20x8 Garage Door
mrichied
Hello Guys and Gals,
First off, thanks for having me. I've been lurking on the site for a long time. I'm in the process of building my new garage, It's 26x26 and I want a 20 foot wide door. Problem is, I can't find a 20' wide door anywhere. Please tell me where to look!
GrayFlattop
Chicago
You could also go with a commercial rolling steel door - like the ones found on at loading docks. They will make just about any size - we just put in one that is 40' wide x 20' high.
Of course the Haas doors mentioned in a previous post look a lot more like a conventional garage door.
MikeF
I'm going a 28x14 tomorrow. Clopay 906 or something like that. I hope you like the look of monster struts.
renloy
Call your local garage door guy or 3 and get estimates. Doors that size are commercial not residential. My 20x12 r20 insulated door will probably cost around 4k installed.
gnpenning
I have more questions than answers.
Post your location for more direct advice.
20' x 8' is still a residential sized door. Box stores are not a good choice to be looking. Go check out your local door companies. Make sure they add struts to each panel. Unless you are in a high wind area then you may have to step up. Depending on your location it should be a lot less than $4k.
James-W
Southeastern Wisconsin
Welcome to the forum. May I ask why you want a door that wide? I have a 16ft wide door and it is more than enough to drive two cars in. I am just curious as to why you want a door 20ft wide.
Benagy
I had a 20 x 8 door installed when i built my garage 2 years ago. Goi it from Overhead Door Company. It is insulated and has windows in the 2nd section. wanted some light in. Cost was about $3000. I am north of Atlanta, GA. Hope this helps. Bert
Scotty Doors
Orlando, Florida
It will be hit or miss as some manufacturers go to 20' and most do not in residential. All will have a commercial style door in 20'.
Windload doors in residential are about non-existent. It would have to be a custom door and then approved by an engineer.
racecougar
Missouri
This thread is from 2018. The OP has likely figured it out by now.
Scotty Doors
Orlando, Florida
I agree. However, I had a request from a customer, and I was researching it myself, and coincidentally I came upon his post. In my research I found you can get that door and it might be helpful to others in the same boat. Cheers!
