You may be required to install 4 smoke detectors upstairs....One in each bedroom, one immediately outside each bedroom (in the alcove) and then one in the living.....Depends on how your inspector interprets the code...
Don't forget you need ventilation in the bath and in laundry...bath should be a requirement, laundry maybe not (again depends on how the code is interpreted).....
Thanks, didn't know that about the fire alarm, I'll add another. And yes, I forgot to add the ventilation, I'll do that tonight. Great catch.
BTW....4-220v-50A circuits plus all the other 110v outlets (I don't seen any AC/heat either) means you're probably into a 300amp panel (expensive over a 200-225) or at least a 225 and a sub panel......
Maybe you don't need 50 at the dryer or range (most dryers are 30 amp I believe and ranges are 40-50 amp).....would save you some money.
Thanks, yes, I was being lazy just making them all 50 amp on the sheet, but yes, I should change it to 30 amp, that's how I wired the house and it was in line with the code.
It looks like you are in an older neighborhood. My previous home was in a 1920's neighborhood. There were quite a few corner lots that were subdivided during the depression. A smaller home was build in the part of the back yard that had been divided from the main lot (much like you are planning to do with your garage/apartment.) That might explain what appear to be marked utility services that lead nowhere.
Yes, the house was built in 1925.
Are you intending to have separate utility services for your garage/apartment, or will you try and branch off the services to your house? Have you considered how and where they will be located?
Well, that's still a little up in the air. I've been researching, and see that I probably can't tap into the meter on the house which is currently 200 amps (upgraded from 100 amps just last summer). If separate service, then I have to pay commercial rates, which I'd rather avoid, but may end up doing.
The utilities enter my house on the other street, and are in the corner of the house, if you look at the picture earlier, it would be on the left hand corner of the house (orientation being right hand corner is against the existing driveway, so left hand corner is further to the left). I'd love to just dig the trench across the yard, pass through where the current driveway is and into the garage, but need to have someone come take a look.
I don't see anything in your plans for HVAC or water heater. With the space limitation, it would seem to be a good candidate for a tankless water heater (located in the garage?) and mini split heat pump. A stacked washer and dryer could also save a couple of square feet.
Yes, I'll be going with a stacked washer and dryer. I'm still thinking about the hot water heater, can easily go in the garage, or in the laundry room (if code allows). Would definitely be on demand, but still need to work out the gas plumbing for the building.
Regarding HVAC, I'm just now starting to research what would be best. At first I was wanting to avoid running gas plumbing, but it looks like it probably makes the most sense in the long run. Mini splits seem like the right way to go, but I need to learn more (cost, location, capability, etc...).
While you are in the thinking phase of the project, have you learned exactly how the zoning calculates square footage for their limitations? The apartment sure would be nicer if you could cantilever the second floor out a foot or two (sort of like a garrison colonial.)
I'm pretty much at the limit without needing a variance on % of the lot used based on 1st floor square footage. But still need to double check the overall calculation.
You might be able to sell the idea of a "mother in law" suite easier than an apartment.
The difference between the two would be the utilities would be a part of and combined with your residence (as opposed to separate meters) and there would not be a true kitchen in the unit, a wet bar, but no cook stove.
After the final inspection you might bootleg an electric stove in.
Great advice. I'll give that a try, but again, not sure on utilities being able to be combined or not yet. That's part of my thoughts in making this an easier sell to the zoning board as well.
Thanks again for all the thoughts. I'm hoping I can get this through and am giving it my best shot. If I end up not getting the variance, then I'd likely do something a little smaller with the same foot print. And use the money saved to escavate the basement down and finish it instead. Would much prefer the garage route though.
