2 Post lift attachment
killahog
Morrow County Ohio
I have been trying to figure out how to make an attachment to my 2 post lift to lift items higher than the current arms will allow. The picture is one example of how this would be useful. I would want something that could be easily attached and stored when not in use. Any ideas?. The deer is much easier to handle now.
HoosierMark
Southeast IN
You need something like an A frame or a gantry that you could easily and safely attach to the arms. Maybe an engine hoist that could be attached. I will be watching thread as I have the same want as you.
OldNeons
Midwest
Assuming you aren’t lifting a large amount of weight (under 500#?), I would just make a simple mast that slides onto one of the 4 lift arms- or slide two arms of one the posts to the center and capture both arms in a saddle with a vertical mast and a horizontal member at the top to move the load towards center of both posts.... Not sure if this makes any sense? Basically picture the “frame” for a game of “hang man”.....
510ebl
Southern New Jersey
What if you stacked all of your extensions and bridged them with an appropriate timber? That might gain you 24 inches, especially if you fab a taller extension from lengths of pipe.
K
killahog
Morrow County Ohio
I couldn't think of anything that weighed over 500 pounds that I would need to lift. I followed the thread that was started about lift attachments for quite a while but have not seen anything on there. The hang man does make sense I was thinking about going that route and use the hole in the arm of the lift where the pad goes to secure it.
K
killahog
Morrow County Ohio
If you get a doe over 500#, please post pics!
She is nowhere close to 500 but a good size doe from Ohio. Ravin R29 crossbow 50 yard shot . Rage 2 blade 2" cut Broadhead
