Branded, where are you located? I don't see either of these for sale online/near me.
Linksys Velop 2 and 3 pack routers down to .03
$50 for the 2 pack by me. Worth it??
I had problems with that router you got from T-Mobile occasionally it would drop connection (Comcast service). Also I needed an extender for 2.4 in the room behind one or two walls (about 50 ft). I had latest asus firmware on it. i returned it and got asus 3100 and it's a thousand times better no need for extenders full speed in every room but for some reason it doesn't play well with verizon FiOS even when connected to FiOS router.. sometimes an icon would show a signal problem videos would freeze but had zero issues with slower Comcast. I don't know if this is a problem with FiOS signal fios support tells me to contact Asus. They only certify FiOS routers, but range on those is pretty bad... but according to FiOS tech support small range is a security feature so the signal doesn't travel outside your homeThey aren't bad out of the box routers, but if you want to spend time you can get a better setup. I bought 2 pack a while back form walmart, on the box it said it covered like 2500 or 3k sq ft house something like that. I only have an 1800 sq ft house and they wouldn't cover it. I spent hours on the phone with customer service and I ended up just returning them. I ended up getting 2 tmobile asus routers for $40 each and running them in AIMesh after a software upgrade. I am very happy with that setup.
I don't know if this is a problem with FiOS signal fios support tells me to contact Asus. They only certify FiOS routers, but range on those is pretty bad... but according to FiOS tech support small range is a security feature so the signal doesn't travel outside your home![]()
Doesn't let me add linksLED motion light for under $25.
1003524047 found 3 @ $15.03
The blower come with battery and/or charger? Nice find
Sent from my Moto G (5) Plus using Tapatalk
ECHO 58v blower $58.03
Still over $200 near me. If you buy this, check the battery. I bought the trimmer and edger last year and both were dead, wouldn’t take a charge.
Thanks for posting Ohiost.
local guy has a few of these for sale (with dents) on FB for $650...![]()
Found a Milwaukee drill kit for 18.03.
Just picked up the EGO Blower/String trimmer with the 2.5AH battery and charger for $139.00. YMMV of course. My store had 3, I bought 1 and my neighbor bought 1. I almost bought 2, but really couldn't justify it.
692042011368 EGO 56V KIT <A> 139.00
EGO 56V TRIMMER +BLOWER COMBO KIT
This was in Marana AZ
This may be an outdated deal. But I have 4 stores local that show “limited stock” and all their PCAs have shown 1 in stock but no luck yet at 3 of them.
Maybe you guys will have some luck.
It is REALLY hard to convince someone to get up on a ladder and check for me. They confidently tell me they have none in stock. All my searching ends up being visually from the ground.
Could be display. Some stores count the display.This may be an outdated deal. But I have 4 stores local that show “limited stock” and all their PCAs have shown 1 in stock but no luck yet at 3 of them.
