3 phase motor maybe weak
jbird5986
Hey guys I got this compressor though it calls for 5 horse motor I been using a 1 because I had a bunch but I got this 3 phase and it won't even turn it and also if anyone cares to guess why the air compressor in the pic isn't on all compressors let me know.Im fairly certain the motor has been converted to run 220 I'm just thought it would have little more torqe
J
jbird5986
The story behind the compressor is I wanted to know if it would help to have 2 and everywher i looked it up everyone was arguing about so i tried it fyi IT DID NOT. The electric motor is dual voltage it will run off either.
The Cobbler
dual voltage is not the same as a single phase or 3 phase motor.
and as already mentioned at least 2 times, a 3 phase motor, which you have shown, will not run on single phase..., which is probably what you're trying to hook up to
J
jbird5986
Well that explains it although its been on a fan for months running but it doesnt require near the torque as that compressor does thats why i swing a hammer but im nearly positive ive used them before but then again i used to drink a little back then.
Davefr
OR
You need 3 phase power for a 3phase motor to work.
Actually a 3 phase motor will "run" on single phase power. However it won't start nor develop full power. I sometimes test them on single phase. Give them a manual spin and they go.
As for that compressor setup it's a kludge.
jar944
Northern VA
Fair, and I agree.
However I didn't think he wanted to pull start it and only have 2/3 the hp
you were doing whats called single phasing the motor, running it on only 2 legs which can overheat and burn up the motor.
as said above, you need 3 phase power or a converter/VFD to run that motor.
also please put some guards on those belts.... and its pointless to power a compressor with 2 motors like that....
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
A swedish nuclear power station had one( out of 4) 3 phase 10 kV networks single phase due to a faulty incomer CB ( 1982 vintage)
Three phase motor load 26 MW, from 150 kW to 2 MW units.
All overheated in less than 3 minutes and were scrapped.
As was the feeding 25/10,7 kV 36 MVA transformer
Ola
Ola
Oregon rock crusher
West of Salem
Besides the three phase motor not providing any tourque while only hooked up to single phase it is very difficult to get two motors of any type to work together driving anything. Even small differences in rpm will make them fight each other causing either belt slip or over heating. Even with matched motors, new shives, and new belts it is best to start one first and bring the second up to speed before starting it. That is unlikely on an intermittent load like an air compressor. Ed.
J
jbird5986
I found some really good prices on 10 and 20 horse 3 phase but that rope startin looked like a good way to lose arms fingers maybe some toes
Cruzan80
Denver, CO
Why do you feel you need a 10hp motor? Do you have the power to supply a 10hp motor (even de-rated)?
cannuck
Rural SK
That's what I was going to bring up as it looks as if the two pulleys are not the same diameter. Also: two different motors from 2 very different designs are not likely to have exactly the same RPM (2 pole vs. 3) so the smaller motor in the pair will not be running at locked rotor RPM and will soon overheat. On top of all that, it looks like a capacitor zip tied to the 3ph??
