12v infinium cordless tools, who makes them?
Mastermind
Ypsilanti, MI
Saw the same ratchet in the cornwell flyer, so someone makes these outside the trucks. Also does anyone know if the 16v and 12v are interchangeable like snappys 7.2/14.4?
efb16acrx
professional tool products. the cornwell ratchet i think is the older 10.8 non variable speed ratchet. With the 1/4 ratchets, the power seems pretty much the same between the older and newer ratchets, with either battery. 12 volts have the battery gauge, and mine are the 2 vs the 1.5 amp hour batteries. The 16v batteries don't interchange with the 10.8 or the 12 unless you grind off 2 tabs on the battery. I haven't done that with mine because I don't see the need, plus the 16v stuff is still under warranty. In the case of the 3/8 ratchets, the 16v completely blows the 12v away.
Monte
Germany
Techway www.techway.com.tw
Skin
Boston
