230V 16A Start/Stop switch wiring
CT44
I purchased a start/stop switch for my chop saw. It's got 4 wires coming out of each fastener on the back side. It has one black and one white fastener. I'm no electrician so my question is do I just wire all 4 wires together and attach to the positive and negative wires of my electric cord? Any advice is appreciated. Thanks
http://www.surpluscenter.com/_MoreSpecs/w11-3352.pdf
That's the link for their wiring diagram on it.
dutchgray
Dorset. England.
Um no, that switch switches two phases and the neutral. Get an electrician to do it if you don't understand it.
alfredeneuman
Fullerton, CA
It's a common thing for the neutral to be blue and the active to be brown and black in the UK for permanent circuit wiring
If it's a cord, however, it's not always the case. Blue can be used for the hot.
C
CT44
It has a green with a yellow stripe, a brown, black and blue wire coming out of both connectors.
OP, what is your location? Without knowing that and what electrical supply u have, we really cant give a good answer.
