2 Post Lift Location
DJF3
British Columbia, Canada
I am planning a 34x60 build. I want to put in a 2 post lift and I'm looking for suggestions on a location. Either just inside the overhead or part way down the building. This is my first time, but I'm sure there are lots of people that have done this already. What works, what doesn't? Thanks!
Bopbop
Savannah,Ga
I would go with option 1. It is farther inside and you do not have to worry about the overhead door.
I just did a 30 x 60 with 3 doors on the side. I put my lift in the far end bay. It is working out good for me. I also went with coil up doors so I don't have to worry about the door over the lift or blocking light fixtures.
D
DJF3
I was always thinking option 1, but if I do go with option 2 (for whatever reason) I will make sure my crew cab long box clears the door lol.
infinkc
Option 2 would be my choice, hate seeing lifts in the back, you basically loose all that space in front, and if you stored something you would always have to move it out of the way.
Rusty Fords
Dallas Or
Mine is placed like option #1 if I leave something on the hoist for a while I don't block that entrance. I wouldn't change mine on bit.
mrobins297aaa
south east michigan
This^^^^, if you put it in the back you either got to keep all the space in front of it clear or you'll be constantly moving things.
you didn't say what your ceiling height is.
if you have 12' or more you can get high lift doors that go straight up before they go back into the space.
mrobins297aaa
south east michigan
I have a 36' x 64' barn with 14'-0" ceiling.
here's a rough drawing of where I have my lift, it has worked well for me.
I have a 18' x 8' roll up high lift door, the bottom of the door track is 12'-0" so it's almost a non issue as far as the vehicle is concerned. and it only sticks back in the space 69".
I would look at one large door instead of two smaller ones, it may not look as good but it makes moving things in and out much easier.
skipchang
Southern Colorado
I have a 40x60 with a 14’ ceiling. I have 2 12x12 overhead door on the 40 side. I went through the same thought exercise and ended up near the overhead door. I’m so glad I did that. I store my tractor and implements in the area past the lift.
Sent from my iPad using The Garage Journal mobile app
mrobins297aaa
south east michigan
you said you had a crew cab long box.
here's a couple of pic's of my 7.3 on the lift.
If you look to the upper left on the pic you can see the end of the overhead door track.
D
DJF3
I'm going with 16' walls and a 12x14' door
