15/32 Drive Snap-On? your thought’s or knowledge
thehorse13
Jefferson County, WV
I've never heard of 15/32 drive. The typical odd ball drive sizes that you hear about are 9/32, 5/8 and 7/16.
I took a look through a few Snap-On catalogs from the mid 1920s. I can't find any reference to 15/32.
ecotec
The weird drive sizes were probably to drastically reduce (you cannot stop it, people are garbage) theft. If you steal a weird drive socket, you need the weird drive ratchet...
Mintgrun
Kingston, Wa.
You could also check it with one of these and a dial caliper.
Although you might not need that tool, since dial calipers usually have a notch on the ID side that would clear the little hammered lip.
Farmer J.
UK, Cornwall/Hertfordshire.
The interior of the square drive hole looks rough, unworn and unfinished.
IDK but the square drive holes in sockets normally look like they are broached or at least finished to exact size and also have those little recess dimples for the springy ball to go in to, or at least a hole through one side of the socket.
Has this socket ever been used? It looks to me like one where the stage of finishing the inside of the square drive hole was missed out in the manufacturing.
It's a 8 point, for driving a square fastener. Likely nobody needed it anyway!
Ricky Joe
Roanoke, Va.
I am filing the opening to my Snap-On Chrysler ball joint socket as we speak. It doesn’t look buggered, but the ratchet or extension doesn’t fit. It happens.
...the square drive holes in sockets normally look like they are broached or at least finished to exact size and also have those little recess dimples for the springy ball to go in to, or at least a hole through one side of the socket.
J, this socket is from the early 20s, when they were cold broached, which could be ugly inside, with no detent ball.
...but the ratchet or extension doesn’t fit. It happens.
It certainly does. The opposite happens, too. I'm sure we all have a vintage handle with a drive stud that just won't fit all sockets. Just a tad too large, seemingly somehow mysteriously deformed or never quite right.
Walkers
Cave Creek Az
That appears to be an 8 point (square nut) socket. What was the tapered square drive, like used for square drive drills, called? I wonder it that is what was supposed to drive that.
Snap-on was very late to switch from cold-broaching to hot-broaching. Just before WWII. In contrast, Duro-Chrome switched in 1935, Herbrand in 1937. That's why there's a ledge and a recess under the broaching and those chatter bumps between the points.
I will have to read up about the hot and cold broaching thing. I don't have any 1920's era sockets, just the older pressed steel ones and more modern WW2 ones.
This innovation occurred precisely in between! Early hot-forged sockets were like solid little plugs, left to cool, then machined, including the nut-engaging openings. The scalloped openings were literally cut out. Later hot-forged sockets were put into a retainer and pilot when they were still hot and a hot, scalloped-shaped broach was pressed inside, displacing the molten steel material more cleanly. Manufacturers who were fond of proclaiming the benefits of the process printed some handy pages in their catalogs. Below is from page 22 in the Duro-Chrome 1940 catalog. Herbrand does a very similar comparison in their 1937 catalog.
The chip marks are usually visible on older cold broached sockets, whereas the hot broached usually have a nice roll of metal at the bottom.
Lesserstore
Texas
I've got a few that seem to be hybrids I think. Like this 1960s-70s SK 1/4" drive 1/4" socket with rough walls, but with a ring of displaced metal.
As for hot broaching, it seems that most US manufacturers went back to cold broaching, forging, extrusion, formed, etc. by the 1980s. Wright and Proto/MAC are still hot forged, but they say nothing about the broaching.
