15 HP Single Phase Motor?
nadogail
Coronado, CA
I never knew they existed...
https://www.ebay.com/itm/Baldor-15H...e=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
The largest single phase motor I thought was available was 10 HP. I checked FL amps on Baldor's site, shows 66 on 208v.
There are a lot of things in this world that have existed for years and I am slowly becoming aware of.
Not everyone who needs a large motor has three phase power available to them; so they find a way to work with whatever is available.
Sleeper
300lbs lol. 120lbs heavier than my 10hp single phase
I would believe that, it’s got to be every bit of 300lbs, I wouldn’t even try to lift this old girl. The 16HP is on the left and that’s a 7.5HP next to it on the right.
Sidestep
Calgary
We see a few of them out here on the Canadian prairies.
Farmers use them to drive grain augurs.
I've got one driving my Quincy 5120, farmer I got it off used two of them, running off generators, to drive a big augur before going to 3 phase.
230V - 60A. I try not to have it kick in while I'm welding.
Here's another farmer selling two of them for CDN$1K - $500ea probably worth that in scrap lol. https://www.kijiji.ca/v-view-details.html?adId=1522870186
Stuart in MN
Minneapolis
If you live in a residential area, the power company won't like it if you try to use one (or your neighbors, when their lights dim every time the thing starts.)
TractorJeff
Elkhorn, WI
20 years ago, a guy gave me a single phase induction motor that was 120 volt only 110 on the nameplate. I remember it being 50 amps on the nameplate or something crazy like that???? I moved soon after and the Scrap Buyer took it when He bought all the Fab scrap (treasure pile). If it had been easy to move I would have kept it for a conversation piece!
Bert_
NW Iowa
They aren't uncommon around here. Biggest common single phase ones I have wired are 17hp axial fans in grain dryers. The rated current is about 78A on those. Normally feed them with a 125-150A breaker.
Used to be common to see legs or blowers with (2) 10 or 15hp single phase motors running it. Now that vfds are reasonable we normally put a 3-phase motor on and feed the vfd single phase input.
A couple weeks ago I wired a 50hp blower up with a vfd fed single phase.
