Why? I’m closer to twice that age and for what I do, a two post works much better.Consider a four post lift, unless your knees are south of thirty five years old.
I was thinking the same thing. I dont see what difference 2 or 4 post makes on your knees ???Why? I’m closer to twice that age and for what I do, a two post works much better.
To be honest I’ve been looking at the clear floor lifts that are for 9000lbs but brand wise I’m not sure yetWhat lift are you looking at buying? There's a lot of different 2 post lifts out there
Do you have pics of your existing floor? If it is really cool looking old world or last century looking I would want to save as much of that look as I could. I’m big into the old school vib and an ancient looking floor of wood or stone would be worth working around a solution to keep it original as much as possible. So a two post might be possible with hiding either deep concrete pylon piers into the ground leaving the rest of the floor original or even tagging the stones positions and digging and pouring two larger footings and reinstalling the stones with just the concrete pads and j-bolts showing. If the floor isn’t worth that kind of effort then disregard the above.So I have a little building that I wanna put a lift in but it only has stone for the floors I was thinking about pouring a pad 6 inches thick for a lift probably 10x15 will that be enough area withstand a lift
I have both. I rarely use the two post. My knees hate it.Why? I’m closer to twice that age and for what I do, a two post works much better.
It’s just a gravel on the groundDo you have pics of your existing floor? If it is really cool looking old world or last century looking I would want to save as much of that look as I could. I’m big into the old school vib and an ancient looking floor of wood or stone would be worth working around a solution to keep it original as much as possible. So a two post might be possible with hiding either deep concrete pylon piers into the ground leaving the rest of the floor original or even tagging the stones positions and digging and pouring two larger footings and reinstalling the stones with just the concrete pads and j-bolts showing. If the floor isn’t worth that kind of effort then disregard the above.
Okay crushed stone, got it. Pour a floor. A lift that you can’t roll transmission jacks and carts and other heavy wheeled equipment around under a vehicle is not very useful. You can’t be dragging stuff in and out from under the car on gravel. You would no doubt end up laying plywood down until you did pour concrete and the lift would then need to be dealt with.It’s just a gravel on the ground
You really need to pick your lift first and then they have the slab requirements in the manual. I'm pretty sure your intended slab size and thickness will work for 99% of all lifts but you really need to check with the lift MFG.It’s just a gravel on the ground
I think that's fine advice, and I also think nobody with an ounce of sense would do otherwise due to the width. You literally can't not do this in this situation. I don't think there will be anything in the manual about how far into the universe the slab should extend lengthwise, but I hope I'm wrong.You really need to pick your lift first and then they have the slab requirements in the manual. I'm pretty sure your intended slab size and thickness will work for 99% of all lifts but you really need to check with the lift MFG.
I don't know anyone that has a two post and hates it (other than you, and I don't know you)..... Where I know a few that have 4 post and wish they had a 2.All this being said, many of us have two post lifts and hate them. Life with my four post lifts is much better and you won't need as much concrete for them.
There are a number of different standards. This is the section from the rotary book I had handy. I'm sure its been updated since then.Hi all. I'm new here and also looking at lifts. Last week I spoke to the Mohawk rep and asked about the concrete thickness. We didn't discuss the width and length of the pad. I'm sorry didn't.
Basic rule per Mohawk, if the lift has a horizontal cross tie, 4" is the minimum. If there's no cross tie, 6" is the minimum.
Thank you!!There are a number of different standards. This is the section from the rotary book I had handy. I'm sure its been updated since then.
It should illustrate the idea, though. There are different standards. Each standard has numbers for minimum concrete thickness, strength, anchor depth, etc.
They also have a minimum distance for the posts to the edge of the pad or an expansion joint. To answer your question about dimensions, I would first decide which standard you want to follow. Then the instruction manual for the lift will show you its footprint.
And remember, these are *minimum* numbers. There's nothing preventing you from going bigger and better. As was mentioned above, if you know where a left will be, you can make it a foot deep there and not run up the cost. For my lift, I made the thick section of the floor about 4x13ft, and 12in deep. That ends up being about 1.5yd. At the time, concrete was around $170/yd for the contractor price. It doesnt cost any more labor for them to finish it. So for $250, you are twice as thick as even the most demanding of the standards, with a footprint large enough for most 2 post lifts a home gamer would be using.
To each their own I guess, but I don't understand the objection to a two post lift.
I just replaced a differential in my Corvette a few weeks ago. I ended up dropping the entire rear suspension and drive train aft of the engine. I guess you could do it on a four post lift, but it certainly would not be as convenient.
For routine maintenance, such as oil changes, tire rotations, and brake pad changes, the two post makes it really easy. I have some tape marks on the floor for our two daily drivers. Drive to the mark, kick the arms in with my foot, hit the up bottom.
My lowered Corvette is a bit more work, but certainly not enough to not have a two post lift. I'm 71 and not in the best shape. You can still reach the floor and tie your shoes, can't you? No more trouble than that to get a car on a 2 post lift.
Yea, that's my concern. Pouring concrete in my shed in a couple months and want to record that but really want to possibly put lift at angle and than the 2 ft sq rebar will certainly become a factor. Perhaps don't put rebar in that area at all?I would record where you put the rebar. Drilling into it when you're anchoring the lift *****.
