2016 Garage Sale Thread
1badbird
Neenah, WI
Paramount no.6 vice missing jaws $40
Small Jorgensen clamp 75¢
Craftsman plastic box 25¢
Billings hammer with new handle $3
Odd handle with file in it 50¢
3/8 craftsman rhft $8
Rest of hand tools $2.50
50a plug $2
Box of ear plugs $6
Emergency bulb and fuse holder for car $1
Panasonic radio $1
Philco Ford radio $1
1badbird
Neenah, WI
A few items I won at a local online auction
Craftsman block grinder in really nice shape $40
All tools to left of grinder $2
Craftsman electronic soldering gun with the box and solder $7 (even had the cardboard sleeve to go over the box)
bulletpruf
San Antonio
Grinder looks nice. What hp? Is it commercial (dual voltage)?
Scott
Berserk
50a plug $2
Box of ear plugs $6
Panasonic radio $1
The file handle is sweet, I would buy that quick!
fl18guy
cohoes, new york
outlaw.
The box has a hammered finish to it. Pic was taken with my bad camera without working flash. The color is a little dull, I might have to give it a waxing to shine it up.
PFSard
Mesa, AZ
For $5.00 at an estate sale Saturday :
Kobalt 5-1/2" Brick and Block Trowel
HDX 1/4 in. x 3/8 in. x 1/4 in. Square Notch Trowel
Craftsman 3/8" 12 Point Combination Wrench 44693
Ridgid Scissor-Style Plastic Pipe and Tubing Cutter PC-1250
Plastic Process Equipment Brass Drift with Screwdriver Handle
Plastic Process Equipment Right Angle Brass Drift with Screwdriver Handle
Plastic Process Equipment Deburrer
Heavy Duty Brass Hammer
Quick-Wedge Insulated Quickwedge Screwholding Screwdriver 1838E
Brass Drifts (three)
MAC 5/16" x 7" Starter/Machine Punch SMP10SS
Armstrong 4" 2-Jaw Adjustable Puller HC-70
Craftsman Phillips Head Screwdriver #2 x 8"
Craftsman Magnetic-Tip Ratcheting Screwdriver 41466
Wiha PH0 X 75 Precision Screwdriver
Phillips Head Precision Screwdriver
Snap-On 3/16" Hex Allen Socket Driver 3/8" Drive FA6A
Great Neck 3/8" Drive 3" Long Extension EX30
Homemade Aluminum Drill and Pipe Tap Holder
Unmarked Chain Breaker
1-3/4" Pin Spanner Wrench (Made in England) 6672/3
Proto Adjustable Face Spanner Wrench 2" Capacity C482
Unmarked Countersink
Hanson Straight Flute Screw Extractor (3/4") ST-6
3/8* Drive 17 MM Hex Socket
No Name Conical Deburrer
Irwin UniBit 3/16-Inch to 1/2-Inch Step-Drill Bit, 1/4-Inch Shank #2
Craftsman 22mm 6pt Impact Socket 1/2-in Drive 18722
Craftsman 3/4" 6pt Impact Socket 1/2-in Drive
DIN Double Open End Wrenches (10 mm X 13 mm, 18 mm X 19 mm, 22 mm X 24 mm)
M14 X 1.5 Bottoming Tap
Brass Brush
Bondhus 7/32" Balldriver Screwdriver
Bondhus 1/4" Balldriver Screwdriver
Eklind SAE L-Shaped Ball Driver Set (missing five pieces)
Proto 7" Straight Visegrip with Slide Hammer 291-R
Bondhus Set of 9 Metric Balldriver Screwdrivers, sizes 1.5-10mm
bulletpruf
San Antonio
Armstrong 4" Jaw Adjustable Puller HC-70
Brass Brush
$5???
Wait for it....
YOUUUUU SUUUUUUUUCK!
Well done.
BlueBomber
Outside Boston, MA
Brass Brush
Did you forget a zero?!!? Major suckage...
FigureItOut
Bentonville AR
I just picked up this Mitutoyo depth micrometer for $10. I have a pretty good idea as to it's use and value, but I just don't have need for it or I'd be way more excited. For the price though, I had to snag it.
Sent from my SAMSUNG-SGH-I337Z using Tapatalk
Tellingthem
Traverse City, Michigan
Stopped by the Habitat for Humanity store on the way home. Saw a nice little body hammer, another little metal loop screwdriver and my favorite an old 50ft Lufkin tape measure. Had the instructions and the receipt in it (not sure if the box is original). That little guy cost $3.95 + .15 in tax for a total of $4.10 on 03/19/1956. In todays money that total is now $36.21. Kind of interesting to see the true cost of these old items. I got them all for $5.
1badbird
Neenah, WI
3 metal boxes of drill bits $3
Porter cable bit kit $2
Air chisel set $3
SK box $5
2 hatchets $12.50 a Miller Falls and norlund
Rest if the lot $3 including aluminum hammer, wire wheel, misc. Handles, OTC puller, extractor kit, and hand drill
1badbird
Neenah, WI
Picked up a few deals at a local auction.
Pic 2- bag and everything in front of it, to the left of it and everything in pic 1 was all in it. $35 included bucket boss bag, vice grips, channel lock side cutters, channel lock small cutters/pliers, bondhus torx set, few ratchet straps, t&b stackon crimper, Klein pliers, handklip no.6 shear.
Snap on pistol grip ratcheting screwdriver $6.50
Snap on ssde100b electronic thin blade screwdriver set missing one screwdriver $20
jpickar
Air chisel set $3
SK box $5
The wooden handled hatchet, does it have a name on it? Maybe Plumb or Norlund? If it is a Norlund, it appears to be a "Hudson Bay" style head. It is worth a few bucks!
John
1badbird
Neenah, WI
Alright next round of stuff... a weekend of garage sales got me this stuff.
Pic 1-3
Craftsman jigsaw with crown top case $3
Craftsman cantilever toolbox in great shape $15
Quaker state duffle bag 50¢
Tall oil can $3
Pair of old fly traps (or so I'm told) $5
Plomb wf-84 $2
No name ratchets 25¢ each
Wrenches and sockets all for $1.50 includes Armstrong and Williams super wrench
Small Utica pliers 25¢
Rawhide mallet, scuff pads, scissors, wheels, slide puller $3 for all
Craftsman 1/2" rhft $12
Stopped at the local ReStore and found plastic cases 4 of them sized 13x9.5x3.75 at $1 each and 3 sized 20x12.5x3 at $2 each.
1badbird
Neenah, WI
Items came from a local race car / engine builders shop, owner had decided it was time to hang it all up and have an auction.
Snap on engine stand with crank handle to rotate engine $21
Snap on ratcheting screwdriver master kit $80
All other snap on $135 included
Ratchets tm75, tm711, f710bk, f836, fx24 extension, tm4cs drive handle, f5l T-bar, tm10f breaker bar, s67 1/2" ratchet adaptor, and more.
Heinrich model 20 vise $2
Not sure about the long for the others, but this is my list of companies that used the innards, if not had Easco make the whole ratchet for them (a few more than you listed):
Allen, Armstrong, Craftsman, Easco, Husky, K-D, Master Mechanic, Napa, Ridgid
I was just talking long 1/2" version. Not positive whether or not Armstrong or Master Mech. offered it in long.
I don't think Husky was ever part of that crown AFAIK.
1badbird
Neenah, WI
It's not a typo outlaw, I couldn't believe that no one would pay more than $21 for the engine stand that is in great shape and has the crank handle. The vise was really $2 also, but I will admit I had no idea what it was worth till I got home and looked them up, new they are over $200! I just figured at $2 I couldn't go wrong lol.
Al Bundy
Upstate NY
So he decided to have an auction and you were the only one that showed up!?!?
I gotta tell you, you ****!
bluebolt
Benton LA
1badbird, nice scores! I have two of those engine stands but I had to pay a whopping $50 each for mine!
BBolt, sounds like you got rooked... I hate to see a fellow GJ member overpay, so I'l cut your loses and buy one of the two for what you paid. :pimpflash
:evil:
