Is there so available space in the main breaker box to add another circuit ?
Could be original to the house - 1979. I bought it in 2007.the small appliance branch circuits in the kitchen should not have anything else on it except kitchen circuits.
how long ago did this "electrician" wire this?
Thanks Nuttsgt, When I choose an alternative, if I pick a new circuit I'll have to have an electrician make that call.Is there so available space in the main breaker box to add another circuit ?
Yeah you can't trust a nice couple! /s. He rented it to a seemingly nice couple who later turned out to be a front for a group of men and women who were into motorcycles.
Who cares if they are rebuilding engines in the living room. A few members here have washed parts in the dishwasher. I can understand eviction because of the oil stains.He evicted them after among other things, it became evident that they had rebuilt a Harley engine in the dining room and left black oil stains on the original oak flooring.
My living room runs on a 15 amp breaker. Occasionally There's too much current and the breaker trips as normal.
I would like to change it to a 20 amp breaker. I assume that it's wired in 14 gauge. To be safe would the wiring need to changed to 12 gauge?
Are there any other alternatives to upgrading to a 20 amp breaker?
Thanks for any insight,
Mike
Job security for some of us.
I can't believe no one has figured out how to make a breaker trip (internally) to a safe position regardless of what the handle is doing
any modern breaker will trip even if it is tied like shown.I can't believe no one has figured out how to make a breaker trip (internally) to a safe position regardless of what the handle is doing
I only posted that picture for a laugh
job security for whom? the fire dept? why? because you think it wont trip? incorrect. breakers can trip regardless of their handles being held in a certain positionJob security for some of us.
We have the breaker at the volunteer warehouse tied with a clamp ( purpose made) that powers the alarm, phone , internet so no one can inadvertently shut it off, but it will trip if an overcurrent is sensed
Yes, I thought the same.I only posted that picture for a laugh![]()
See above.... My comment was in jest as I wish nobody's house to burn down...We've seen plenty of stuff done and ask ourselves, why has this not burned ?job security for whom? the fire dept? why? because you think it wont trip? incorrect. breakers can trip regardless of their handles being held in a certain position
Yes, this is usually what we see around here or something similar.
The NEC code requirement has been a minimum of two 20A small appliance circuits for many, many decades.A friend of mine is doing a kitchen reno. He mentioned that the standard for kitchens is now 20 amp circuits. With only 2 outlets per 12 gauge run. At least for him, he has relatively easy access for recabling.
poster is in Canada, where we used 15 amp splits until GFI was mandated . in my opinion the 15 amp split is a better . 20 amp is very easily popped with 2 appliances .The NEC code requirement has been a minimum of two 20A small appliance circuits for many, many decades.
No reason you can’t use 20a splits, though. Just need a 2 pole gfci. Sensible outlet placement goes a long way, though. I have never had a modern kitchen where we tripped breakers.poster is in Canada, where we used 15 amp splits until GFI was mandated . in my opinion the 15 amp split is a better . 20 amp is very easily popped with 2 appliances .
Single recps. need to be rated for the full 20A. A duplex can be 15A.Yes, you need to get that load on a dedicated kitchen circuit. IOW, get the living room off the kitchen circuit. You could try a new 15A breaker, as it is possible that yours maybe tripping early due to continuous use right at the limit. But even if that works, it still needs to be fixed correctly. And, both kitchen circuits should be 20A, breaker and wire, but recepts are fine at 15a.
I think you made a wrong turn at East Podunk.East wall which is pretty much toolage wall is to get a 20 amp 110 (12gauge) at 36” high along with one dedicated 30amp outlet to go with another 220 outlet at the back corner for another compressor down the road.
West wall and header wall is to keep the 15 amp there but with extension boxes to run conduit for a couple more outlets in between the 2 that currently exist on those walls. I never use more than one plug per circuit anyways, just want options of where I plug into.
Back in 1993 we moved into a lake cottage in WI. Small place, about 900sqft, with a 60A panel with screw fuses. Built around 1910.Using pennies has become a distant folklore, too.
The coffee maker is in the kitchen, but shares the living room circuit. There have been quite a few comments about this peculiar arrangement.Why is the coffee maker in the living room in the first place?
That's the way it was wired when I bought the house in 2007. Go figure.Why is the coffee maker in the living room in the first place?
Is the coffee maker physically in the kitchen or physically in the living room?That's the way it was wired when I bought the house in 2007. Go figure.
Why does that matter?Is the coffee maker physically in the kitchen or physically in the living room?
But regardless, this was already answered in post 17
It was mentioned two posts above yours.Because it seemed to be. Question and I wasn't scrolling back to something I read 2 weeks ago at 3am
So it's in the kitchen but the kitchen circuit is shared with the living room.
I saw a post asking why it was in the living room, and OP responded that's the way it's always been.It was mentioned two posts above yours.
For someone that hands out a big ration of **** to people for not reading threads when responding and for asking irrelevant questions, this feels odd
I've succeeded!Turns out it's in the kitchen, as stated over a week ago. You got me, my whole world has come crashing down around me.
