2" or 3" Roloc Pads?
gotwheels
I have not used the Roloc style abrasive/conditioning pads. As a DIYer,would you recommend 2" or 3" size pads for general home shop/automotive use? Thanks
ken w.
Western New York
Everywhere I have worked they supplied the 2" discs. I have found the 3" disc tend to be too big for what I do. I do a lot of small engine and automotive work.
mbshop
visalia ca
2 in for me. Had 3 in but it basically sat in the toolbox.
was only used on large flat surfaces which rarely occured. So 2 in.will be the best to start off with.
please practice on junk as you can ruin parts easily without knowing it.
bobcatdan
Kaukauna,WI
Maybe it's because I'm uses to 2", but 3" just s seems big, foreign and weird to me. I consider them a small area cleaner as they are slow as hell doing a large area, so stick with 2" to fit in more areas.
dmdc411
Mn
They're awesome for softer metals. Used in aviation for all kinds of work!
Sent from my SAMSUNG-SM-G870A using Tapatalk
Hammer1963
Kentucky
I use both. I rarely purchase new 2" disc as I can always cut down a 3" disc and use it as a 2 inch, plus lots of time there will be plenty of usable surface area on a used 3 inch. I do this with both grinding disc and conditioning disc
