1946 Atlas Model 53
hpmachining
I thought I would create a new post in this forum to show the progress on my drill press and maybe ask a few questions. I posted a few things in my introduction thread.
I've made a little progress cleaning it up. I've got the rust polished off the column and the handles. I used maroon Scotch-Brite, followed by 600 grit paper, then 0000 steel wool, all with WD-40 as lubricant. I put Turtle Wax on them after that. I did the same to the guide pins for the motor mount plate.
The table and base surfaces took a little more effort. I used an orbital palm sander, light touch with some 80 grit and WD-40 followed by 150 grit. I cut a piece of Scotch-Brite and put it under the sander after that, then hand polished a little with the 0000 steel wool.
I've been tediously trying to clean paint spatter off of the original finish. I think it's just latex paint. I've been using IPA to soften it a little and picking and scraping it off with a piece of plastic and a wooden skewer. I'm working on the head now
This brings me to my first question. Do you think boiled linseed oil would be a good thing to use on the painted surfaces once I am done cleaning them up? I've never used it before so I don't know what to expect from it. I would try it on a small inconspicuous spot if I went that route. Or maybe there is something better? I have to admit, using linseed oil makes me a little nervous with what I've read about it's propensity to spontaneously combust, but I think I can figure out how to handle that safely.
I'll post more pictures as I go.
FrankLee
seMI, 48317
My first priority is to preserve the original paint when possible.
My process is to spray with Grez-Off, scrub with a small nail brush, rinse, dry and wax. I've tried several degreasers and found Grez-Off to work the best. It's more expensive than others, but the results are worth it, imo.
Examples:
If a painted part is lightly rusted, I follow-up Grez-Off with Barkeepers Friend.
Beerhippie
Far NE Oregon
That's how I turn scratched-up old stainless sheet metal into a nice, brushed finish. I use Mother's Mag and Aluminum polish instead of WD 40.
I generally use the IPA to soften myself up a little.
BLO will change the color of the paint a little. Here's an example:
Before BLO, after cleaning:
After BLO:
Be careful!
I used Greez-Off on that DP above.
Before:
After:
I could see the paint running on that badge instantly on applying the Greez-Off. I hit it with hot water as soon as I saw that, and saved some of the paint/dye.
It also removed the paint from the data plate of the motor:
I'd sprayed the motor down with G-O before I started cleaning the painted parts of the DP, so by the time I noticed, it was too late.
FrankLee
seMI, 48317
Examples:
Yeah, I should have mentioned above that I always(?) remove all badges and only use Meguiars Cleaner wax on badges.
H
hpmachining
That's what I'm trying to do, too. Thanks for all the links. Lots of good stuff there to look through.
I have some of that home. I'll give it a try.
With your user name, I would expect nothing less :LOL:. I wasn't even thinking about beer when I posted. Thanks for all the pictures and warning.
I'll have the give that a try. Is just the Scotch-Brite, Mother's Mag and Aluminum polish enough or do you use sandpaper first to get out deeper scratches?
