200 HP electric motor
W-Cummins
Iowa
^^That's a genius idea, I didn't even think of that one!
Once I get my own three phase air compressor, I'm just going to run an extension cord from my neighbors house to get the 3'rd phase!:thumbup:
Depending on the feed to the neighborhood this could work with 2 other neighbors! :shocking::shocking::shocking:
William....
Matt Matt
Ontario
in case you didnt notice, this is a joke post based on a previous ridiculous thread.
I assume the 200 hp might be the shock point. I have worked with some 200 hp motors and they are 3000 pounds. I assumed there was a little bit of a typo. Maybe he meant 20 hp.
I have a 3P 20 hp Motor that I can start on 40A 1P that powers a RPC. I believe that motor is 190ish pounds.
The motor nameplate states 48 A. It is a little confusing single-phase 120, single-phase 240 and three-phase 230, three-phase 460, three-phase 575–600. And sure, at one point I think you told me I couldn’t run a particular pedestal grinder that was 600 V in my home garage shop. It’s been up and running a long time.
I assumed the typo of 20 hp. I further assumed this by a 200 horse power motor would be absolutely ridiculous 3000lbs. and furthermore based off his 60 amp question on hook up. Furthermore, at 200 horse power motor would shadow a 60 gallon air tank. A 200 hp motor would have a name plate of close to 500 A at 230 V and 250 A at 430 V. To start a 200 hp motor from single phase 240 V it would require almost 1000A for about 30 seconds. No Single phase breaker would hold this. This is why I assumed the typo.
Edit; my last post was to encourage seeking expert help and/or to flip the motor and buy a plug and play. At no time was I intending a potshot post.
Youre wasting your time.
Its most definitely not a typo and most definitely a joke thread.
You missed the previous thread thats why youre lost.
OccupantRJ
Eastern North Carolina
I need to move a Bridgeport milling machine from one side of my shop to the other. I plan to use the factory supplied lifting point, so the mill will be suspended in a pendulum fashion from a HF cherry picker.
Plan is to mount a 3 phase motor on the mill table and run it to act as a stabilizing gyroscope during the move. I assume I will need to buy a VFD to power up the motor? I could then later use the VFD/motor combo on something else like a powered bicycle or something.
Question is do I need a 2A51138 pulley on the motor to increase the gyroscopic effect for more stability? Or would a 1A51138 work better due to less mass? Would a 1725 rpm motor or a 3450 rpm motor be better for this application? I assume the faster motor due to the gyro effect.
I would be able to adjust the table in the X/Y axis to accurately dial in the balance point. I think this would cancel out the swinging of the mill during rolling across the concrete for the 18 feet 6 inch move.
I would set up a power festoon cable system to power the motor during the move, and also use the soft start feature of the VFD to prevent initial wild swinging of the suspended load.
Does this idea seem that it would work well? Thank you for your most esteemed opinions. Any local help available during the move would be appreciated. A couple of members don’t live far from me.
mike93lx
Richmond, VA
no need to waste your money on a VFD. just plug the motor into three different sockets...viola! 3 phase power. if you need to adjust speed, just kink one of the cords
MattT
Definitely go with the 2 pole motor. And change max frequency from 60 Hz to 400 Hz. That'll get you plenty of gyroscopic effect, and probably allow you to push the mill across the shop with one finger:lol_hitti
Miss the Pontiacs
Saskatchewan Canada
A green powered option is what is required. Bicycling is good for your health and assists with developing a good stroke. A good stroke is essential in compressing air. See pics for application.
strutaeng
Dallas, TX
I wonder how many calories are need to make this little tank reach 120 psi? The guy needs to take advantage of gearing. Start on "high" gears and switch to "low" gears as pressure is built up and resistance increases?
No need for the gym!
PugetDude
Superstition Mountains, AZ
That's the high-speed two-stroke model, produces 12VDC and compressed air at the same time. You can tell it's the high-speed model by the cooling fan on the alternator.
Miss the Pontiacs
Saskatchewan Canada
I’ll be damned your right.
Here all along I thought it was the 10 speed, racing tire that produced a hydraulic action forcing air into a peanut butter jar with a quick release valve for pressure sensitivity.
mike93lx
Richmond, VA
Kind of ironic, i was walking through one of our plants late last week and happened to pass by a 200hp motor waiting to be installed. I am pretty sure that it would run fine at my house, or brown out the neighborhood. One or the other
Falcon67
Merkel, TX
I looked at one of those "200 HP" chinese motors. It's a really more of a metric 200HP.
Figure the running draw and it comes out to more like 3.14159 english HP. The startup draw is about 200 HP because of the sand they pack in the bearings during manufacturing. So once you get it going, tape over the breaker because you don't want to turn it off. Take a pic of the breaker and save on your phone so per code, the shut off is always within sight.
mrobins297aaa
south east michigan
well as long as were going off topic.........this was 1983, Michigan Bell bldg. downtown Detroit, this fan had a 200hp motor on it and it was such a pia to get it installed where it had to go, we were all joking that we hope that we never had to change that motor.
It ran 15 minutes and burned up.....really
PugetDude
I got this 400hp DC motor from the scap bin at work. How many 9v batteries will I need to run this? I want to use it in my swamp cooler. 20190513_125002.jpeg20190513_125009.jpeg
Sent from my SM-G892A using The Garage Journal mobile app
Excellent idea running it on 9V, since it is going to be used around water.
BTW, You might be able to scavenge a bunch of 9V batteries out of old smoke detectors.
laser3kw
northen IL
120v or 240v?
prolly didn't have enough extension cords running to it
Falcon67
Merkel, TX
I could see a bank of Eveready's running that giganto. They'd never handle the start up though. I would suggest maybe hooking a big start cap in series with a regular phone POTS line, then you could call that number and the 90v ringing voltage would kick the motor off easy.
LOL. I started this thread and enjoy that it is still going.
How did that other guy ever end up?
I think hes hiding in the corner with his tail between his legs.
Either that or hes sitting in the dark because the poco cut his service drop after he tried to start his 200HP motor on a 100a service. :bounce::lol_hitti
rharman
SoCal
I think you can reverse the rotation if you fold the cords in half.
Miss the Pontiacs
Saskatchewan Canada
You can always wrap a section of the extension cord with tin foil. Then by sliding the tin foil up or down the extension cord you find the sweet spot of how much current you actually need.:lol_hitti
laser3kw
northen IL
Charlie K
Baltimore
I heard he was in Florida helping somebody pull stumps.:beer:
country83
lol all joking aside
If i hadnt seen the previous ridiculous thread pertaining to this subject i would think this was either spam or a troll post.
nicely played!!
:willy_nil [emoji38]_hitti
Been reading this thread and enjoying it, but after looking I still haven't found the previous thread mentioned. Did it get deleted?
Sent from my XT1635-01 using Tapatalk
country83
Milton Shaw
I really need this motor to replace the one on my granddaughters toy sewing machine. She runs through batteries too often and need to convert to plug in. Send me a PM if you are interested in helping me with with granddaughter.. LOL
