Is the cable you pulled in marked RHH, XHHW, etc? URD(Sweetbriar) is sort of a common trade name around here. The power co. uses one type of URD(definitely not allowed in homes), but what we use is dual rated as RHH also.
I would be very surprised if yours wasn't also the dual rated type as I can't see an electrical supply house selling the power co. version to electricians wiring homes.
It's not the dual rated. The manufacturer said that they make the cable that can run in contuit in the attic. But mine is not it. He also said that the insultion on any of their burial cable is more mils. then any house ran wire or cable. But that won't stop anyone from cutting it or driving a nail in it. So that's a good reason to me to do it right.
it worked great I ended up diging about 400' of trench. 135' for the cable, and 265' for a water line to a pasture. $107.00 for 4 hours. I had it back in 3 hours.
Now before I go any further I have a question. After doing a search and adding up amperage I'm not sure that the feed through breaker box is going to be enough. My home is all electric, It 2,800sf. I have a heat pump A/C system, 220v water well, 120v aerobic septic system (with a small air pump that runs 24/7) 220v hot water heater, And all the outher things that a home has. I know that it would be rare that all these thing would be on at one time. But will I have enough for the garage? Now for the new meter box. I plan to use two 2/0cu and one 1/0cu for neutral. Would 3/0 be overkill? I have 2/0 and 1/0 already but I want to do it right.
