10x16 shed with loft
sublime68charger
SW Wisconsin
How many studs did you miss putting the siding sheets on?
Or did all your measurements stand true and all the nails found home the first time?
Great work
You'll still have the walnut thunk my yard barn under the tree has shingle roof and it's still cer- plunk in the fall.
H
hondakilla98
Oregon
I didn't take into account the fact that, the 10' walls are inside the 16' walls. So I should've started the first studs on the 10' wall at 12.5" and 16" after that.
hpw
what brand is the T1-11 that you are using and how much did you pay a sheet?
H
hondakilla98
Oregon
Roseburg forest products Duratemp 8" shallow groove 5/8" 4'x9'. I paid $26 a sheet for 14 sheets, and $23 for 2 slightly damaged sheets.
hpw
thanks, wished I could find it local to me....looks pretty decent, especially the price.
H
hondakilla98
Oregon
I bought it from a place that sells seconds. I got my 5/8" cdx sheets for $10 each at the same place. Some are better than others, but at the same price as osb it's hard to go wrong.
hpw
so far looks good, wanted to add that it looks like you ran your sub-floor decking(8') the same direction as your floor joists. When you do your roof decking run the grain(8') perpendicular to the rafters.
Zeke
Did you notice his blocking? It may not pass inspection for a dwelling but I find his orientation acceptable if he didn't buy T & G. The only other problem is plywood can be more springy lengthwise. It would have worked out to 5 sheets exactly either way.
H
hondakilla98
Oregon
I'm definitely not doing that kind of bracing on the roof. I'll be running the sheets the proper direction.
H
hondakilla98
Oregon
I haven't had any time to work on it. I've been busy with my new handyman business. My wife picked out some colors and painted them on the shed. Number 2 is the winner.
Here's the shingles I'll be using. Malarkey Northwest XL in natural wood.
H
hondakilla98
Oregon
I cut the wings of each end today.
I also put up my last 9' piece of siding, and finished nailing the sheets that were already up. I picked up silicone and z flashing to finish the ends.
H
hondakilla98
Oregon
My roof plywood is on, gable and rafter trim boards installed, tar paper is on, and the gable end flashing is installed. It's going to rain the next few days, then I can shingle, and install my ridge vent. I'll get some pics up tomorrow.
I wish I'd waited to cut the siding until after the roof sheeting was on. It's 5/8" lower than the roof, instead of even with it.
I put my 1x6 trim on the rafter ends and gables. That left me with a 1 3/8" wide 5/8" deep gap on the ends of my roof. So I ripped some 5/8" plywood into 1 1/4" strips and nailed them in place. That gave me a solid corner to mount my flashing on.
Plywood on.
Ridge vent slot cut.
H
hondakilla98
Oregon
When I install the windows. Since they're going on the outside of the plywood. Should I use 5/4"x4" trim instead of 1"x4"? I'll be using 1"x4" trim on the corners and around the roll up door.
H
hondakilla98
Oregon
I cleaned my cheap windows today. And the free one has stuff in between the glass. It was free, but now I have an opening that's not standard and a crappy looking window. I'll see what replacing the glass will cost vs ordering a window.
H
hondakilla98
Oregon
Pictures of my framing are on page 1 and 2.
I see what you're asking now. I'm not using any.
I have doubled 2x4 sandwiched with 1/2" plywood above and below the window. With 3 cripple studs above and below them. With the proximity of the next two studs, I wasn't worried about jack and trimmer studs.
Here's the door opening.
920kip
Titletown USA
First. Thanks for posting your progress. Looks good.
Second. I am not a carpenter, but... I think the jack studs should be installed on the window openings. And above the header on the door opening. It may keep your door from flexing that header.
Third. Keep up the good work. I built a 12 X 16 four years ago, and then ended up selling the house. I wish I still had that shed. May build another. You sure learn a lot making sawdust.
H
hondakilla98
Oregon
Thanks.
I probably should've run jack studs on the windows but on a shed I'm not worried. As far as the door header is concerned. What difference would 2 more 2x4's make on top? I already have 4 above it now.
I have learned a lot
H
hondakilla98
Oregon
Most of my shingles are on, and I trimmed back the tree. Tomorrow I'll cut the opening in the tar paper for the ridge vent, and install the ridge vent and ridge shingles.
H
hondakilla98
Oregon
I'm almost ready for paint. But the bottom of the shed is dirty. What should I clean it with before I paint? It's Duratemp t1-11
H
hondakilla98
Oregon
It's been a while since my last update. My loft is finished. I used 2x6's and 7/16" strand board(thinner than I wanted, but that's what was available). The main area is 10' wide and 8' deep. The small section is 8' wide, and 30" deep.
Here are some pics.
I would have run a ledger down that wall instead of those little pieces of 2x4, especially under the large portion of the shelf.
You don't want to store anything very heavy on that 8" shelf. Adding another little piece of 2x4 on the stud directly ABOVE those 8" shelf "brackets"would help a lot.
H
hondakilla98
Oregon
How many nails are needed to hold up each 2"x6"? There are 3 16d nails in each 2"x6" and 3 in each 6" section of 2"x4" under the 2"x6". I'm 330lbs and it felt sturdy to me while I was crawling around up there screwing down the sheeting. Obviously I'm not storing engines up there.
The 2"x4" pieces above the 2"x6" seems unnecessary, but I'm sure I have some scraps around.
If you are careful with your load, you will be okay.
If you put a 300 lbs load on that short shelf between 2 studs I can guarantee that after a year or so those 2x6 will droop. Nails are not design to hold shearing load and if the weight is high enough, the wood will split. Again, light loads help.
H
hondakilla98
Oregon
We have different expectations. I'm planning on storing holiday decorations and stuff I never use. None of which is really heavy. If I was going to store car parts in it, I could see there possibly being an issue. As it is now, it's heavier built than anything on the market in my area.
wasfast
San Diego CA
You've done a nice job on the shed. The rain is going to make quite a mess splashing the dirt around the building up onto the siding. Gutters help some although with the tree above, you'll be busy keeping them open. You may consider putting a skirt of 1"-3/4" crush rock around the perimeter, a 3" deep.
You don't state what city but looks like the Willamette Valley somewhere. I lived in Oregon for 50 years, 10 different towns. Enjoying the sun down here these days.
