1965 GMC build
BMW Rider
Calgary, Alberta, Canada
Sorry, didn't intend to instill fear in you. :scared:
A few tips. Figure out the routing of the wires on the truck, mount the components that can be moved in the best possible locations to facilitate tidy wire runs. Start laying the wiring in place to build up the harnesses. Use small zip ties to control the wires where they branch off and to keep the wires contained. Get rid of excess wire length from those pre-wired accessory harnesses. Once everything is in place and all the wires routed, you can remove it all and wrap the harness with your choice of loom or non adhesive wrap tape -just don't use regular sticky electrical tape except to finish the ends of the wrap. Remove the zip ties as you wrap unless you are using split loom, then they help keep the wires contained. Lastly, use good connectors and terminals and get good crimpers for them. I hate those blue/red/yellow insulated run of the mill type that are so common. I prefer uninsulated terminals with either proper connectors or heat shrink sleeves to insulate them.
R
Robert Haas
All done with the wiring, Truck works amazing.
I now have one of the coolest shop trucks in the area. :p
zmotorsports
Northern Utah
Truck is looking great Robert. Great little shop truck.
I had a 1982, then a 1991 each that I had built from wrecks that were my shop trucks. Both I had slammed and trick paint jobs but they were cool as daily drivers and shop trucks. I kind of miss my '91, I even had a shot of NOS on it and was a blast to drive.
Seeing your pictures now makes me miss it even more.
zmotorsports
Northern Utah
Looks much better. Great stance, although the before looks great too.
Better than some of the ones I've seen with too much gap in the wheelwells. The before looks nicely proportioned as well.
R
Robert Haas
moving on to the firewall
made cardboard patterns
Then pulled the cab off the frame, the frame off the build table and then mounted the cab to the build table so it is level and square
R
Robert Haas
This tin bending is tough. :headscrat
Getting it figured out.
what started off as a small modification to let us set the big block back 2 inches exploded into building an entire new firewall. :thumbup:
I am happy with the results but golly I am slow at this type of work.
R
Robert Haas
Cleco's sure make this type of work simpler.
I need to get going on acquiring a planishing hammer and an English wheel:thumbup:
R
Robert Haas
I have so much respect for the people that just build sheet metal from scratch. We flat **** at it. However we are really stubborn and have no problem throwing away weeks worth of work and starting over.
Due to the very tight conditions and the fact we have re invented the wheel so often on this build it comes as no surprise when bad planning and over estimation of our talents put us behind the proverbial 8 ball.
I am talking about the master cylinders (Yep plural as we are running twins) and the steering column are fighting for their respective homes.
Here are a few pictures to show our pain.
jbmatth
Northern Ok.
Rob,
I just discovered this thread this week and have really enjoyed reading up on it. You have done a fantastic job thus far and I look forward to seeing more so I'll be tagging along.
JB
xtremek
St. Johns, Mi
Glad to see I'm not the only who is more stubborn than they have certain types of talent. There's hope for me. Don't get me wrong, you're stuff looks amazing, I just see some of the same mistakes I make.
R
Robert Haas
Yeah:thumbup: the firewall is basically finished.
It is as snug as a bug wrapped around the big block but I can pull the dist. and valve covers without having to move the motor. and that is after I moved the engine back two and a half inches.
iajonesy
Iowa
What size tires are you running up front? That looks really nice with the BBC in there.
Mike
R
Robert Haas
Mike
245/40/zr18:thumbup:
The Big Block does look great in this set up. Can't wait to get the inner fenders and core support built.
