hpmachining
I thought I would create a new post in this forum to show the progress on my drill press and maybe ask a few questions. I posted a few things in my introduction thread.
I've made a little progress cleaning it up. I've got the rust polished off the column and the handles. I used maroon Scotch-Brite, followed by 600 grit paper, then 0000 steel wool, all with WD-40 as lubricant. I put Turtle Wax on them after that. I did the same to the guide pins for the motor mount plate.
The table and base surfaces took a little more effort. I used an orbital palm sander, light touch with some 80 grit and WD-40 followed by 150 grit. I cut a piece of Scotch-Brite and put it under the sander after that, then hand polished a little with the 0000 steel wool.
I've been tediously trying to clean paint spatter off of the original finish. I think it's just latex paint. I've been using IPA to soften it a little and picking and scraping it off with a piece of plastic and a wooden skewer. I'm working on the head now
This brings me to my first question. Do you think boiled linseed oil would be a good thing to use on the painted surfaces once I am done cleaning them up? I've never used it before so I don't know what to expect from it. I would try it on a small inconspicuous spot if I went that route. Or maybe there is something better? I have to admit, using linseed oil makes me a little nervous with what I've read about it's propensity to spontaneously combust, but I think I can figure out how to handle that safely.
I'll post more pictures as I go.
