Just want to confirm a backfed breaker in a panel will safely trip. Just want to cover my bases before I do this. I plan on fabricating a metal "stop" to "lock-out" the 200A breaker and permanently identifying the 100A breaker as the main.
So, my advice: WAIT! Just do it right once, and be done with it.se. Since this already protected by the 100amp breaker in the house can I run the existing aluminum feed wire directly into the lugs on a new 200 amp main panels or would they be too small to properly secure them there.
We were not suggesting removing the 200 amp breaker and replacing it with a 100 amp. Instead we were suggesting leaving the 200 amp main breaker in the panel in place, just not connected to anything, and supplying the panel with a 100 amp double pole breaker that will plug onto the stabs of the panel, and then back feeding the panel thru this breaker. The 100 amp will act as the main for the panel, until such time as the original poster decides to upgrade his service and replace the wires from the pole to the meter can, the meter can itself and the wires from the meter to the panel, at that time he can connect to the 200 amp main and then remove the wires from the 100 amp breaker. He could re-use the 100 amp breaker as a sub feed to another panel (in a garage or shop) or remove it from the panel alltogether.
If the OP does this, he needs to be sure and tape over the 200 amp breaker and mark it unused/dead and mark the 100 amp as MAIN DISCONNECT so someone won't trip the 200 amp thinking they were turning off something. As an alternative, the 200 amp could be removed from the panel and stored until it is needed for the 200 amp upgrade, but this is overkill.
Charles
your best solution, considering your situation is to install a sub panel. the likely hood of you exceeding 100amps is not high.
all residental homes in the US have a minimum of a 200 amp panel and only a SMALL percentage people actually come close to reaching it.
anyone who has a 200amp panel...place an amp probe on one leg, with your a/c unit running and you will be lucky to see it drawing 50amps....that is just one leg.
the majority of people have space problems, not a lack of power available.
Says who?
Minimum service requirement is typically quoted as 100A based on NEC 230.79(C) in regards to the service disconnect.
Around here, it is a requirement that the meter socket be rated for 200A w/ a bypass lever, but that says nothing for the service. Hell I just installed a 150A this weekend.
Drive through any newer sub div within 50 miles of Omaha neb there's plenty of new houses with 150a services in in them.i would love to see a picture of that 150a.....someone please show me a picture of a NEW construction home or one done in the last 10 years with anything less than 200amp service. trailers and mobile homes don't count.
multi families are also exempt from this as the rules are different.
ok BigJohn.........
the NEC does state that....but if you have a license and you have or do wire for a living you know multifamily is different.
go ahead and wire a house with a 100 amp panel......how many breaker spaces are in it....unless you are wiring something the size of a shed you WILL NOT have enough spaces. even with most 200 amp services breaker spaces are limited, unless you purchase a larger panel. this is especially true with the AFCI rules.
i am not going to argue with you about this....i know what i am talking about and anyone that has bought a single family residence in the last 15-20 (my actual experience) years knows (if they look at a panel) it is a 200amp service. and an electrician (who actually does this for a living) knows what i am talking about.
there may be unique situations that require more or some that require less, very few.
anyways...his cheapest option is to get a sub panel......
I may have found what you're looking for...
It's a panel that's capable of being a main or a sub, and there's a knockout for when it's used as a main for the main switch. That would mean that the switch is modular, which might also mean that there are different main switches available.
It's a Square-D, looked decent. It was in one of the sites that I work in.
Just buy the panel with main breaker and unbolt it till you're ready to use it,the sq d panel covers all come with that knock out filler whether they have a main breaker or main lugs.I may have found what you're looking for...
