220 circuit split question
glennm
Hi
i am considering purchasing a Laguna 14BX bandsaw (any thoughts on the saw would be welcome). It is available as a 110 or 220. The 220 is more robust and it is actually a bit less money right now. I would need to run a new circuit for the 110 because I believe it needs a 20 amp breaker so I don’t see any advantage in choosing that one. i have an ingersol rand compressor hard wired on a double 20A breaker right beside where the saw would be located, I am wondering if there is any reason that I shouldn‘t add a surface mount box, install a 220 receptacle and also feed the compressor from the same box? The two would not be running at the same time and it would save a lot of work running a second circuit.
eegger
WI
Sure you could leave the Compressor hard wired and wire a outlet off of that.
u2slow
BC
You could do 6-20R receptacles and plug in either/both.
Not sure what NEC says about hardwiring both to the same 20A circuit.
G
glennm
My thought is to hard wire the compressor and have a receptacle for the saw
Zeke
I'll bet that under most circumstances both would run at the same time w/o a problem. A BS is not something you bear down on much. They just don't work that way, say, as opposed to a table saw. Only if they started at the same instant and I would think that any delay built into the breaker would allow that.
This should explain it.
marak
Anchorage, Alaska
I've had the Laguna LT16 HD, made in Italy, for about 7 years now and I absolutely love the thing. Simply a pleasure to use and is one of my favorite woodworking tools. It is 240V, as is most equipment in my shops, and I use Twist-Locks for all of them with the exception of welders, plasma cutter, and air compressor.
I don't know if this is NEC "legal", but I would add a pigtail with a 6-20P plug. Put a 6-20P on the bandsaw and install a 6-20R receptacle. Obviously you can only use them one at a time.
What is the HP rating on the compressor motor and BS motor and do either of them have integral overload protection?
These are the details I don't know about.
G
glennm
The compressor has a protect. Not sure about the saw (I don’t have it yet)
eegger
WI
2.5HP, 9.8Amp for 220v
6 ft. Cord w/Nema Plug: 6-15P
You'd have to change the plug/or get an adapter to go to a 20A outlet.
pattenp
Virginia - USA
Nema 6-15 is rated to 1.5hp. Using a non manufacturer installed plug would need to be a 6-50 which is 3hp rated.
rpcraft
Waco
If they sell the same unit in 220 or 110 how is one more robust? Just curious. Usually I go for 110 as much for items for shop equipment, especially something I am moving around or using semi-portably. I do simply because I'm able to use in locations other than my shop at a 220 socket. My main desire for something being 220 is only when it has to use more energy capacity than a 110 line can support.
eegger
WI
That's straight out of the manual.
The bandsaw is supplied pre-wired with a 110V (NEMA 5-15P) 3pin plug or 220V (NEMA6- 1 5P) 3-pin plug. It is recommended that The bandsaw be connected to a 15-amp breaker. The start/stop button activates the motor.
Norcal
It's time for A-holes who import equipment with obsolete voltages to have a chain attached to their ankle & the other end to their **** machine, then push the machine overboard. Rant over, more then a bit harsh but that garbage needs to stay in whatever s-hole country until they can supply it to standard voltages, the Europeans & Chinese seem to be the worst at that.
pattenp
Virginia - USA
I guess you didn't understand what I was saying. The factory installed 6-15 plug is okay. If modification is done to the cord and a non-factory replacement plug is used it would need to be a 6-50 to be NEC compliant if the motor is actually 2.5hp.
TRWham
East Cobb County, Georgia
I know Brazil, South Korea and Saudi Arabia still use 220 V 60 Hz power. There may be others but those are the 3 I dealt with most often when building equipment.
Sumboodie
AK
S Korea was 50Hz when I lived there about 20 yrs ago.. I remember figuring it out when my alarm clock kept losing time.
Norcal
Like it or not, 110,220,440 volts are not supply voltages, 120,208,240,480 are standard supply voltages, with 115,200,230,460V the rated voltages for motors & welding equipment.
What is even more annoying is for some equipment the user has to add transformers (buck/boost) to allow the oddball equipment to function on the power supplied by the PoCo.
u2slow
BC
There are dual rated motors and welders that will accomodate 220-240v and 50 or 60 Hz. This is getting more common.
Fwiw, my 16A/240v USA-made compressor came with a factory 6-20p molded cord. It's worked fine for 20years. I wouldn't get too hung up on the HP rating if it holds on a 15 or 20A breaker. Jmho.
G
glennm
well, I’m confused now. I thought I could leave the compressor direct wired and install a receptacle to accept the plug on the bs?
F-22
Do these things really make a difference? TBH I do not know what the actual voltage is in my country (Slovenia, EU), some call it 220, some 230, some sockets have 240 written on... I assume devices are made for 230V and can handle +-5%, maybe even +-10%.
About the same deal with the 50Hz vs 60Hz frequency. I think, at least for workshop tools, that everything is designed to handle the differences. And with tech stuff like chargers that use DC, I think those can usually handle everything from 100V to 240V...
mike93lx
Richmond, VA
It would function, but I wouldn't want them to have a chance at kicking on at the same time.
I'd be inclined to do it in my shop, but I would probably just put both on plugs so there is no chance of simultaneous running
Sumboodie
AK
That is assuming it's a DC motor with no losses due to friction, etc.
No machine is 100% efficient. Otherwise perpetual motion would exist.
1hp ~ 746 watts. 1 amp at 240v is 240 watts.
1hp at 240v is about 3 amps.
At least I think that's right. It's 0230 and I'm tired.
u2slow
BC
Nameplate values of the actual machine you have are more useful than a theoretical table value. I know NEC is contrary to this, but not all codes see it this way.
However, any wiring or circuit components need to be based off NEC code not nameplate amps
