harbor Freight one and two piece designs. For those who work on Volvos you know all about the T45 holding the timing belt tensioner on. The HF one piece T45 with a thin profile ratchet works excellent removing it without stripping it out.
wafrederick
Holton,Mi
Craftsman's torx bit sockets are two piece design,can't get a replacement bit for them.Snap On no longer uses a roll pin to hold the bit in place,the roll pin liked to work itself out.Now a press fit.
buening
Decatur, IL
Just watch the cheaper 2 piece designs. The bit isn't always fitting tightly to the socket portion and always seems to have a bit of play. This is for the roll pin type, not the press fit.
dirtmister16
wisconsin
never had any trouble with either style, but i have seen alot of sheared 1 piece. i have snap on two piece bit sockets, they work great, havn't broken one yet.
