Between 485 & 705 SQ/FT 3rd time's a charm with a 3 car workshop
L
loganb
Omaha, NE
Did you pick up a Domino I can't remember or did you do this with some other jig?
Yeah.....I had a moment of weakness....lol. More details on a thread I put here:
Thanks for pointing that out, honestly forgot I hadn't included that in here
Plane till looks nice! I like the two-tone with the walnut bits
I admire your ability to slowly chip away at things. All those small progresses add up.
Thanks sir! Part of it is it's a nice escape for a bit here and there....but I'll call out that I'm honestly impressed and very happy with how much more often I do "escape" out there with it being attached and conditioned for all seasons. Especially with the kids at the ages mine(and yours) are....it's often tough to get too far away. But with it attached it helps a lot. I broke building code and put a door stop on the house to garage door(should be self closing...which it is...as long as you don't engage the door stop lol) so I can prop it open and jump out for 5 or 10 minutes while supper is cooking and kids are kinda behaving...or encourage them to come out and "sweep" more often when I'm still within earshot/easy response range. I'm doing more of my cleaning up/putting away during those short little stints which is maybe helping get some of the slightly larger tasks done in the 60 to 90 minute stretches I might get after they go to bed or on a weekend.
It also helps when I remember to actually take a lunch break, drive the 8 or so minutes back home and knock out the "quick kills" such as getting the new flag and spotlights installed
L
loganb
Omaha, NE
We have a pretty swell view out of the 2nd floor looking to the Northeast that lets us see a lot of different neighborhoods and city shows....so this combined with the "enthusiatic" display put on by some of the neighbors had our contribution to the local firework tents at $0 this year....I'm sure that'll end soon lol
L
loganb
Omaha, NE
Few small projects in the works...time has been sparser here between weather, work and a ridiculous amount of family drama
For @nicholam77 l did get some progress made on the vacuum clamping setup...some may be a stretch though. Pump showed up, immediately had to take it apart as that T-fitting couldn't be removed with the motor attached....put a new fitting in so I could just have standard NPT threads....available fitting I had wasn't exactly long enough....not holding vacuum like it should...haven't gotten back to it.
Couple little hand tool holders. In the background in the 3 clamps is a holder for the marking gauges strewn about. Foreground is a holder for handsaws and card scrapers. Ripped some slots in a piece of mahogany then glued and end back on for a "bottom for them to rest against. Will smooth all edges, put some Danish oil on then find a home in an open plane till spot
And the current state of the Sanctuary of Scattered Sawdust....
The overarm guard/dust port does a wonderful job of keeping the tablesaw debris to a minimum....but on non thru cuts or crosscuts it doesn't help so much....still not bad though.
L
loganb
Omaha, NE
Quick sand, round over on some edges and slather on Danish oil and ready to figure out how they'll be mounted and then to install. Probably going to screw from the back so fasteners are hidden but some old school brass slotted screws did cross my mind
L
loganb
Omaha, NE
Some mindless sharpening moved to the kitchen so I could bless my wife with my magical aura. Helps me feel productive and not like I'm totally abandoning her once the kids go down
Sandpaper on glass, then 2 sided diamond stone with Veritas angle guide. Starting from scratch on this plane blade for a #5. Primary angle of 25 degrees and secondary at 35
But 30 minutes or so later
Google says paper is 4 thou thick...so not yet paper thin shavings but getting closer on a plane that needs a lot of cleanup as well so pretty happy with it.
Xti04
Thats the same method I use for my plane blades and chisels. Float glass with sand paper from 120 grit up to 3000 grit. Once they start to dull out, touch up with the finer grits to bring them back to shaving sharp again.
L
loganb
Omaha, NE
For anyone on the fence about the benefits of a mini split for the attached garage
Having overflow space in air conditioning for a short notice family gathering
The brownie points from your spouse will fall from the clouds like rain drops in the monsoon season for facilitating a family gathering
Doesn't hurt that they ate 20 lbs of pulled pork, this was 2 pork shoulders, overflowing a large crock pot at the start and basically gone in 1.5 hrs
L
loganb
Omaha, NE
Some very random pictures here
This may be what happens when your grocery store that you do online ordering with changes the unit of measure for ordering banana's from each banana to bunch and you don't pay attention
Of the things this could have happened with, this one is at least not that expensive and easy to eat
Old coffee maker finally got retired after 10 years....see if the stellar reviews on this are accurate.
In preparation for the spur of the moment....well like 2 day notice party....finally put the propane firepit back together. Only been here for 5 years....lol. Next I need to figure out why the ignitor isn't working after sticking a new battery in. May just have the electrodes too far apart but lighter was easy way to fix on a time crunch.
More meat pictures..
2 ****'s, mustard binder and a mixed up dry rub, scored the fat cap pretty deep. Sat in the fridge for 12 hours of so with the rub on, stuck on the pellet smoker before going to bed, stuck them in the foil pan with a cup or so of apple juice in the morning and pulled them off the smoker when probes said about 200 or 201. Let them rest for a couple hours then shredded and stuck in a crock pot on warm till serving time. Worked really well and was very well received, thought it was moister than the last time I did a speed cook at 325 or 350 and had it done in 6 or so hours. Was really expecting there to be some leftovers....but there wasn't so guess I have to light it up and do another one or two for the freezer...darn.
But in a process of burying the lead a bit....the father in law is now at peace after 7 weeks or so in hospice.
For such an event, things went about as well as we could ask and he's now at peace, the family all got their time with him and the turnout for the events was successful. With much of the family traveling from out of town, we invited all of his siblings and their families over after the visitation for a chance to relax and eat without the headaches of restaurants or hotels which turned out really well. It put 35 ish adults and a dozen or so under the age of 12 in the house with about 2 days notice....but I volunteered to do it so couldn't complain to anyone but me but we are really glad we did it as everyone enjoyed the opportunity to get together and relax a bit in the middle of a challenging scenario.
Now we have some time to come down a bit from the checklist driven to do list that's been the last week as we got things ready. The wife is the executor/personal representative for the estate which was at least pretty squared away (as far as we know) so we get to start dealing with that in the near future but we have some time on that.
It's been a fairly long and often tumultuous road to get here and we're definitely not adjusted or "fine" yet, but as we've been sitting around discussing things...2 pieces of advice that we've learned that we'd do differently the next time. And to only have 2 at this point is a blessing so we're thankful for that
Hospice: We waited far too long to learn about hospice, what it does, how they do it, learn about in home hospice vs at a hospice house etc. The wish was to stay at home as long as he could, and we let that go too long and got into hospice later than we should've. Knowing it was the backup plan, we should have vetted it out earlier than we did but the team there was great and was used to it...but would've lowered the stress I think with both us and her father had we all had a better knowledge of what that option looked like if we had to pivot from the primary plan
Prepaid funerals: 10 years ago or so they prepaid funeral expenses thru some sort of policy with a funeral home so we were kinda "locked into" using that company and were not impressed. We used a different company a couple years ago for her sister's arrangements and yes, they were more expensive but the quality of service and support was night and day different and would easily pay for it again. The facilities at the more expensive one were nicer, bigger etc but it was really the people that made the difference. We were also told repeatedly by her folks that "everything was done" and "all wishes on what he wanted were listed out"....yeah.....there were some selections made like casket, headstone was already picked out and in place etc so the amount of decisions we had to make was much reduced...but definitely not "all done"
I know there are some legal scenarios like Medicaid eligibility planning where prepaying funeral expenses with a 3rd party is good practice, but we would've been better off had they just setup a dedicated "investment account" with a transfer at death or similar arrangement for quick access when needed. The costs that they were "guaranteed" at 2014 rates vs current have basically doubled....but when you compare to what the general market has done over that time....just setting aside the money would've been a better deal for the family.
Now we try and figure out the new normal, get to work to empty his house so it can be sold and all the stuff that comes with that. In a slightly more happy note we agreed a couple months ago that after this was "over" the wife and I would take a trip(no kids) somewhere.....so we get to figure that one out. Debating on a short duration cruise, but also considering something like Sanibel Island, FL or Smokey Mountains....so if anyone has favorite spots for "relaxing" type venues in the continental US for 4-5 days happy to hear them!
legenddc
Really sorry to hear about your father in law. Your family has had a rough few years. I hope dealing with the estate isn't too difficult.
On a happier note, it seems like some banana bread is in your future! :lol: You'll enjoy that coffee maker. I got my wife the glass carafe version for Christmas and she really enjoys it.
L
loganb
Omaha, NE
Good luck with the dealing of the estate. I know it's your wife who is the executor of the estate, but it helps if others are there to support her. Hope it goes well!
Thanks guys! The estate settlement shouldn't be terrible and this is the 2nd time the wife has been tapped to do this in the last couple years so we at least know the general process. There are also current estate planning documents here so that will be a big help.
Biggest thing will be getting their house emptied out so we can sell it. Lot of stuff, and not a ton of it overly valuable but nobody in the family needs any of the furniture so we'll have an estate buyout or sale of some sort to get it emptied out. Once the house is ready to list, it'll sell quick as the housing market here is still pretty hot due to limited supply and it's in a good location. Some lawn equipment and outdoor power tools to sell which I'll probably do on FB Marketplace, 2 vehicles to sell....nothing that some time and effort can't handle.
OutlawDrifter
KS
Sending you, your wife, and family my deepest condolences, thoughts, and prayers. Even when you can see the end, its never easy.
In regards to your trip, I'm biased, but knowing what your(and my) weather is right now...and how I felt after losing my people, I'd head for the mountains for cooler weather and seclusion! Book a cabin and disappear for a few days.
Boostingaz
Indiana
@loganb
Very sorry for your loss my friend. Glad that you guys got your time and goodbyes.
Hospice is always a "tough sell" to families. It's a great resource and it's really a quality of life tool not a death sentence as everyone perceived to be. Everyone hears the word Hospice and immediately pushes back or is in some sort of denial in a sense, which is understandable. We have had people discharge and come off of services as it actually facilitated improvement. So you are exactly right in your learning that it really needs to be a forethought not an afterthought.
Praying for you and your family now in this time of transition to settling affairs while emotions are still in the picture. It's a tough time and praying for peace within the family and a smooth road for you all.
Xti04
Sorry to hear about the loss of your father in law. It sounds like hospice was a help to your family and it makes me happy to hear that. So many people push it off far too long and it really is amazing what those folks can do for your loved one. Hopefully as you navigate through all of this your family finds some peace in all of it. Prayers for your family. When vacation time comes fall in the Smokies is incredibly beautiful, but you will have to fight with every other person who comes here looking to see the incredible fall colors. Temps will be much nicer soon, humidity is stifling right now and there hasnt been much breeze to help out either.
Trapps
The Detroit Zoo
Sorry for the loss, Logan. I would mimic your Hospice sentiment. For us with my father, it was a service I wished we’d engaged earlier in the process. Palliative care too.
Please review the Moccamaster when you’ve had a few pots…
gearhead1960
My sympathy to you and your family on the loss of your FIL, Logan. I can mirror the Hospice sentiment, also. For my mother we called them in as soon as the Oncologist said they could do nothing more for her. Hospice was super fast in responding and handled a lot more than we could have on our own. While she didn't last more than 3 days from when they were involved, they relieved a great burden. It's sad that Hospice sometimes is misunderstood.
nicholam77
Minneapolis, MN
Very sorry to hear that, Logan. 100% agree on the hospice care. We went through similar a few years ago (after 2 year pancreatic cancer diagnosis with my mother-in-law), and as it worked out she did not do hospice at all and passed in her own home. Fighting a terminal illness (I can only assume) is a very personal thing and everyone has to deal with it on their own terms in the way makes sense to them. For family, it's hard to always know the right thing to do and at the right time. I won't get into it further, but basically I'm glad to hear it went as well as it could have for your father-in-law, surrounded by family, that's the best you can hope for.
I think a solo trip is a fantastic idea. We've only been able to do that once since my kids were born (just before covid, too!), and it was amazing. I love my kids to death but honestly I've been dreaming of it ever since lol. I've never been to Sanibel Island, but Florida by the ocean is always good. Some spots we've enjoyed are Vero Beach, Naples, and the Keys. Less resort-y, but I've also enjoyed the big beaches and surf towns in the Carolinas. As well as Hilton Head. For something different than the beach and depending on the time of year, Sedona is quite beautiful. I know you said continental US, but at least from Minneapolis there are 4 hr direct flights to Cozumel and Puerto Vallarta, might be an option if you're not opposed to Mexico.
The Moccamaster is great. It works fully auto but I like to keep the cap off and stir the grounds occasionally as it drips the water.
L
loganb
Omaha, NE
Appreciated. Wish I didn't have more of these in the near future but with 3 grandparents all on the far side of 90....yeah.
I'm probably more partial to the mountain option, my wife is more partial to the beach one...and Xti's comments below about the crowd confirms what I saw online and not looking for mass of humanity....maybe we do both?
@loganb
Thanks sir. Figured in your line of work you'd had a lot of interactions with them. When they said he was no longer in remission back in late January/Feb and started talking about next steps and eventually did radiation is when we (wife and I first then adding in father in law) a better handle on "hospice". It was both a blessing and a curse that in the last several months before hospice his condition gave him enough physical strength to be mobile-ish(with wheelchair or walker) but the cancer had also caused enough brain function changes that he wasn't properly processing his current condition all the time. That combined with a heavy dose of stubborn-ness made for a challenge....but as I often say...."Experience is what you get when you don't get what you want"....so we are now more experienced
Definitely a significant relief. The 2nd night he was there was probably the first night we had slept well in 2 weeks as we weren't worried if he fell, will the overnight health care team need a lift assist etc...It took some adjustment for my wife to better understand the purpose and intent there, but the family and friends were pretty good about visiting him often, his wife was there most days, so we're hopeful that at the end he understood he was where he needed to be, even if he didn't want to.
Definitely agree with the sentiment, looking back I wish we had been "encouraged harder" to learn more about the options if treatment no longer is working earlier on in the game instead of at the end. I'm sure there have been studies and research done about that and when to talk about those things....but palliative care/hospice wasn't presented to us till Feb-ish, at which point we should've pushed harder on our end to do the learning without him involved to get us up to speed. We would've preferred to have done in home hospice, unfortunately he felt he was more physically able then he actually was in the last month at home, leading to some potentially dangerous situations for all which made a hospice house with additional staffing a need.
Moccamaster will get a review.....so far it's made 2 pots....only 1 with fresh beans.....an improvement over the Mr Coffee for sure....I also think it's an improvement over the machine at work but I wonder a bit if that's the bean's there using. I don't want to have to take a thermos to work for better coffee when the rather expensive machine is like 60' from my desk....but I might!
Your experiences sound very similar to mine, sorry we get to share that. Saw a meme/video the other day reiterating our generation/age range as the "sandwich generation" where we're sandwiched between caring for both our kids and our parents at the same time....we often joke about why did we move back closer to family to get the mess we've had the last 5 years but I have no idea how we would've managed it without being close....it would've forced us to move back in a much more hasty manner so things work out in the end.
We've never done a solo trip either....honestly not sure how to travel without them anymore! We've previously done several trips to Tampa area and seem to enjoy Gulf side more than Ocean side. I've done some work time in Charleston SC, but never any exploring. Arizona was something we were kinda looking at, partially cause the babysitters are in Vegas and we kicked around the idea of flying there, dropping the kids off with grammy and pappa and then dropping the top on their Pontiac Skyy and heading south to Arizona but this is probably going to happen after school starts (3 weeks out)....she's only a 1st grader but the grandparents already told us they'd come here to watch the kids so keeping them on the normal routine with school/daycare is easier on them.
Mexico would be an option....except wife's passport is expired lol. We may do this as a no kids trip, then follow it with a family friendly cruise....Nov/Dec/January ish. Couple coworkers with similar age kids had strong reviews on both Royal Carribean and Carnival cruise lines with kids.
Trapps
The Detroit Zoo
If Charleston is on your list I can make some recommendations. My son went to the Citadel and we spent a fair bit of time there.
Arizona has much to offer, from the canyon and Sedona to the valley and everything in between. Sedona has amazing scenery, its somewhat mystical and spiritual, and it is 'close enough but far enough' to escape to. A drive up or down Schnebly Hill Road will give your a real feel for the area. I've got a few rec's there and in the Phoenix area too. Taliesin West and Arcosanti are well worth it side trips.
Our first trip without the kids was a long weekend in northern Michigan (about a 4 hour drive for us). You could fly into Traverse City. If that's an interest I have a ton of recs for you.
Xti04
Logan we did a few Carnival cruise with the boys at a yound age. My youngest was turned one the day we boarded his first cruise and his brother was 3.5. Kids loved the cruises, but we alternated who would stay inside for naps( usually me because I like naps) and there is also child care so you can have a minute with the wife as well. As they got older they have asked to go on another cruise but covid and vax restrictions kept us from booking another. We would probably do another one now that they are older, but have really been liking the Tampa/ Clearwater area the last few years because its a cheap direct flight there.
Boostingaz
Indiana
Acrosanti 🤣🤣🤣🤣🤣 sorry. Only if you enjoy being crammed in a basement that reeks of weed and un-showered hippies. We went there for a bluegrass festival that I'll never forget and not in a good way. Let's live a commune lifestyle etc etc etc while the leader/founder flys in from Scottsdale on his million dollar helicopter. I was less than impressed.
zanyad
NE Ohio
So sorry on your loss. I'm glad to hear the family party went off well, and that the estate is in good hands. I also wanted to add to the positive chorus about hospice. We used the same hospice for both my father and grandfather, and both experiences were great (the hospice staff and services, not the reason for the care).
L
loganb
Omaha, NE
On the hottest day of the month should've called an audible and said "no car show with kids"...but we weren't that smart...
In good news they had a fun picnic lunch in the park and the kids are napping for a bit longer
Couple more unique/less common ones
Ford Econoline....economy is no longer it's function...
For @Blackbyrd
'68 or '69 Camaro....looks fairly stock from the interior but something doesn't look original under the hood...can't put my finger on it
I bet it's a hell of a lot of fun to drive....looked great
Don't see a ton of Corvair 95's around here (or probably anywhere?)
Possibly the original, kinda wheelchair friendly ride with the side ramp?
And a pretty sweet looking '34 Chevy Phaeton....the fact it was purple was an added bonus in my book
OutlawDrifter
KS
Always fun to see odd stuff at the shows, definitely hot today...after washing the wife's rides and mowing I declared it an inside day!
Super easy to tell the difference on the 1st gen Camaro(67-69). 67 is the only year with a wing window(also has no signal lights on the front fender or rear quarter). 68 lost the wing window and added the signal lights. 69 has the creases that run off the top of the wheel well openings.
Those Corvair pickups are rad! My grandpa had an Econoline pickup in the late 60s when he was selling equipment.
L
loganb
Omaha, NE
That 1st gen camaro is lying to people hahaha
And looks good while doing it.....kinda like some girls I knew back in the day...
Makes it a '69 based on a picture from a prior event that I'm pretty sure was of the same car....I wasn't wise enough to take a picture of the outside lol...just under the hood and inside
At peast its got a proper orange and white paint scheme! Go Vols!
Better that then a certain Texas team!
L
loganb
Omaha, NE
Doesn't feel like much progress this week
At least the beer fridge is full with the leftovers from some gatherings:
Short road trip coming up so looking over the road trip tool bag...had far too many sockets set's in there so dumped the bag out, got batteries on the chargers and reducing the weight a little bit:
Now to just figure out where my prescription sunglasses are and finish packing the bags for the rugrats I mean kids :)
Trapps
The Detroit Zoo
+1 for the Wera Tool Check plus. Was your acquisition inspired by Ryan's post too?
I wonder what kind of purchasing/revenue impact garagejournal.com has the overall tool world?
Loves the cars & coffee pics too!
L
loganb
Omaha, NE
No...I'm a well admitted tool *****/snob with a softspot for Wera. Think the rabbit hole on their catalog picked up momentum 6 or 7 years ago when I found one of their Advent calendars that was really good (before they got more popular) and it was the prior years and dirt cheap. I think I bought 6...several for gifts and the rest for me to use for my own purposes! I love the Tool Check kits...one of their screwdrivers with bit storage in handle lives in each vehicle, this was the intended primary tire changing tool before the M12 3/8" impact with 500ft lbs came on sale:
Nice insurance policy....never used for it's intended purpose. Part of me struggles with replacing a solid kit like this with a battery driven platform that I have to keep batteries fresh on....but on road trips longer then an hour the M12 inflator and M12 flashlight are coming as well so it's an additional power tool on the same battery platform. This Wera set might slip move to under the seat of the work Tacoma to have there...though a search tells me I need a 21mm for those lugnuts so I'll have to pick one of those up to guarantee it never gets used for that purpose :)
On other fronts....992 miles from Sunday to Wednesday and home again. Fortunately none of the tool bag contents were touched, but the Volvo does need an oil change now...and still have an O2 sensor to install as that didn't get done before we departed. I think my wife's limit in the car with kids across this time frame was probably 700 miles....but we all survived and head back to work tomorrow "to relax"
Main destination was Branson....Airbnb vacation house rental for a large (17 total ppl) birthday gathering for a significant birthday for my wife's stepdad. Been to Lake of the Ozarks a lot, my first time to Branson/Table Rock area....keep in mind we spent 0 time actually at the lake:
  • Branson proper is overrated but the best example of a tourist trap I've seen(which yes, means I haven't been to Disney...yet). And it's all on a 2 lane(with center turn lane) windy *** road thru main street and I don't want to imagine what the backup looks like on a holiday weekend
  • Branson Aquarium is surprisingly really good if you've got little's....say under the age of 10 or 12....I'm a zoo snob with the normal top zoo in the country in my backyard but this was good:
  • If we go back there, next house will be on the lake with or near a boat rental place and there will be 0 trips into Branson except for trips to the food store and the beer store
OutlawDrifter
KS
Man, wish I would have known ahead of time...hopefully you found, or knew of Macadoodles, truly an amazing liquor store!
Definitely a tourist trap, we went last summer for a quick getaway. Stayed in a VRBO on a golf course. Tons of people and that street *****!
L
loganb
Omaha, NE
We got a Macadoodles in Omaha last year! Very nice store....I haven't fully decided if I like Total Wine & Spirits or Mac better....I'm probably more partial to Total Wine but they're all of 1.5 miles apart on the same road so it's easy to hit both on the same trip :)
Good experience with the house rental....in a development of built to rent houses, nice pool/clubhouse, not sure what it cost for the house but the same place for the same days next week was 320/night which for a 6 bed/5 bath house seems pretty good to me. It could use some maintenance and fixes...but for a vacation rental in that tourist trap it was more than acceptable. I think I did irritate a couple people when I got the "locked" backdoor open in about 10 seconds when there was confusion on the front door keycode and it locked itself out in some timeout safety feature. I just got lucky it was a cheap door with latch only(no deadbolt) so not hard to retract the latch enough to get it to open....they thought it was a movie trick and wasn't something that happened in real life....but it meant we got supper sooner so it was soon forgiven
L
loganb
Omaha, NE
Tired of the planer ******* gear oil on the side from the gear box
And where I think the leak is coming from...the oring in the handle to go from high to low.
New orings to be here Monday...see if it can go back together and be a bit more civilized
