Between 485 & 705 SQ/FT 3rd time's a charm with a 3 car workshop
L
loganb
Omaha, NE
Making slow progress in the Nova
We are hosting a large gathering next week(ugh) so it's gotta go back to storage shortly so I can get the garage cleaned up for overflow seating in case it's warm
Will have to find some homes for a bunch of little stuff on this years Epstein day event
And caught this and had to grab a pic and share the fuel company with a sense of humor
OutlawDrifter
KS
I got the dental pick and tweezers as well as too many other things!
Skipped the 250th pliers...didn't have room in the drawer and I spent an absurd amount of money on pliers last year :LOL:
And because we all need some **** talking...you better get your *** in gear on that Nova! Prime Fall driving season is coming up ;)
L
loganb
Omaha, NE
Definitely not wrong on needing to get moving! The list is getting smaller....it's back to driveable now which is a big plus....well once it's off the jackstands and fluids are topped off! I've been told it should go back to storage tomorrow....not sure I'm going to get that one done....will depend on how much help with kids I get
L
loganb
Omaha, NE
Ended up with about 18.5 lbs of pulled piggy in the freezer.
Nova is closer and should be driving again tomorrow night....now that means driven to storage as there won't be any time to work on it till after the weekend event but it's more then it's driven the past 2 weeks
L
loganb
Omaha, NE
Nova is back in storage...for a couple days
Power washer got broken out
Put the still new in box from a year or so ago(oops) surface cleaner on and gave the stall a wash
It does do a nice job of medium cleaning with minimal mess and over spray. It's a 15" cleaning head with a rating of 3.8 from on a pump at 3.5 gpm and it feels a bit underpowered but the slab is much cleaner so it was apparently powerful enough.
L
loganb
Omaha, NE
Props to all y'all who host events all the time....shits a lot of work lol. When you do it more often it gets easier...but glad this event is on a 7 yr rotation so won't be our turn for awhile after Sunday...maybe I take Monday off work.
Now to finish putting away tools and moving more stuff around in the garage to make more space
L
loganb
Omaha, NE
Too hot, too much left over food and beer....wait only 1 of those 3 things is actually bad lol. Gathering went well, everyone seems to have had a good time...garage having AC was a big help as it provided sufficient space everyone could stay inside if they wanted and get away from the heat index of 114 or so we had. All the 3d printed fidgets and toys were enjoyed and disappeared so that was great and the laser got fired up for some coasters
Now to figure out some better locations for some of the tables and chairs so they're out of my garage and then back to more regularly scheduled programming here.
Did wake up to an unexpected message on the thermostat about how it was calling for cool but temp was going up....uh oh with today's forecast being similar to yesterday and 100+ actual and heat index of 110+. Compressor fan was spinning normally so not capacitor(which is guaranteed to not fail as I have a spare!), filter was good so kicked it off and let it sit for 10 minutes then fired it back up and a couple minutes later had this temp reading in the duct above the A-coil
So....not sure what happened but it apparently needed a reboot. Seems to be cooling things off correctly again so hopefully this was just a fluke. AC is about 10 years old but a 4 ton unit so should have plenty of life left but when it goes it won't be cheap to replace.
L
loganb
Omaha, NE
Hope it was just from running constantly that cause a little hiccup in the system.
Appears to have been as hasn't had an issue since! Knock on wood...
Speaking of wood....
Neighbor asked if I could help on a little project. They lost a tree in a windstorm last year and they kept some cookies and wanted to combine one with a bomb tail/fin stabilizer they had to make a small end table.
The cookie has had a significant amount of epoxy poured on it and it's not flat...so that added some complexity
Initial mockup
The tail of the fin stabilizer has to be cut down a bit so it doesn't take as deep of a pocket into the bottom side of the table
Bottom side as I pondered how to knock the high spots off
Landed on the CNC to flatten it as was too tall once leveled out for the sander. Didn't do the entire bottom, but enough to get the fins to sit flat
And closer to mocked up ..need to make a template to get final diameter on the pocket in the base....it's going to end up in the range of 2-5/8"
gearhead1960
Years ago, had A/C tech want to clean my outside unit cooling coils for big $$$ as most people don't know that this can affect performance greatly. I now clean them every other year in hopes that the lower load on the unit will give me longer life for the A/C system...you might want to check your unit, if you haven't already done so....IMG_3476r.jpgIMG_3477r.jpg
L
loganb
Omaha, NE
Great reminder! I've got clean the coils on an annual calendar reminder and did do it this spring vs dismiss and say "will get it later"...I've got the fun "fuzzy coils vs the straight fins so they're especially fun to clean
This morning got out early with the kids and hit the Offutt AFB airshow flightline before it got hot and other conflicts came up...got to see the planes but had to leave before the airshow part
C-5 Super Galaxy out of Dover...last year they had a C-17 here
F-35 Demo team flies at 2:14 today...they brought 4 birds, two on static display and two for the airshow
Had a BUFF on hand
Bomb bay
Cool TBM torpedo bomber, apparently the only flying nationally historic designated structure. They were doing paid rides on this ....that would be pretty sweet
Looking up the tail to the rear facing gunner position
L
loganb
Omaha, NE
Been awhile since I've been to that show. They generally put on a good one. B2 gave us a flyover last time I went 7-8yrs ago.
Mother nature had her way this year and the air portion got canceled around 1:30 or so as a thunderstorm rolled thru. Tomorrow looks clearer and hotter.....not sure if I'll try and go to the show part solo or not. When we left the line at security to get to the show area had to be at least an hour long....not something I want to tackle with kids...
L
loganb
Omaha, NE
Local shop had a donuts and coffee event this morning so loaded the kids up
As you might guess they specialize in Corvette and Gen 1 Camaro...very nice shop
Some of the more unique things that dropped in...we were there early and left early.....kids lost interest when I said no to a third donut lol
'56 DeSoto Firedome Wagon
L
loganb
Omaha, NE
Kids just left for a playdate so lets see if we can get anything accomplished
Rear view mirror wasn't behaving last night on the ice cream run so trying to get it cleaned up, a new fastener hopefully gets it the tension it needs to stay put. Bit of brake clean and some new spray lithium hopefully lubes up the ball for easy adjustment for another 50 or so years
Been working on a bit of a display board for it when it goes out to a show....my graphic design skills aren't great so this has been very AI assisted. Claude has been working best and was able to quickly build out a "tool" to allow me to adjust all the text, sizing, fonts, columns sizes after I provided the scans of the window sticker and protect-o-plate. I need a new "hero image" of the car...it's cloudy today so not sure I'm going to be able to get it today but this is progress at least. Sized for 18 x 24" printing
Hopefully on the plate this afternoon is polishing/clean up time. There is a 50 Mile March fundraising event next weekend where they march from Lincoln to Omaha to raise money for veterans causes and I know several marching this year. They're trying to setup some cars to line the march in and I submitted the Nova to participate if they want it. Unsure whether they're going to use it as they've got limited spots and I suspect they're going to have a lot of interest from the local supercar scene which is surprisingly robust but either way gives me a goal to work towards and get more polishing/paint correction done.
L
loganb
Omaha, NE
Slowly getting there
Almost done across the whole thing with fast correcting cream on a cutting pad...looks and feels much better. Exterior glass has been cleaned up and clayed as well, still need to get the interior glass and then probably some polishing on the glass. Before I get too carried away on the glass though I'll get the fast correcting cream pass finished, then move to the next level and start over. Hopefully with a lot of the scratches/water spots etc gone it'll continue to speed up as I move thru. Pile of dirty microfiber clothes is growing...going to need to find a spot for some totes/drawers to better store the clean ones.
L
loganb
Omaha, NE
Made some progress
First pass all done...onto next pass with an orange pad, trunk is done...hoping to get drivers side done tonight. Took the kids to the park in it...was going to do an ice cream run but the older one doesn't seem to want to finish her supper
Speaking of supper
Overcooked the bird....breast got too hot but was fine for this round...will need sauce for when it gets warmed up for leftovers.
L
loganb
Omaha, NE
Random updates
Making some items for a charity auction back home...will be going in some slate coasters...couple different designs
Little project on the bomb tail end table
Put 50 miles or so on the blue car, hit a small cars and coffee event with the kids after a donut stop....will try a different one next time that is better attended. Picture is edited a bit...the paint doesn't pop that much in person lol
Took a headrest to Ace to pick the spray paint color for the speaker grilles
Kids "helped" paint and didn't do too bad but will need one of the spray gun handles for them.
More work tonight to try and clean up the Nova more, will be lining it up with some other cars at the finish line of a 50 mile march from Lincoln to Omaha. They're raising money for veteran related causes and the Nova made the cut for the lineup. It's mostly late model stuff including a 2,500 HP Lambo but should be a fun morning and a good cause. Link below if anyone wants more information
madison069
Monroeville, PA
Seems cancer is more common lately as a previous co-worker passed from cancer and currently my buddy who painted my car is fighting cancer. There several folks around me who has beaten cancer but always fears of it returning. Seems nothing is safe these days as everything causes cancer.
L
loganb
Omaha, NE
Very diverse lineup
Leading the pack are matching corvettes, the one on the far side is Kyle from 1320 Media's
The reds are a pair of highly modified Lambo's with over 4000 HP between them, then the blues has another very nice blue Corvette...and the lowly Nova lol
L
loganb
Omaha, NE
Few other shots....there were a number of drones up and lots of professional photographers so will see what comes out over the next couple of days as they do their editing
Very nice Camaro with lambo doors
Not always a huge fan of Audi R8's but this one is very nice and sounded awesome. Hearing some of these may spur irrational noise making upgrades sooner then was planning...lol
This was the other blue car...."Blue Angel"....I suspect it's horsepower out of 3 cylinders was equivalent to the 8 in the Nova!
And then the purpose of the event, this is the back half of the squad marching in....they had just over 200 I believe who finished and raised around $800k toward their cause of veteran support.
This image looks a bit heavy on the "middle age white male" demographic but was a pretty diverse group. One completed it in a wheelchair, a large number of females including an 11 year old who finished it for the third time. Lots of media coverage at the landing zone so hopefully it continues to grow
L
loganb
Omaha, NE
Sharp looking Nova!
Thanks! She's getting shiny-er! Inlaws who sent it our way are coming in this weekend for a quick visit so hoping to have it looking better then he's seen it in a long time.
Need to get the rear speaker grilles finished, then make some shims for the rear shoulder belt brackets....they're at times not extending like they should and think it's cause they're not setting level enough on that rear package shelf
Uofime
Charleston SC
A free flowing exhaust on that suspected smogger engine is probably not going to sound like you hope. You really need compression and a cam (and heads to match it) to make a properly rowdy sounding engine.
Problem then becomes the vehicle is less suited to family duty
OutlawDrifter
KS
Oh, ye of little faith...a lot can be done with any V8, low compression or otherwise.
With the correct size of pipe and proper muffler selection, you can fool people with what's under the hood.
L
loganb
Omaha, NE
Nova is looking sharp, these are one of my favorite muscle cars!
+1 what @fouckhest said. In my pretend list of project cars, always wanted to do a 68-70 Nova with a 427 and a manual. Of course it would be set-up like a Pro-touring car….
Thanks guys! Growing up with Dad having a Chevelle I was partial to those....I'm now growing more fond of the little X-Body sister. I'd like to expose the kids to car related work more...i encourage them to come out and join as I'm working on it(which does mean I get less done) but the more it occurs the more I think I'd like to do a full engine swap down the road when they're upper grade school/middle school and at an age where they can really do some work. I'd likely have to pay thru the nose for a decent body muscle car candidate for a LS swap with a 5 speed in 5 years down the road....but "so the kids and I can have a project" does sound like great justification
It sounds very good for what's there right now with a slightly lumpy RV cam and dual exhaust....but the kids do giggle when I push the skinny peddle so more throaty noise means more laughs and giggles and it's all for the kids right? LOL
The corvette's that were there on Sunday sounded ridiculous but they all had high end exhaust designed to stand out and lots of under the hood work and they were idling a lot as things were getting moved around. I originally was thinking front suspension/steering/brakes would be the first really major upgrade but replacing the worn subframe bushings improved the overall feel and handling a lot. Steering is still too soft and easy for my preference but thats likely the steering box as much as anything so not sure what may be on the plate for major winter work....still a lot of fall driving to do before we get there!
L
loganb
Omaha, NE
Making moderate progress....maybe
Been spending too much time on the couch at night and not enough in the garage as been too tired to head out when kids got to bed...so been trying to feel productive and work on making a sign board for the Nova for when it goes out on display.
Full file is attached, made with an AI (Claude) tool to handle all the sizes, fonts, editing etc. Going to send it to printing and then revise as I go....open for all thoughts and input on what you'd change, like to see more of, want to read yourself on these boards etc!
Wife's Volvo hit the shop as it had a new growling/noise I couldn't find a cause for in the area of the transmission...coming back with new tires/alignment that were definitely needed and no great answers on that noise other than do a drain and refill on the ****** 2 to 3x and see if it improves. Not super encouraging....but I have the materials already for at least that first drain/refill so need to get that done tomorrow, then see how it behaves as I order more supplies from FCPEuro to do the next drain. Really not sure what "next" vehicle would be if we need to start looking for something different but it's guaranteed to be ugly and too expensive
Ironically this '76 C10 Suburban came up for sale locally, heavily upgraded with a late model Blueprint 350, EFI, AC, mostly newer interior....I think it would be a sweet daily driver....she....well she wasn't so fond
Yeah, she has some character....wife called it rust...though to be fair the wife has no interest in a new suburban or anything else of that size....so I knew from the start an old one was even more of a no-go!
  • 8.26 nova board.pdf
OutlawDrifter
KS
I saw the same ad on FBMP for the 'burb. It really would be a great driver.
So is Tahoe sized stuff too big also? Toyota offers a lot of great SUV options 🤷‍♂️
legenddc
I've known two people with Volvos of similar ages that seemed to develop a lot of expensive fixes once they hit 100k. Hopefully the drain/refill solves your transmission issues.
L
loganb
Omaha, NE
I'm glad I'm not the only one who thought it would be sweet! $9.5k for anyone interested in Lincoln, NE
As for her next vehicle...she honestly doesn't know what she might want which is a blessing and a curse. Largest she's ever had as a daily was my '03 Cadillac Seville STS, then this XC 60. She says she'd like more storage space and another row of seats, but at the same time says she doesn't want anything that much bigger....but not show how much "bigger" is acceptable. She's definitely against Suburban size....I think Tahoe size is out as well, she's adamantly against mini-vans due to her perception of them though I don't think she's ever been in one made in the last 15 years. I think when we have to eventually go shopping for something she's being forced to test drive a couple van's...which may backfire on me.
We have access to a Hyundai Palisade that she's ridden in a fair amount but never driven, she seems to be ok with that so I think in the lines of that, Honda Pilot, GMC Acadia, Toyota Highlander type rides where there is a 3rd row but minimal storage space behind it. I don't like the prices of any of them so that's not helpful to the equation! I also am partial to vehicles being on the more "loaded" side of the options spectrum which doesn't help the price tag either.
I'm hopeful...with 160k miles on it's not worth a rebuilt ****** so if doing a fluid drain and fill 2x a year helps keep it on the road....I guess I'm doing it. It's actually not a hard fluid change at all so that's helpful. The shop I took it to(local independent who specializes on foreign stuff) said it was the last year of "fairly" trouble free ones for a bit. The '16 thru '19's they said had either rod bearing or lower control arm bushing issues, so at least avoided those issues! If this does quiet things down it'll be time to look at new front struts as they're still the original and it's got some odd headlight fault on a front headlight. These are the motorized ones that adjust aiming with the tires so it could be several things
madison069
Monroeville, PA
I don’t envy you for shopping for a car for the wife. I was able to narrow it down to a RAV4 and an Outback for the wife. The Outback won because the rear cargo space was big enough to put her mother’s scooter in the back if needed.
I’m cool with it cause of the crash rating and the fact I know my mother survived a wreck in a forester that should have killed her and my cousin. But the forester kept them safe while the engine of that car went under the cab.
