1956 ford f-100 MAKE OVER
don long
southern california
I've been very disappointed that since I've gotten older that I couldn't drive my lil red pickup any longer.
It is an original non molested pickup with the old straight 6 motor backed up with the old 4 speed granny gear transmission.
At the first of the year I took some old corvette suspension off the shelf and started cleaning it up getting it ready for polish. I ground off all the casting edges and smoothed out each piece before polishing each piece.
Thinking that the truck needs some love and upgrading. I have had a nice newly rebuilt 429 ford motor sitting around for the past 10 years waiting patiently to be put into the truck so that I could drive it again (can't get my foot up high enough to hit the clutch pedal)
with the suspension all polished up I went out to a place that sells all the bracketry for the suspension transplant. That's where this project stalled out until the first of this month when I had the "Pick-ups unlimited over for a tour.
I ran into an old friend that day that builds 1956 ford pickups for his business and he agreed that I need to get back on my truck project.
The truck went to his garage last week and today I stopped by to see the progress
My Truck
The Corvette suspension before clean up
After clean up before polish
after polish
That was the first of this year
Swanny1953
Lucas, TX
Subscribed to ride along on another fantastic Don Long project!!
Those C4 bits look terrific. Now I have to decide if I have the inclination to try doing that with the suspension on my '57 Cameo!
drivesitfar
So you’re putting the 429 into this awesome old truck and giving it an automatic transmission instead of manual?
This could probably burn rubber just going to the store.
I’m all in for this rebuild and looks like you found the right guy to get it done.
Good luck as always!!
D
don long
southern california
Don,
Beyond the suspension and drivetrain, do you plan to 'resto-mod' other aspects of the truck? Interior, A/C and such?
Who ME??? Oh yes the plan is to give it a big window in the rear, it had A/C from when I drove the beauty back in 2000-2005 I had a nice custom interior with Lexus power seats but all that needs to change when I cut the back panel out of it
Dan in Pasadena
Pasadena, CA
"......with the suspension all polished up I went out to a place that sells all the bracketry for the suspension transplant...."
Don,
Any chance this ^^^ was Flat Out Engineering? If so, that's the IFS crossmember I used in my '55 Chevy truck. IFS totally changed the driving experience wit this era straight axle suspension.
When I built my truck I already had a never installed Fatman Fabrications Mustang II IFS kit but the installer - who works on this projects all the time - recommended I use the Corvette suspension. He said it's a much stronger system. Since I'd waited all my life to build just one truck I sold the other kit and used the FlatOut cross member.
I didn't install Corvette IRS though because I told myself there was a chance I'd tow 2 Jet Ski's after retirement. I over built my truck, sold the JetSki's and never did it. Now I kinda wish I had.
Can't wait watch your truck's restomod.
BORING HOP YARD
Boring Oregon
I have installed the "Flat out on my 56. I have a Jag front IFS and the truck is air bagged.
I chose to weld it in instead of bolting it in. I also changed a few things as well. Here are some pictures of my truck.
BSWS
Tucson AZ
That's already a nice truck but after seeing your other projects I'm sure it will be amazing soon. I've always liked the 56 best, not just because I was born that year, they made some nice improvements from the 53. Then came the 57, couldn't they have eased into the boxy design a little more gradually? I had a 60, I don't hate them but they're no 56.
D
don long
southern california
BSWS
The only reason to overhaul this truck was because at my age it is too hard to lift my left leg high enough quick enough to make driving it safe so as long as I have the 429 motor already and also the corvette suspension there is no reason to let the truck sit because I can't drive it!!!
D
don long
southern california
I took the 429 motor over to the truck shop last week and went by today for a progress report and was very pleased with what I saw
The motor is mounted to the frame along with the rac & pinion steering
and the 3rd member is hanging from the frame
The other mounts are on the frame waiting to be welded up.
What could be better.
I was handed a list of parts needed so I left, bought the parts and brought them all back
ambenz
NW Chicago Suburbs
Gosh, that frame looks pretty flimsy with those open gussets and THAT TORQUE MONSTER attached to it. I suppose most people can't afford a Art Mossison chassis... Sooooo....worried about give? I see stainless steel bracing in that builds future...cool build...guess a 56 has to be in the mix of all your cool rides. Still green with envy over here,,,,LOL!
BSWS
Tucson AZ
BSWS
That sounds like a good reason to me.
D
don long
southern california
This is the X member that the motor is sitting on
Modern Garage
Southern Minnesota
I just finished tuning up a black '56 Big Window that belongs to a friend. His has Corvette rear and a Malibu front with disc brakes, and a Chev 327 4BBL/ Automatic. It was built in the 80's or 90's with a Turbo 400 trans and a few years ago he paid someone to put in a Turbo 200R4 for the overdrive. Don't know who did it but I had to spend a couple of hours finishing that job too.
The engine is all stock from 1966 or so with points and Q-jet carb. About ten years ago I was working on it for him and found the choke cable (converted to manual like so many) adjusted wrong so the secondaries were always locked out. I reset the choke cable correctly and took a drive - all good. I told the owner when he picked it up. "I've never touched the choke cable." The secondaries had been locked out for as long as he had owned the truck! On the way home he stopped in an abandoned mall parking lot and did burnouts for twenty minutes because he couldn't believe how much power I had just found for him.
Joe
D
don long
southern california
Took the Headers over to the 56 this morning and was nicely surprised with his progress.
The fenders are back on the truck for centering the front Wheels to the wheel openings. The headers will be installed then the motor mounts will be welded in place. The back suspension mounts are all welded and looking great. Hopefully the frame will be ready for powder coating by the end of this week
