30x30 Pole barn
scutty83
Southwest Missouri
This is my build 30x30 with 8/12 pitch attic trusses, also will have 10' lean to on north side (left) Will post more pics soon.
scutty83
Southwest Missouri
Re: 30x30 Pole barn: More Pics
More pics
z385488
Columbus, GA
Looks good I started a 24x32 last week. My thread is in the test section, I still haven't gotten the security code **** figured out yet so I can post pics. How are you posting yours? What has the temps been like in your area? The heat is rough here in GA. I plan on setting my trusses today, sure wish I had your tractor set up.
scutty83
Southwest Missouri
z385488: the tractor setup saved some serious heartache as I was able to lift each one directly in place, probably could'nt have done it without it as each truss weighs nearly 400 lbs. Another big help is to cut pole sections and fasten them between the double truss carriers that way you have something solid to nail to and avoid toe nailing altogether.
The heat has been awful! 100+ nearly every day for the past three weeks, as far as posting the pics, it was a bear. I was up until 2 last night trying to figure out the security token deal. I ended up just uploading one or two at a time then it finally took.
MG30: The layout is an enclosed 30x30x10 main shop with 3/0 entry door, 12x8 garage door, and an 8x8 garage door in that order on the front gable wall. The lean-to will be 10' wide and run the full length of the left eave wall (as your looking at building in the picture). The attic space is 14' wide and 7' 3" headroom in the center. As far as finish it will have wainscoting, 6 exterior vinyl windows and 12" overhangs.
scutty83
Southwest Missouri
Been a while since I've added pics, almost ready to start laying down metal, just have to finish the lean to.
