24x36
BC iron works
24x36x10h block garage 140 mph wind code
just got the prints and permits.hope to start next week
jlckmj
SE Wiscosin
Where are you located?
keep us posted and take a lot of pics,
I am building the exact same size garage in a few months, I need some inspiration.
Jim
BC iron works
this site is not worth posting on anymore.
if you want to see pics go to welding web.com
BC iron works
maybe 3 for jim
NUTTSGT
Northern Central Ohio
wow.
I understand now.
f in steel
i said concrete block
this site *****, jack olsen must run it
(im from calafornia and drive a porsche but you should ride a bike)
You have very few posts and got an attitude with everybody. You don't use puncuation and capitalize letters, most people here won't respond to that type of mentality. Good luck with your build.
rsa
Between Raleigh and Fayetteville, NC, USA
I like! Looks like you found a contractor.
I have a 32' x 28' hip under consideration. 10' and 14' doors on the long side. One thing slowing up pulling the trigger is that I hate to lose so much of my yard to a 26+ foot wide driveway and don't have the access to put door(s) on the short side. :(
Good luck with the build!
BC iron works
it just takes so long to upload pics.
BC iron works
more
Roostriz
Excuse my ignorance, but what are the white sploches at the base of the walls?
-Jeff
Looks like they coorespond to the cutouts in the block on the photos above. I'm no mason so I have no idea what they are for...
BC iron works
its miami dade code. the inspector has to look in there to see the
rebar meet code. then thay fill the cells with concrete and then grind
them down to make it look better
BC iron works
allmost finished the garage doors are 130 mph wind code
and will be insulated so are being custom made
BC iron works
moving in, power and driveway will be done next week
Nighttrain
Dripping Springs, Tx
Nice work BC. I understand your frustration with uploading the pictures. I found that by going to photobucket and uploading them there then inserting them to your post you get a larger picture and then you don't have to click on it. Photobucket is free and its not to tough to do.
My neighbor is in the process of building a block garage about the same as yours. The code for the rebar is a good idea, but I wonder what would happen if the inspector did not pass it? Does he come out while they are building it to see if it is proper code before they get the wall to the 10' level.
Keep us posted.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
wow.
I understand now.
Not sure I understand it, but then again I'm still stuck on WTF!!! :wtf:
BC iron works
Front driveway in and have power.
