2019 Home Depot Clearance Thread
Rusty67
LA, CA
I don't think so. If you want good/solid wireless, are willing to spend a bit more money and learn a little, go with a ubiquity setup.
Sonic-Boom
$50 for the 2 pack by me. Worth it??
They aren't bad out of the box routers, but if you want to spend time you can get a better setup. I bought 2 pack a while back form walmart, on the box it said it covered like 2500 or 3k sq ft house something like that. I only have an 1800 sq ft house and they wouldn't cover it. I spent hours on the phone with customer service and I ended up just returning them. I ended up getting 2 tmobile asus routers for $40 each and running them in AIMesh after a software upgrade. I am very happy with that setup.
nikon5400
I had problems with that router you got from T-Mobile occasionally it would drop connection (Comcast service). Also I needed an extender for 2.4 in the room behind one or two walls (about 50 ft). I had latest asus firmware on it. i returned it and got asus 3100 and it's a thousand times better no need for extenders full speed in every room but for some reason it doesn't play well with verizon FiOS even when connected to FiOS router.. sometimes an icon would show a signal problem videos would freeze but had zero issues with slower Comcast. I don't know if this is a problem with FiOS signal fios support tells me to contact Asus. They only certify FiOS routers, but range on those is pretty bad... but according to FiOS tech support small range is a security feature so the signal doesn't travel outside your home :)
Sent from my Moto Z (2) using Tapatalk
Rusty67
LA, CA
Wow, that is the absolutely worst answers I've heard tech support give ever concerning wireless range. Without doing a wireless site survey and checking the spec sheet vs the configuration of your router there is no good way to give you an answer as to why a particular access point/router is not performing well.
nikon5400
Sikaflex -
does anyone know the item number or Internet number for sikaflex that's on clearance?
I remember I saw a lot of 10 ounce tubes on the end cap but I was in a rush and didn't pay attention was kind it was.
I took a picture but can't find it :(
Thanks
wastedcosmonaut
It's has a powered amplifier. That makes it better than the unamplified ones. Shape and size of the antenna copper will also improve it versus a smaller one.
But if you are in a metro area, say NYC or Chicago, then you don't need a big or amplified one.
Ohiost
ECHO 58v blower $58.03
Poe34
Still over $200 near me. If you buy this, check the battery. I bought the trimmer and edger last year and both were dead, wouldn’t take a charge.
Thanks for posting Ohiost.
Ohiost
Same thing happen to me last year when I got one of the hedge trimmers clearances out. One would charge. Echo was pretty cool and sent me another
gpiggaz
Tucson, AZ & Edmonds, WA
Just picked up the EGO Blower/String trimmer with the 2.5AH battery and charger for $139.00. YMMV of course. My store had 3, I bought 1 and my neighbor bought 1. I almost bought 2, but really couldn't justify it.
692042011368 EGO 56V KIT <A> 139.00
EGO 56V TRIMMER +BLOWER COMBO KIT
This was in Marana AZ
drwheels
okla. city ok
My closest store had penny price stickers on the shelf again. They wanted more than .03 price for the stuff. Commercial lighting for shower.$17.97 regular price.
Crazyjake8493
Upstate NY
Picked up a couple Centipede 2'x4' folding work stations today for $13.03. I'd never even seen them in stores before today.
gpiggaz
Well that was fast, it went down to 125.04 yesterday, I took in my receipt and they refunded me the difference. All sold out at my HD now.
Zestomite
Southern California
This may be an outdated deal. But I have 4 stores local that show “limited stock” and all their PCAs have shown 1 in stock but no luck yet at 3 of them.
Maybe you guys will have some luck.
It is REALLY hard to convince someone to get up on a ladder and check for me. They confidently tell me they have none in stock. All my searching ends up being visually from the ground.
Firefighter1406
One heck of a deal. $229 is all I can find.
drwheels
okla. city ok
Could be display. Some stores count the display.
Poe34
HD usually writes their stock numbers large enough to be seen from the floor. I often go up on the ladder to retrieve something and I have never had anyone question me!
