2 wire Dimmer switch ?
Bulldog13
Cape Coral ,FL
I have this 2 wire dimmer switch in my kitchen that needs replacement…it used to “click “ when you shut off the light…now it won’t shut off unless you spin it to a certain position , The new dimmers all seem to have 4 wires ? I’m not an electrician so what kind of dimmer do I need to replace this ?
PCustoms
VT
Odds are this is how you need to wire it:
New switches have a ground and many are 3-way right out of the box, so that gets wire nutted.
Maybe slightly different depending on actual switch and your wiring
Bulldog13
Cape Coral ,FL
I’ll fine tune it up to specs 🤣…I’m just glad it works and I didn’t burn the house down …the chirps are a riot by the way 👍
