Hi
i am considering purchasing a Laguna 14BX bandsaw (any thoughts on the saw would be welcome). It is available as a 110 or 220. The 220 is more robust and it is actually a bit less money right now. I would need to run a new circuit for the 110 because I believe it needs a 20 amp breaker so I don’t see any advantage in choosing that one. i have an ingersol rand compressor hard wired on a double 20A breaker right beside where the saw would be located, I am wondering if there is any reason that I shouldn‘t add a surface mount box, install a 220 receptacle and also feed the compressor from the same box? The two would not be running at the same time and it would save a lot of work running a second circuit.
