36'x48'x17' Pole Barn - Floor plan ideas
tomralph
Colorado Front Range
I need a sanity check... been looking at the floor plan for months and I want to make sure I have the right size, and that I didn't over look anything critical.
I went with a 17' tall ceiling for an RV in the future with a 14' overhead door. It was 16' but I decided the extra 1' would allow my to put a second story in the back on top of the Woodwork shop and extend it cantilevered over some of the shop space. The taller ceiling is only needed on 1 side of the workshop, not both.
Going to pour a 4" thick frost protected slab with radiant piping in the floor.
Running NG to the workshop will be a chore, it is on the opposite side of the lot form where the NG enters and where the meter is. Can I do the radiant flooring with electric? Possibly offsetting the cost with solar on the roof since 1 side is a southern facing slope in Colorado (lots of sun).
I can't increase the size without a lot of pain, though I am already feeling that it should be larger, I haven't drawn any of the second floor yet. Maybe that will help cure the 'I want larger' bug.
OutlawDrifter
KS
I am told it would be... 4000 psi with fiber + 6"x6" wire mesh. I don't have anything 'heavy' yet, reading here it looks like 4" should hold a 2 post lift
i would decide which lift you are interested in and read through the manual to see what the minimum recommended depth and psi rating the concrete needs to be. 2 posters require more than a 4 poster. you're probably looking in the 5"+ range at a minimum. i personally would not stand under a 2 post mounted in 4" concrete.
astroracer
Mid_Michigan
Most 9 to 10 K two post lifts require 3 to 4K PSI concrete at a 4" minimum thickness. I 've been standing and working under mine on 4" concrete for 6 years, no worries. :)
4K with fiber and mesh is overkill for a 2 post lift.
Mark
astroracer
Mid_Michigan
Just for shits and giggles I copied this from BendPaks site.
Depending on the lift, they don't start recommending 5" of concrete until you get upwards of 35K on some of them. others go up to 8" but that's more then most of us need to lift.
Lift owners and end users are responsible for the safe installation of their lift. The figures below represent suggested concrete specifications, but should not be construed as actual requirements for your building, facility or application. Because local and statewide building codes may change and / or vary, always check with the building architect before installation for additional guidance on UBC compliance requirements. In no event shall BendPak Inc. be liable for special, consequential or incidental damages for the misinterpretation of this information. BendPak Inc. reserves the right to make changes to this document without incurring any obligation to notify the public that changes were made.
4-POST LIFTS
DESCRIPTION
MIN. CONCRETE SPECS
HD-9ST-B
9,000-lb. Capacity / Four Post Lift / Narrow Width
3-1/2" Min. Thickness / 2,500 psi
HD-9-B
9,000-lb. Capacity / Four Post Lift / Standard Width
HD-9STX-B
HD-9XW-B
HD-14SS
14,000-lb. Capacity / Space Saver
4" Min. Thickness / 2,500 psi
HD-14
14,000-lb. Capacity / Extended
HD-14X
14,000-lb. Capacity / Extended / Limo Style
HD-14STL
14,000-lb. Capacity Tall Lift / Space Saver / 82" Rise
HD-14ETL
14,000-lb. Capacity Tall Lift / Extended / 82" Rise
HD-18
18,000-lb. Capacity / Standard
HD-27
27,000-lb. Capacity / Standard
HD-27X
27,000-lb. Capacity / Extended
HD-35
35,000-lb. Capacity / Standard
5" Min. Thickness / 2,500 psi
HD-35X
35,000-lb. Capacity / Extended
HD-40
40,000-lb. Capacity / Standard
HD-40X
40,000-lb. Capacity / Extended
HD-14LS
14,000-lb. Capacity / Alignment
HD-14LSX
14,000-lb. Capacity / Alignment / Extended
HD-14LSXE
14,000-lb. Capacity / Alignment / Limo Extended
HDO-14LSX
14,000-lb. Capacity / Alignment / Extended / Open Front
HD-18A
18,000-lb. Capacity / Alignment
HD-27A
27,000-lb. Capacity / Standard / Alignment
HD-27XA
27,000-lb. Capacity / Extended / Alignment
HD-35A
35,000-lb. Capacity / Alignment
HD-35XA
35,000-lb. Capacity / Extended / Alignment
XR-12AE
12,000-lb. Capacity / Scissors Alignment
2-POST LIFTS
DESCRIPTION
MIN. CONCRETE SPECS
XPR-9F
9,000-lb. Capacity / Floorplate / Chain-Over / Narrow
4" Min. Thickness / 3,000 psi
XPR-9FX
9,000-lb. Capacity / Floorplate / Chain-Over / Wide
XPR-9FD
9,000-lb. Capacity / Floorplate / Direct-Drive / Narrow
XPR-9FDX
9,000-lb. Capacity / Floorplate / Direct-Drive / Wide
XPR-12FD
12,000-lb. Capacity / Floorplate / Direct-Drive
6" Min. Thickness / 3,000 psi
XPR-10C
10,000-lb. Capacity / Clearfloor / Narrow
XPR-10CX
10,000-lb. Capacity / Clearfloor / Wide
XPR-10AC
10,000-lb. Capacity / Asymmetric Clearfloor / Narrow
XPR-10ACX
10,000-lb. Capacity / Asymmetric Clearfloor / Wide
XPR-12C
12,000-lb. Capacity / Clearfloor / Triple-Telescope Arms
XPR-15C
15,000-lb. Capacity / Clearfloor / Standard Arms
XPR-18C
18,000-lb. Capacity / Clearfloor / Standard Arms
8" Min. Thickness / 3,000 psi
SCISSOR LIFTS
DESCRIPTION
MIN. CONCRETE SPECS
XR-12AE
12,000-lb. Capacity / Scissors / Alignment / Extended
SP-7X
7,000-lb. Capacity / Scissors / Full-Rise Platform Style
SPECIALTY LIFTS
DESCRIPTION
MIN. CONCRETE SPECS
PL-6SP / PL-6000
6,000-lb. Capacity Single Post Parking Lift / Deck
PL-6SPX / PL-6000X
6,000-lb. Capacity Single Post Parking Lift / Deck / Extended Rise
PL-7 / PL-7000
7,000-lb. Capacity / Two-Post Parking Lift / Deck / Standard Rise
PL-7X / PL-7000X
7,000-lb. Capacity / Two-Post Parking Lift / Deck / Extended Rise
LR-60 / LR-6000
6,000-lb. Capacity / Low-Rise Lift
LR-60P / LR-6000P
6,000-lb. Capacity / Low-Rise Lift / Portable
MD-6XP
6,000-lb. Capacity / Mid-Rise / Frame Lift / Portable
P-6 / P-6000
6,000-lb. Capacity / Low-Rise Lift / Pit-Style
P-6F/ P-6000F
6,000-lb. Capacity / Low-Rise Lift / Pit-Style / Flush Mount
T
tomralph
Looks like the life needs 4" @ 3000 PSI for a 10k lift, going to a 12k lift it wants 6" @ 3000 PSI.
I will probably dig out where the lift if going to land to be 6" deep and just 4" for the rest of the floor.
larry_g
oregon
I'm goingto ramble here a bit but hopefully make some sense.
I assume that the enclosed shop within is a wood shop? To get materials in and out you will be maneuvering around the lift, pain in the *** to me.
I assume the tractor has a loader, think about using it to load materials into the shop and the lift is more in the way. can you move the enclosed shop to the front of the building to have direct access outside?
Are you having a storage floor on top of the shop? Think about access to it with the loader. The storage on top could replace a section or two of pallet rack giving you more floor space.
You have a OH door in front of the tractor. Is this for getting the tractor in and out? Do you have access to maneuver if the house is right there? you show 8'...
The pallet rack is blocking part of the 8' door opening. Think of any swing of something coming through the door. If you do bring the tractor through that door your going to tight without angling the tractor. Maybe swap the positions of the 8' door and the man door next to it. or move them both to the right 2-3'.
Add the lift arms onto the squares representing the lift poles, they do take up room your not accounting for. Add thickness to your interior walls and mark out swing room for the doors as that is also floor space you cannot use.
You can also look at my build below as it is 36x48 also
lg
no neat sig line
T
tomralph
lg
no neat sig line
Thank you for the response! It made sense to me!
The house is about 50' away, the 8' cement pad is just a landing pad outside the door. The pallet rack is close to the doors, as you said probably too close.
The lift being in the middle brings up a VERY good point about having to maneuver around it to get stock/material to the wood shop. HMM.
Thank you again! I will update the drawing and post sometime soon, I have been using SketchUp to 3D model it and see just how things are in the work shop.
astroracer
Mid_Michigan
Yup, like Larry said, add the thickness of the walls into your drawing. You will lose about a foot of interior space when you do that. Your 36' building turns into 35' on the inside.
Also, try to keep ALL of your overhead doors at least 4' off the interior walls. Reason being, if you look at the clearance you have in your drawing from the wall to the trailer, you have 2 .5'. That will actually be 2' when you add the wall thickness. You will have a difficult time walking down that side of the shop, let alone the stuff you will NOT be able to store there because there is no room. This is unuseable space and keeping the OH doors off the walls gains usable storage space and walking space that is otherwise lost.
I try to shoot for 6' off the inside walls. Room for benches, (pallet racking), working and opening car doors.
Mark
astroracer
Mid_Michigan
I would also flip your layout. If the house is on the tractor side put all of your benches on that side of the shop as well as the work space. Put the pallet racking on the other side also to get it out of sight and out of the way. There is no sense having to walk past and through dead storage space to get to the working space.
Mark
And center the lift on that 10' door. :) AND... You don't need extra thickness under the lift bases. A 4" monolithic pour with mesh will be plenty strong for your 2 post. Don't "mentally" lock your lift into one spot. You may want to move it someday and you can put it anywhere you want this way. :)
Mark
