12-point Driveline Socket Sizes
CobraRed
Looking to get a universal impact extension set that's for driveline 12-point bolts.
Some kits are 4pc with 12mm, 13mm, 3/8" & 1/2" and some kits are like master kits from 8-17mm or whatever.
Was planning on getting the 4pc then I saw a ford intermediate shaft with 10mm 12-point heads. What sizes are out there on driveshafts and the like you've seen?
JradM
Alberta
Sunex 2625 set is an option too. I used that set on my truck (only needed the 12pt 12mm).
2625 has 10mm, 12mm, 13mm, 14mm & 1/2". I think they're for head bolts officially, but sockets are sockets - plus that's another reason you might need them.
geartow
ohio / pa border on I80
Depending on your job requirements, 17mm 6point for Isuzu, 5/16 6point and 5/16 Allen for gm, inverted torx on sprinter vans, 21 mm and 22 for New flange style semi drive lines . Some old 1tons had Torx . 7/16 6 point gm 1 tons. Yes I remove a lot of drivelines. I drive a row truck for a living. 16mm and 18mm for some older izusu.
tamaraw
Not exactly a driveshaft, but older Hondas use 17mm 12pt on the flywheel and pressure plate.
amlv20
CEN-CAL
fords of the last decade have been 10mm and 12mm but the 2020 model year super duties went back to 3/8
ecotec
I have whole sets of 12pt… but I only remember using 12mm shallow and 30mm deep.
Callelle
Depew NY
I have the 4 piece Cornwell set, I mostly use the 1/2" on class 5-8s. I need the new 18mm one that Matco has for the newer Endurant HDs.
