140KW Generator-Mystery Diodes
RPH
Michigan Thumb
Look for stud mounted. We used them in the induction generators. They do have both common anode or cathode. Check your old ones first for conduction. The won’t survive the exchange.
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
There are two identical sets of diodes. One set with cathode to the body/threaded part and one set with anode to the common threaded part.
As long as you replace with modern diodes of the same or bigger physical size and rated for 400 V you will be OK.
As long as you can find ONE healthy diode and let a sparky determine anode or cathode to body/thread you will be OK.
All you need is a simple DVM with diode measuring setting and maybe you can even find a tutorioal on u-tube?
VDR was common in the old days , since peak voltage could destroy the diodes. With modern diodes, I believe you can remove th VDR.
Good luck
Ola
RPH
Michigan Thumb
Good luck
Ola
Nice to see you chime in here. Yes, the varistors do have a habit of going bang. We removed them from the smaller induction units due to the 480 vac going high. At Europe’s 400 vac service it worked but you are correct that it’s not absolutely required. Typically if the varistor is in one piece and no char marks around the area we trusted them to be good. Ours always obliterated themselves and left the big carbon mark.
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
RPH.
Thanks.
From what I think I can see, the varistor sits between + and - on the output from the 6 diode- three phase- full wave bridge rectifier magnetizing winding that feeds the field in the main generator?
Ola
RPH
Michigan Thumb
RPH.
Thanks.
Ola
You are correct on the varistor and diodes from what I can see. I’d like to see the complete unit. Gets boring now that I’m retired. I miss the big power and problems it presented.
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
Me too, retired from large electrical power system engineering at the early age of 75!
Biggest generators I made system calculations for was 1667 MVA units at two upgraded nuclear power stations.
Excitation there was 1,3 kV and att max 9500 A.
Output voltage 25,2 kV FLA 38500 A. Worst short circuit power 965 kA.
The most demanding and time consuming calculation was the subsynchronuos stability.
Try to keep my brain in order by repairing old car radios!
Ola
RPH
Michigan Thumb
Company I worked for was based in Skien, Norway. Loved going over for training. I could live over there. My kind of forests.
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
The pics from the OP shows serious corrosion damage to several different metals in the rectifier assembly.
I think the OP needs to inspect the entire generator for corrosion on all metal parts and find out the root cause of the corrosion and remedy that.
Ola
