18 months later.....
AZ Glen
Scottsdale, AZ
I kind of forgot about this board, I came over again looking for compressor info.
Here are some updates from the original start:
To current pics.
The idea was turn the driveway into.....not a driveway, but a patio area in front of the shop.
Thanks for the compressor info....that was a great thread.
ilikebeer
SW Ohio
I like the old school Miller Beer poster.
In that last picture is that just a bench? I've never seen rock stacked that way but, it's cool looking.
A
AZ Glen
Scottsdale, AZ
Yes, its a steel frame, filled with river rock, commonly called a gabion wall. they are used a lot for decoration in Arizona. The concrete on top still needs to be acid stained.
Quiksilver
Loveland, OH
AZ Glen- I just wanted to let you know that you have left the story untold. I can tell by the hot rod that you use the machining equipment for hobby, but is your shop for use in a business or hobby only?
Next would be the absence of dimensions for the shop length, width, height? Door dimensions?
Construction type? Just from what I have seen on this website I would guess that the construction type is that of a miracle truss? Do you have any framing pictures?
On another note I am extremely jealous. I can only imagine having that much equipment ready for use at any time. By the way, the hot rod looks like a killer project, and the benches, are those just built out of angle iron and steel mesh?
Sorry about all of the questions, but you have just struck my curiosity. Great looking shop you have.
A
AZ Glen
Scottsdale, AZ
No problem...I posted a lot of pics during the initial build. it is 2x6 construction, walls are 9'6" high, the trusses are scissor truss, 25x30 is the footprint, the door is 8x14
the bench by the fire pit is made of 2x2 post, the mesh is 1/4" dia., and enclosed using 2x2 posts and boxed using angle iron, then the concrete top was poured in on top.
While it was nice to have a shop, it was nice to keep the wife happy by decorating the back yard and making the driveway more like an extension of the house patio.
The VMC is new and will be used to mass produce items to support my habit www.hotrodsbyglen.com
Quiksilver
Loveland, OH
Thanks for all of the info. Once again, the shop looks great. I like the ceiling design, is that just to set the fan up higher out of the way?
Thanks for the info on the bench also, I will add that to my list of things to build once we get a house.
rickairmedic
louisville ,Ky
Glen I see on your sight El Polacko and the guys did the chassis on your A bone looks good they do great work . They are desighning alot of stuff for Slick 60's Ford trucks right now as well.
Rick
rickairmedic
louisville ,Ky
Steve is a member of my truck club Slick 60's and although everybody gives him heck over the engine choice in his unibody ( they are big on ford in a ford ) :D they still respect how nice his truck has turned out and we even had one member who worked in the HVAC industry who had a mid life crisis and moved across country to go to work with him Dave seems happy as a clam out there doing what he enjoys to pay the bills .I do like your garage by the way and I may end up stealing the bench idea outside that looks sharp.
Rick
A
AZ Glen
Scottsdale, AZ
were still working on the landscaping. I am going to make some palm trees out of steel.
The base of the tree will be made with clusters of rebar tied together vertically, then the leaves of the palm tree will be made using sheets of copper, I plan to cut the leaves with the plasma cutter so they have a rough edge. Once everything is bent up to look natural, it should finish off nice. One between each gas pump.
rickairmedic
louisville ,Ky
Glen are you planning to leave the pumps in their natural patina or restore them at some point the palm trees sound kewl as well.
Rick
A
AZ Glen
Scottsdale, AZ
Just let them rust.....the bench will get a nice rust patina as it gets a year on it, and the palm trees will rust also.
Down Under Bloke
Top End NT Australia
Is that the first flat screen in a garage on this site, sure won’t be the last!
I like the old bowsers you have; I grew up around a servo in the 70’s so remember them from my childhood.
