My theory is that 12pt are cheaper to produce due to less metal. .....................
There is less material after the broach cut of a 12pt but a 6pt socket is using the same blank. So they are not cheaper to produce.
I wouldn't sell both sets, and I don't think I'd sell just one set either. Think about it this way, you'll sell it for a lower price than what it'll cost you if you bought them back at a later date.
If you wanna sell them because you feel like you have a lot of the and can spare losing a set, go ahead. Have you divied up the sets to the likely locations you'll want/need a set of sockets? Vehicles, garage, house?
I guess I'm just old.
The first tools I ever used as a kid were my grandfather's. This was in the late 1960's & early 1970's. ALL his sockets were 12-point. A mixture of mostly SK, Herbrand and Mustang.
The first 6-point sockets I ever SAW was around the late 1970's and I remember thinking how cheap that looked. Tie all that in with my 30 years in aviation and if I had to choose, I'd keep the 12-point and let the 6-point go.
I want to do it more for getting rid of clutter. I hate clutter. Can't stand having stuff I won't *ever* use at all.
12pts can also be used on square fasteners, dont forget that its a triple square...
There is no right or wrong to using 12 point or 6 point, the answer is they both work. Yes a 6 point will fit better but everyone and I mean everyone will without a second thought after having trouble undoing a bolt or nut with a socket of either kind they will go to their toolbox grab a wrench and give a good swing to loosen it, 99% of the time that wrench is 12 point.
Thats what I find funny people will debate for years on 12 point or 6 point yet will without thought happily swing on a tight bolt with a 12 point wrench.
This isn't a debate about 6 vs 12...
I wasn't really asking about the 12 pt vs 6 pt debate, I'm more wondering about the prevalence of 12 point SAE bolts. I just haven't come across one ever and was wondering where they were. I know in aviation they are around, and if I were to ever get an A&P I'd just buy another set. The chances of that are around .05% though...
I think the reasoning for the 12 point back then was the low tooth count ratchets. It was a design tradeoff.
I don't know about that. I also inherited an SK "Wayne" ratchet from from my grandfather from about that same time period. I don't know the tooth count, but it's pretty dang fine!
The model # is 42470 if anybody knows anything about those.
You tend to see 12 point metric bolts but I haven't come across any 12 point SAE bolts yet. I don't and won't ever own a larger International Harvester tractor or semi so that kinda stuff won't ever come up.
^^^^this^^^^
and really, only widows and girlie men sell tools.
edit: Thief’s, dumdasses, and guys really desperate for money sell tools too.
I had an application once where I needed to torque a jam nut in a recessed hole on differential cover. The 6pt socket was too big to fit into the hole and could not reach the jam nut ... but the 12pt socket did.
I just watched a video from NG about the Bugatti Veyron, and while it's unlikely any of us will ever see one, the mono-**** is held to the engine cradle with 14 12pt bolts/nuts.
So I guess thats one example of a currently produced vehicle using them exclusively.
Just curious. Outside of aviation where I doubt I will ever be taking apart a jet, is there a legit reason to keep say 12 point 3/8" & 1/2" drive SAE sockets?
The only 12 point bolts I have ever encountered were in metric.
I'm considering selling off the 12 points from my large Craftsman purchase, shallow and deep. Just don't ever see a need for them.
My point was if I didn't have that 12pt socket in the tool box things would not have gone as smoothly as it did ... just saying.You do realize there is no reasonable explanation for 6 point to be larger OD than 12 point? It will vary by manufacturer and perhaps by socket to socket but by design there is no difference.
My theory is that 12pt are cheaper to produce due to less metal. Only 12pt fastener I can think of are ARP rod bolts and head bolts.
as for using 12pts on a 6pt fastener, as long as the fastener is in good shape, the contact will be the same in either 6pt or 12pt for the most part. the 12pt is no more likely to round a fastener, unless its badly corroded or really super soft. that little spot on the flat thats missing on the 12pt socket never contacts a fastener flat, so it doesnt really need to be there.
another point i would like to mention is that all the sockets i have split have been 6pts, and almost all deep. i use 6pts and 12pts interchangeably, no preference unless im dealing with something badly corroded.
WOW! You need to read a little.
A 12pt socket is not the same a tripple square. They have a different angle to them.
Even Snap-on has this posted on thier web site.
A square socket has a 90 degree ange. A double and tripple still have 90 degree angles between corners on the sockets.
A 12 point has 30 degree angles. because there are 360 degrees in a circle and divided byu 12 you come up with a 30 degree angle.
Yes they both have 12 splines but the splines on one are 90 degrees and 30 on the other.
Not saying it might not bight but it alos might do a lot of damage to the fastener.
That is a nother subject for another day how now one know the English language. It is a hoot.
