12x16 post barn type shop, maybe.
Erevojoe
Shelby co Alabama
Ok, I could spend hours explaining why or just skip to the point. I live on my wife's family property and it doesn't look like we will be moving any time soon. I assure u it's not cause I don't work or cause I'm hooked on meth. Before I moved here I supported myself very well and worked for a Fortune 500 company. We were in Florida and I was a special test mechanic for a major motorcycle manufacture. I took a diffent job with the e same company to move back to Alabama so my wife (and kid on the way) could have a little more time with her parents (of whom one had very little time to live). While here,the economy collapsed and the company layed most people off and moved out of Alabama. Since then, it's been hard times. I took a job at the local oil change cause it paid better than wrenching on bikes. It's a shame but I can make more money outside of the motorcycle world than in.
Anyway, like I said, not going to kill time explaining :lol_hitti
I've been living with a very small shop that is an I closed porch build off a little portable building for about 8 years and I've out grown it, the loose brick flooring just can't handle the 600lbs lathe and its packed so full I have to drag the band saw outside if I want o use anything in there. Since my father in law is still ailve( 10 years after being given 2 years to live) he has been opposed to be increasing the size or building something else. After i spent most of this year rebuilding his farm equipment for free(I wouldn't have charged him even if we didn't live here) I think he has figered out we are here to help him not cause we can't live alone. We pay rent and utilities after all. He changed his mind.
Now I decided a few years back to just walk away from motorcycles cause Alabama doesn't pay well. My first job as an entry level tech in 1997 paid $19.50 an hour in Texas, in 2010 the local shop said they pay 12:50. Shameful.
But, every person I run into hates there mechanic and would love to find a professional so I'm looking at starting up part time, if I can build a building. Something that doesn't have to live forever. If I'm successful enough, I'll ind an actual shop to rent, if I'm not making enough money to quit my day job, then it's over. I don't know if I'll ever own this property or not. Oh and one other thing, my son has a more serious version of the asgburger than myself and as he gets older it appears he might not be going to college and branching out on his own so I need a trade I can teach him and help him get started before I pass away. Blaa blaa blaa, what's this got to do with a building? Nothing, let's move on....
Plan was to put up 4x4x10 posts at eight foot spacing. Total building 12x16, basic flat roof with enough angle to keep the water off it. 4" thick slab. Outside of walls covered with 11/32 pine sheet. Basic 2x4 framing with anchored sill plate (treated) metal roofing. My stepdad family builts metal buildings (like Walmart) so I grew up working concrete and have some building experience, but not an expert by any means. But I just realized that pole barn poles are set 4' deep. That's going to put a real kink in my budget and take more than I've got to dig. So here is the question.
If I'm anchoring to a slab (the footers of the slab will be 6" deeper) do I even need poles at the corners and middle of each wall? Or at least since I'm anchoring the walls, can I get away with 20" depth of the poles, I was going to set them first in concrete and then come back and lay the slab.
I've heard that the slap shouldn't touch the poles and I've heard that u want the poles in the slab.
Either way, I know this is is a little bit under engineered, but I've got to have the slab poured before the weather gets cold and I'd like to have the shop "open by appointment only" by the time people start dusting off the bikes next spring. Budget is so tight, u don't even want to know. I'm buying parts as overtime clears the bank. Personal Motorcycles are for sale at this point. Oh and last point. No building code out here. Atleast for land owners building non lived in stuff. A contractor building a new house, I'm sure someone has to get paid for a blueprint and inspections and permits...
Cyberbear
California
Just keep it simple: pour a slab and footings, use stud walls and ceiling joists to support above storage loads and you're about ready to go after electrical. You know best about any weather issues there, but use at least a 5:12 pitch roof. There is little to be gained by using post and beam construction.
Ben Jamin
Tampa Bay
I agree w Cyberbear. A 5:12 pitch or a gambrell roof will give you much better weather protection and much needed ventilation. Good luck
E
Erevojoe
Shelby co Alabama
Thanks for the suggestions and direction. That's kind of what I was leaning towards. I got tunnel vision with regard to post barns cause that what most everything around here seams to be. After looking into conventional wood framing a little more it just didn't make sense that I needed to add more things that could move around and cause cracks or warping.
Another hurdle is finding an in ground single cylinder motorcycle lift that doesn't cost $5k. Looks like I'll be casting the 6" hole in the slab and just filling it with a wood plug for now. I'm a little short for pushing large bikes up onto table lifts. No big deal when I was 21 but it get harder with age. I just used a regular table lift with a 10(maybe 8") atv extension on each side, but I still had someone to lock the wheel clamp. I'm thinking I can set up a remote controlled air valve with an attiny85 circuit or maybe spend the extra $5 and just get a prebuilt Arduino.
Firebrick43
West central Indiana
Never seen a motorcycle post lift. But as cheap as table lifts are why not just form in the concrete a recess the height of the collapsed table so the top is flush with the surrounding concrete when down?
KEH
Friend(now deceased) built a larger shop like that, with studs on treated board on concrete. Based on observation, and being in about the same termite zone as AL (SC) I would think of laying a run of concrete blocks to put the treated footer on. That would also keep the siding above the splash level also. Whatever you do I would Arrange for good drainage on all sides. Good luck.
KEH
kbs2244
The cost advantage of post and beam building comes from the lack of foundation cost.
You can even build with a dirt floor if you like.
Since you need a concrete floor anyway, stick building on a slab would be the way to go.
E
Erevojoe
Shelby co Alabama
A single cylinder bike lift is exactly like it sounds. It's a 6" air over hydro cylinder with a 12" metal plate on top of it. Sticks about 1.5" above the floor. I'd post link but I haven't found the manufacture I used to use yet.
TractorJeff
Elkhorn, WI
Go 16 by 20! Its 4 feet more each way so it will be an additional wall panel cost. It will add cost to the roof project but if you have machines like you stated. (Saw/Lathe) Then you will need the space as business grows. Trust me I worked in a small building for years!
E
Erevojoe
Shelby co Alabama
I can't, any further in one direction and I run into an old concrete storm shelter and the other direction I start blocking off sections of the yard. Wish I could, but I'm over moon about getting this much. I've spent the last eight years searching for tools and stuff cause I'm so cramped I can't organize or even move in the shop I've got now. However, if I can get this thing off the ground and prove I know what I'm doing, I might have a lot more support. My wife's family has a lot of connections in this area.
