2 stall garage wall removal?
mrhess23
I would love to remove this “wall”. Im not sure if its load bearinf. We just bought this home. Eventually id like to have a ceiling and insulate it. Im not worried about storage. Any help would be appreciated.
firebirdparts
Kingsport, TN
It is not holding anything up.
Your connections running all the way across the building, where those are nailed to the rafters, they add quite a bit of strength. You need to keep all those. When you take the wall out, a couple of them will sag, but you can take a 2 by 4 and just hang that from the roof itself.
mrhess23
That would be awesome. Hoping for a few more opinions to make me feel better. Totally new at this.
Fav Onefour
MN cold and hot
Looks like a previous owner wanted the wall gone too. They knocked out most of the studs and left nails sticking through the plate.
Honestly, I don't know how much more you can remove. It is a wide span hip roof. The front, (over head door wall) and back are held in by the wall. The cross members from side to side are already twisting. Your door rails hang from the wall.
I'm not sure how you plan to do a ceiling and insulation. Some sort of hot roof and additional ceiling material is weight without structure.
At the very least, try to think of the long term plans before tearing into the wall.
mrhess23
Adding rafter ties? Suggestions? Bracing the cross members from the top and adding rafter ties work?
billconner
Thousand Islands NYS
I agree with Firebird. You can just remove it. If the remaining joists sag, use pieces of the wall framing for a hanger. I've never done it but structurally, I believe you can remove those joists. If you plans include insulating, at least consider a do called hot roof with spray foam on the roof deck and joists removed. Would look cool (especially with a t&g ceiling!)
Fav Onefour
MN cold and hot
Rafter tie might be worth consideration. It could be pretty simple.
We have an old dairy barn that was repurposed into open storage. The old hayloft floor had been the bottom rafter tie. The entire floor system was removed to make it one big open space. We installed steel cross rods attached with plates to the rafters above machinery height. The rafters are 2' spacing and we attached on every third one. It's been like that for about twenty years now, so I guess it works. ;)
Door rails and openers would still need to be hung in your garage. The hangers can be reinforced and extended to the roof. - Reinforced because of the longer distance. If they're a floppin, they're a breakin something.
Firebrick43
West central Indiana
This looks like its not only functioning as a rafter tie but also a rafter support purlin to me? Its hard to tell if its directly against the rafters or not? If it is against the rafters I would remove the wall (someone already seriously compromised it) and put a jack post under the purlin.
The center rafter tie can be hung to the peak with a 2x4 to keep it from sagging.
