1935 Gas Station Resurrection
shortykorte
Tallahassee, Fl
Thanks for sharing the pictures. I do like looking at the old buildings. We still have a lot of stations here but most are covered in various materials to make them look like a regular building.
H
HD FLHX
Central Iowa
There has been some work being done to the building just no big milestones to show off. The weather hasn't cooperated very well recently..when its not raining its been cold. Not good if your trying to get outside paint work done. I was able to get the the front doors stripped, a few areas repaired and the doors into primer over the last couple days. Of course it rained today so paint will have to wait till tomorrow. I did find it interesting while stripping off the old paint that at some point the door jambs were painted yellow. No signs of yellow on the doors though. The old doors were just soaking up the primer so I ended up putting two coats on.
A neat addition to accompany the Prestone anti freeze can. It's an original 1944 Prestone magazine ad
rmalkow2
Brighton, MI
That Prestone Ad is an awesome find. Looks to be in great condition too for such an old piece of paper.
The doors are looking great so far. Will the bottom half panels get the same dark green as the peak area above the doors?
pitterpat
Indianapolis
That looks like an APCO station. The one thing that kindof confuses me is the price of gas they have displayed. 15 cent sounds to cheap for the time. I think in the mid 70's, 73 or 74 is when they had the big gas embargo, and everywhere was almost ration the amount of gas you could by. Man that had to be a big change in automotive history. NO more HIGH PERFORMANCE factory cars, all the big gas guzzling whales became extinct. Japanese imports were the new Chevrolets.:sad:
I remember the price being more around 50 to 70 cents a gal that time. Lucky me was just at the driving age. I bought my first car, a 1962 4 door 6cyl, 3 on the tree. It was owned by a little old lady just up the street from me, been sitting in a one car garage and shelled out $250.00 of hard earned Taco Tico pay. Taco Tico, along with Pizza Hut, and White Castle got there start in Wichita, Kansas.:thumbup::thumbup::thumbup:
Oh also the sign looks to be a two sided plastic sign:sad:
15 cent is about the right price for gas in those years. I started driving in 76 and the gas was about $ .50 in 76 -78, I remember because I could fill up my 69 Rambler for $5.00 (which was half my allowance then).
bp460
Chicagoland
Fantastic work! Thank you for taking the time to document and share your project. What type of filler did you use on the front doors before priming?
Cheers,
Brad
H
HD FLHX
Central Iowa
Cheers,
Brad
I intended to snap a couple pics of the cans while I was at the building today. I used two products both were JB Weld brand. The first was a wood restorer which you just brush on and let dry then followed by wood filler which was basically bondo.
H
HD FLHX
Central Iowa
Here are the freshly painted front doors with new stainless kick plates. I still need to pick up a couple new door knobs and finish stripping the old paint off the one block on the left side of the east door. I know they are called something, but it escapes me at the moment.
I'm going to use these blocks to cover the holes left when the old lights by the west door were removed.
Figured it would be a fitting day to pull the Econoline out and park it out front. It is a real former military truck used at Fort Rucker to support the 1st aviation brigade
The concrete work out front is scheduled to be done sometime in June. The pad will be poured between the front doors for the gas pumps to set on and the old flower bed on the corner will be dug out and filled with concrete so its even with the brick drive and sidewalk. I'm also having them fix the small section of sidewalk that was busted out when the power company set a new pole last summer.
In case anybody was wondering the basket is doing well in its new forever home
Loose Ctrl
Upstate SC
That looks real good.
I'm digging the old aviation Econoline. I wouldn't mind having a cargo version with the old V4 and manual on the column. The early model Econolines are extremely rare down here.
shortykorte
Tallahassee, Fl
Yay! The basket lives on!!!
Very fitting displaying the truck this weekend, thank you. Ft. Rucker is just up the road from me.
Building is beautiful as ever. The picture with Econoline should be one of the towns featured photos. Looks like a beautiful day.
rmalkow2
Brighton, MI
Great transformation you've made so far. The frontage looks awesome with a painted wall, doors, trim, etc. Quite an improvement not only for your use but for the town as well.
H
HD FLHX
Central Iowa
Still finishing up little things around the building. I spent part of yesterday prepping and painting one of the interior brick dividing walls. I chipped all the old construction adhesive off then gave it a couple coats of flat white to clean things up. Inside the lift bay will get the same treatment.
Blocks covering the old light fixture holes on the front of the building installed.
The sign I had made arrived this week to a bit of disappointment. Typically most of the signs they make are distressed. I had asked for a special size and it to be non-distressed. Because of the size change the layout had to be changed a bit. We exchanged several emails back and forth on the sign layout and with so much focus on the layout the non-distressed part was overlooked. She is going to make another one to make it right.
Old Auto-Lite Batteries give a way I came across while killing some time on ebay.
The bed of the F100 making the move. About to get back to work on it.
Turbo1Ton
Holy cow! Finally finished this thread after finding it last weekend. Amazing transformation! Everything you are doing is awesome! Kudos to you and keep up the great work!
Jeff
madoc1
spicewood, tx
the doors came out really nice. and love the eco. we had one at a furniture store i worked at and spent many miles in it. what happens at your home shop now?
jim
oldironfarmer
Terlton, Oklahoma
Yeah both pumps last sold gas at 33 cents, every pic I've seen from the era has been in the 26-32 cent range.
I really enjoy reading your thread, thanks:thumbup:
For curiosity, I graduated high school in Oklahoma in 1967, and worked in a Mobil station for three years. Most of the time our gas was 29.9 to 32.9. Majors were always within 1 cent. Cheap brands like Deep Rock and Apco would be three to five cents cheaper. Occasionally gas wars we would sell at 22.9 with Apco down to 19.9. The 15.9 sign must have been taken because it was a give away gas war. We would get support from the distributor to match stations on our corner (Shell and Texaco) but we would have a volume limit. Oft times we would close up with a line and open the next morning with higher prices. Gas wars were a gimmick to get traffic at the expense of making money. Gas stayed pretty consistent until the oil embargo when it shot up into the 40's and slowly climbed from there.
Impeccable work!:bowdown:
shortykorte
Tallahassee, Fl
Sweet!
Will the sign fit on a park bench? If you keep the sign I guess a good spot would be on the outside back wall. Was this sign made by same people in Michigan that did 30" round sign?
H
HD FLHX
Central Iowa
jim
I will still do all my paint work there.
Thanks for the insight into the gas price fluctuations of the 70's. I wondered how that 15 cent price was possible during that era. I was born in 77 so the cheapest gas I can remember actually paying for was the 70-80 cent range of the early 90's.
Sweet!
Its a painted wood sign made by a lady in New Jersey. It's 2 foot tall by 4 foot long. I'll probably end up hanging it in my office at home.
H
HD FLHX
Central Iowa
Spent some quality time with my media blaster this afternoon blasting gas pump parts.
This was the last of pump parts that needed cleaned up. On the inner frames I'm just going to epoxy prime them and paint them black with a single stage implement paint. The outer sheet metal is ready to be body worked now. I'm not really after a"concours" restoration on these pumps just want them presentable. After all these will be displayed outside exposed to the elements.
The rest of parts I blasted and body worked a few weeks ago.
Loose Ctrl
Upstate SC
I was born in '77 as well. I turned 40 last month. Have you hit the big four oh? I was told it's was the end of life, but everything seems to be fine for now. :lol:
bj383ss
TX
Man those pumps are looking great. I have 16 months until the big "40". I'm not really worried about it. I would much rather be 40 versus 20. I did make a deal with my wife when we got married I would be getting a Corvette. See if she holds her end of the deal up.
Bret
slik560
Kansas, USA
When you get those pumps finished and set outside, are you going to put a "private property" sign up to keep travelers that are passing through town from trying to fill up? Might be fun to watch, but I would not want them messing with my freshly-restored vintage pumps...even if they don't...pump. ;)
BUGTHUG
Kansas
could you go more into detail on the media blasting procedure you used? My cousin borrowed me his HF red tank, but its missing the air attachment and needed something else. More trouble than going and buying a new one. I see the results look good, so maybe a good investment for one?
mh70ss
Bensalem, PA
Joe, I want to congratulate you on such and outstanding project and the fact that you take the time to document, explain and answer everyone's questions. Truly amazing work. I completed the entire Rt. 66 trip last year and really enjoyed the small towns and got to see many gas stations, some restored, many closed, etc. Yours is right up there with the best of them. Keep posting.
Thanks,
Mike
Stuart in MN
Minneapolis
The average person may not even recognize that they're gas pumps...they don't have TV screens built into the front, or a place to stick your debit card. ;)
BUGTHUG
Kansas
BB1934, man is that your stuff in the picture? You have a page going on somewhere on here, I'm sure we all like to see it. Sorry Joe for the small interruption.
H
HD FLHX
Central Iowa
Not yet...hanging onto my 30's for a few more months
There is pin that you can engage that will lock the pump nozzles inside the pocket. It what they would have done when the station was closed so people couldn't help themselves to gas back in the day. I'm going to leave them in the locked position so the nozzles won't be able to be removed from the pump pocket.
The biggest thing is having a 2 stage air compressor and clean dry air. Knowing which media to use is also important.
It's too bad you started restoring those pumps.....:sad:....looks just like my original condition one.I would love to have another just like it!Station looks awesome tho,I just read through the whole thread!:bowdown:
Its interesting seeing the little differences between the 2 pumps I have. Both are 505's but the Texaco is a pretty early one. My Phillips had painted on lettering and the ad glass is a bit different than yours. It also never had a globe.
H
HD FLHX
Central Iowa
Stopped by the building on the way home from work this afternoon and was pleasantly surprised to see that my concrete guy was there working. I wasn't expecting him for a couple more weeks. He still has a little bit of prep work to finish up before they pour tomorrow afternoon.
Gas pumps frames epoxy primed
don long
southern california
HD
Your lil station is sure lookin good.
Thanks for the inspiration I need to work on a couple of gas pumps myself
(Too many projects not enough time)
Don
