12 flexible bit holder stuck in drill
BigShotBob
None
It's stuck in there pretty good. Need help
Tried putting it in reverse, pulling, using dykes, hitting it, all nothing. Have no WD40
relicrecoveryspecialist
Alma
Use pliers on the chuck, try to turn it on just a tad, and pull out and then push backwards. Sometimes newer drills do that. I’ve had two Matco’s like that, and had to have the Matco guy come get them unstuck just in case I broke it. You may hold a pair of pliers on the chuck, and hit the plier head where it pops it loose
cstmg8
Pickerington, oh
Looks like an impact? That bit is probably too soft. Did you hold the bit firmly (like not letting it turn at all) while you reversed it? Sounds like it just jammed/wedged.
Sent from my Pixel 3 XL using Tapatalk
Alma
I'm pretty sure that's not a drill chuck. Try pushing in the quick disconnect outer ring.
That’s what I meant as a chuck, quick disconnect just push it in, I’ve used pliers to lay over the top and tapped it on the pliers and got it loose
cderalow
Potomac, MD
Pull up on the knurled ring.
At least that’s how my ryobi works.
tarbellb
Oregon
Ive had a bit get stuck in my older M12 Fuel impact to the point that I sent it in for warranty.
Short of breaking it, I tried everything.
