120/240 appliances
canbug
Just North of Cow Town
A/C unit, hot tub, if you are in the country your water well pump. Most loads that are over 20 amps are possibility using 240Volt. That would be your 4 wire.
Tim.
Stuart in MN
Minneapolis
Tim.
The hot tub may require 120/240vac, but an A/C and a well pump are going to be 240vac only.
I have a walk in cooler most don't have but I cant think of another thing I own besides a dryer and range has 4 wire feed to it.
With all of the electronic controls now a days, the only thing that actually runs on 120V AC on those appliances is the LIGHT BULB !
Brian_WK
NE South Dakota
Most walk-in coolers now have a 120v gfci circuit ran to the inside and a 240v circuit ran to the condensing unit.
Some commercial reach in freezers do as well, others have a transformer for the electronics. Same goes for alot of commercial equipment that requires large heat or cooling loads if you are lucky enough to have it in your home. I once saw a water heater that had a digital lcd screen on it im assuming that had a neutral but never tore into it.
My old dryer was the same way was a 3 wire cord no electronics just buttons and a timer never bothered to look at how they did the light bulb. New drier needed a 4 wire. Checked it out in the wiring diagram only the light bulb and the control board needed 120v (which was again reduced lower and to dc) I removed the light bulb (it was bright enough for me in my laundry room anyways)and put in a transformer to reduce from 240v to 120v.
Problem solved only needed a 3 prong plug then.
Brian
Brian_WK
NE South Dakota
My oven has a fan for the convection side that runs on 120v must have been a deal on them instead of the 240v when they were manufacturing them.
Brian
nh_yota
Seacoast New Hampshire
Submersible well pumps run on 240 and they don't use a neutral but they still require 3 conductor (or 4 conductor with ground) cable from the control box out to the pump. The start capacitor is in the controller and not the pump, so the cable has 3 conductors for start/run/common.
Tim.
Only the hot tub will need a neutral.
Have u ever taken apart a dryer? The motor in many of them is 120v.
My dryer is less than 10yrs old and has that setup.
Beat me to it!
sberry
Brethren, Michigan
Yes from the control box for a well but that's a different animal than a common feed, The one I forgot about was the hot tub, I knew there was something else but couldn't remember. No garage tools though? I got a lot of stuff but cant think of a single place a guy would benefit from capping an extra wire.
Norcal
In my own shop the only machine that could use a neutral is a 1976 Rockwell 20" wood/ metal bandsaw, because a extra blade welder is 120 volts. In my opinion, this is a rare situation, because a control transformer takes care of 120 volt power for the starter & light, existing welder is 240V it just does not work...
Other then hot tubs, clothes dryers, ranges/ cooking equipment it's wasting money to run a unneeded neutral.
Alchymist
Central PA
My wood shaper has either 120 or 240 motor option, and I run it on 240. Unfortunately the power feeder is 120 volts. Only options are to convert back to 120 on the main motor, add a step down transformer for the feeder, or run feeder from a separate 120 outlet.
Whats the FLC?
Alchymist
Central PA
Whats the FLC?
Spec sheet says 12.5 @120V for shaper, and 1.2 for feeder. Would be almost 14 on 120 volts, doable on a 20 amp circuit I guess. However, a transformer for the feeder would bring the 240 Volt draw to just under 7 amps. Have some transformers salted away, just never got around to doing anything about it. :headscrat
