kmoon
If you are looking for a tool box strictly tool box check them out best money I spent.
i had posted this previously on a thread....
a set of swivel head metric sockets, plus a 36mm socket, a 32mm wrench
semi deep impact sockets
short and deepwell sockets for 1/4, 3/8, and 1/2
all torx and E-torx sockets
allen head sockets
basic set of combination wrenches, basic set of from 8mm up to 19 (obviously it's good to have the larger size too)
oil filter housing sockets
extensions for all 3 drive sizes. adapters to go up and down all drive sizes. swivels for all drive sizes
my advise is anything 1/2" drive you buy, go ahead and get it as an impact or industrial finish type, so you can use it all with an air gun
a good 72+ tooth ratchet for 3/8" and 1/4" drive. swivel head is nice
the best air gun you can afford
a whiz-wheel, angle or straight is fine. probably angle would be best though
a good screwdriver set, including phillips, flathead, and torx. you don't need a gazillion of them, just a nice set of them. i have used my ratcheting screwdriver alot with the bits i have, comes in handy alot.
a good set of mallots, brass hammer, and a good weight metal hammer. ball peen preferred.
a good set of drill bits, not used often but when you need it it's nice to have.
breaker bar and torque wrench(es), and a good prybar set(striking).
A good Fluke 88 (and knowing how to use it), will be your best friend.
get a set of wheel hangers, they make life much easier.
torch is great for loosening rusted bolts
Ratcheting box end wrenches up to 24mm - this is a must
Vice grips/pliers
duck tape... zip ties
Slide hammer kit
ohhh and 6 point... don't do 12 point
Fan Clutch Tools
Roll Cart
electric/battery/pneumatic screwdriver/drill
air hammer
Radiator hose pics
Hose pinch off pliers
easy out
tap and die set
Exhaust Donut Tool
Long HD Dykes
hood prop
trim tools
vacuum brake bleeder
crowfeet set
ratcheting screwdriver set
brass drifts
chisels and files
i'm tired of typing but wait theres more!
and again.... in spite of the many comments.... DON'T BUY A BOX
You have one already, buy tools, tools make money, you'll have time later to buy a box
allen head sockets
Vice grips/pliers
Slide hammer kit
Fan Clutch Tools
Roll Cart
air hammer
Radiator hose pics
easy out
tap and die set
Exhaust Donut Tool
Long HD Dykes
hood prop
trim tools
crowfeet set
brass drifts
chisels and files
